LPAF-40-03.0-L-08-2-K-TR
    SAMTEC(申泰)
    SMD,P=1.27mm
    板对板连接器 立贴 针脚数:320Pin 间距:1.27mm 排数:8
LPAF-40-03.0-L-08-2-K-TR 数据手册
F-217 LPAF–20–03.5–L–06–2–K LPAF–20–03.5–L–04–2–K (1.27 mm) .050" LPAF SERIES HIGH-SPEED LOW PROFILE OPEN-PIN-FIELD SPECIFICATIONS Mates with: LPAM 4, 6 or 8 row standard .050" (1.27 mm) X .050" (1.27 mm) pitch For complete specifications and recommended PCB layouts see www.samtec.com?LPAF Insulator Material: Black LCP Contact Material: Copper Alloy Plating: Au or Sn over 50 µ" (1.27 µm) Ni Current Rating: 2.2 A per pin (6 adjacent pins powered) Working Voltage: 250 VAC RoHS Compliant: Yes Lead-Free Solderable: Yes RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality Solder crimp HIGH-SPEED CHANNEL PERFORMANCE LPAM/LPAF @ 5 mm Mated Stack Height Rating based on Samtec reference channel. For full SI performance data visit Samtec.com or contact SIG@samtec.com LPAF FILE NO. E111594 Dual Beam contact 43 LEAD STYLE NO. PINS PER ROW 4 mm, 4.5 mm and 5 mm stack heights Up to 40 pins per row G b p s PLATING OPTION NO. OF ROWS –L – 04 SOLDER TYPE K TR –K =Tape & Reel ALSO AVAILABLE (MOQ Required) • Tin-Lead Solder Charge • Other pins/row and row counts • Other Gold plating options Contact Samtec. –03.0 = (3.0 mm) .118" –10, – 20, – 30, –40 –03.5 (Per Row) = (3.5 mm) .138" = 10 µ" (0.25 µm) Gold on contact area, Matte Tin on solder tail MATED HEIGHT –2 = Lead-Free Solder Crimp =Four Rows – 06 =Six Rows = Polyimide film Pick & Place Pad – 08 =Eight Rows LPAF LPAM MATED HEIGHT NO. OF ROWS B –04 (6.71) .264 (9.25) .364 (11.79) .464 –06 MATED HEIGHT* LPAF LEAD STYLE –08 No. of positions x (1.27) .050 + (5.15) .203 (1.27) .050 LPAM LEAD STYLE –01.0 –01.5 –03.0 (4.00) .157 (4.50) .177 –03.5 (4.50) .177 (5.00) .197 *Processing conditions will affect mated height. B (1.27) .050 (1.27) .050 A (1.32) .052 DIA No. of positions x (1.27) .050 + (3.10) .122 Note: Patent Pending Note: Some sizes, styles and options are non-standard, non-returnable. WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. LEAD STYLE A –03.0 (2.79) .110 (3.30) .130 –03.5 – TR
LPAF-40-03.0-L-08-2-K-TR 价格&库存
很抱歉,暂时无法提供与“LPAF-40-03.0-L-08-2-K-TR”相匹配的价格&库存,您可以联系我们找货
  • 1+236.868991+30.78173
  • 10+201.3098610+26.16073
  • 25+188.7033525+24.52249
  • 50+182.5680050+23.72518
库存:48
  • 350+150.12758350+19.50947
  • 700+149.15738700+19.38339
库存:48
