MLE-107-01-G-DV-K-TR 数据手册
F-215
MLE–120–01–G–DV
MLE–150–01–G–DV
CLM–126–02–F–D
CLM–111–02–L–D
(1,00 mm) .0394"
CLM, MLE SERIES
RUGGED RELIABLE MICRO SOCKETS
SPECIFICATIONS
For complete specifications and
recommended PCB layouts
see www.samtec.com?CLM
or www.samtec.com?MLE
Insulator Material:
Black LCP
Contact Material:
CLM: Phosphor Bronze
MLE: BeCu
Plating:
CLM: Au or Sn
over 50µ" (1,27 µm) Ni
MLE: Au over 10µ"
(0,25 µm) Ni
Current Rating (CLM/FTM):
2.8 A per pin
(1 pin powered per row)
Current Rating (MLE/FTM):
2.9 A per pin
Operating Temp Range:
-55°C to +125°C
Contact Resistance:
CLM: 15 mΩ
Max Cycles:
CLM: 100 with 10µ" (0,25 µm) Au
Voltage Rating:
MLE: 310 VAC
Insertion Depth:
CLM: Top Entry = (1,40 mm)
.055" min., Bottom Entry =
(2,41 mm) .095" min.
(Add board thickness for
correct post OAL)
MLE: (1,63 mm) .064" to
(3,18 mm) .125" with
(0,38 mm) .015" wipe,
pass-through, or
(2,44 mm) .096" minimum
for bottom entry
Insertion Force:
CLM: 1.5 oz (0,42 N) average
MLE: 2.70 oz (0,75 N) average
Normal Force:
CLM: 40 grams (0,39 N) average
Withdrawal Force:
CLM: .75 oz (0,21 N) average
MLE: 0.50 oz (0,14 N) average
RoHS Compliant: Yes
Lead-Free Solderable: Yes
SMT Lead Coplanarity:
(0,10 mm) .004" max (02-25)
(0,15 mm) .006" max (26-50)
CLM
NO. PINS
PER ROW
1
PLATING
OPTION
02
Mates with:
FTM, FTMH, MW
D
–F
–BE
= Gold flash on
contact,
Matte Tin on tail
02 thru 50
= Bottom Entry
(Required for bottom entry)
–L
(1,00)
.03937
No. of positions x (1,00) .03937
+ (0,318) .0125
100
02
= (3,50 mm) .138" DIA
Polyimide film Pick & Place Pad
(7 positions minimum)
–P
(2,41)
.095
(2,54)
.100
= Pick & Place Pad
–P
01
(0,28)
.011
(1,00)
.03937
–K
= 10µ" (0,25 µm)
Gold on contact,
Matte Tin on tail
(5,72)
.225
x
(3,57)
.140
(2,26)
.089
04-15
16-50
(1,36)
.054
–TR
= Tape & Reel Packaging
–PA
(3,56)
.140
(7,11)
.280
ALSO AVAILABLE
(MOQ Required)
• Alignment pin
• Other Gold plating options
Contact Samtec.
Pass-Thru
MLE
1
NO. PINS
PER ROW
01
PLATING
OPTION
Mates with:
FTM, FTMH, MW
No. of positions
x (1,00) .03937 + (0,20) .008
(1,00)
.03937
(0,30)
.012
(0,71)
.028
–A
01
Note: Some lengths, styles
and options are non-standard,
non-returnable.
–K
–P
(6,35)
.250
x
(3,18)
.125
(3,30)
.130
= Alignment Pin
(3 positions minimum)
Metal or plastic at Samtec
discretion.
= (4,00 mm) .1575" DIA
(5 positions minimum)
(0,64)
.025
DIA
(4,32)
.170
(3,12)
.123
–A
02
(3,07)
.121
(1,00)
.03937
OPTIONS
–G
02 thru 50
100
DV
= 10µ"
(0,25 µm)
Gold
RECOGNITIONS
For complete scope of
recognitions see
www.samtec.com/quality
= Pick & Place Pad with
integral Alignment Pin
(3,00)
.118
(0,89) .035
DIA
(7,00)
.275
A
PIN/ROW
APPLICATION
–PA
(8,26) .325
by A
(3,81)
.150
(2,12)
.084
OPTIONS
= Metal Pick & Place Pad
(3,50)
.138
–P
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
–TR
