MLE-135-01-G-DV-A-K-TR
    SAMTEC(申泰)
    SMD,P=1mm
    排母 间距:1mm 2x35P 立贴
MLE-135-01-G-DV-A-K-TR 数据手册
RUGGED RELIABLE MICRO SOCKETS (1.00 mm) .0394" PITCH • CLM/MLE SERIES CLM Mates: FTM, FTMH, MW CLM -1 MLE - 02 - NO. PINS PER ROW 02 thru 50 Mates: FTM, FTMH, MW –F PROCESSING = Bottom Entry (Required for bottom entry) –K –L = (3.50 mm) .138" DIA Polyimide film Pick & Place Pad (7 positions minimum) = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail PIN/ROW No. of positions x (1.00) .03937 + (0.318) .0125 04-15 (3.56) .140 16-50 (7.11) .280 –PA = Pick & Place Pad with integral Alignment Pin –TR = Tape & Reel –FR = Full Reel Tape & Reel (must order maximum quantity per reel; contact Samtec for quantity breaks) –PA (3.81) .150 (2.26) .089 (2.12) .084 –P MLE -1 - 01 - NO. PINS PER ROW 02 thru 50 PLATING OPTION - DV –G - OPTIONS –A = 10 µ" (0.25 µm) Gold = Alignment Pin (3 positions minimum) Metal or plastic at Samtec discretion –K = (4.00 mm) .1575" DIA Polyimide film Pick & Place Pad (5 positions minimum) MOQ Required No. of positions x (1.00) .03937 + (0.20) .008 Alignment pin Other Gold plating options –P = Metal Pick & Place Pad (5 positions minimum) (3.07) .121 –TR = Tape & Reel 10 YEAR MFG WITH 30 µ" GOLD EXTENDED LIFE PRODUCT F-224 = Pick & Place Pad (7 positions minimum) (8.26) .325 by A ALSO AVAILABLE Note: Some lengths, styles and options are non-standard, non-returnable. –P A (2.54) .100 Lead-Free Solderable: Yes SMT Lead Coplanarity: (0.10 mm) .004" max (02-25) (0.15 mm) .006" max (26-50)* *(.004" stencil solution may be available; contact ipg@samtec.com) HIGH MATING CYCLES OPTIONS –BE = Gold flash on contact, Matte Tin on tail SPECIFICATIONS Insulator Material: Black LCP Contact Material: CLM: Phosphor Bronze MLE: BeCu Plating: CLM: Au or Sn over 50 µ" (1.27 µm) Ni MLE: Au over 10 µ" (0.25 µm) Ni Current Rating (CLM/FTM): 3.1 A per pin (2 pins powered) Current Rating (MLE/FTM): 2.9 A per pin (2 pins powered) Operating Temp Range: -55 °C to +125 °C Max Cycles: CLM: 100 with 10 µ" (0.25 µm) Au Voltage Rating: CLM: 270 VAC MLE: 310 VAC Insertion Depth: CLM: Top Entry = (1.40 mm) .055" min., Bottom Entry = (2.41 mm) .095" min. (Add board thickness for correct post OAL) MLE: (1.63 mm) .064" to (3.18 mm) .125" with (0.38 mm) .015" wipe, pass-through, or (2.44 mm) .096" minimum for bottom entry -D- PLATING OPTION –FR (4.32) .170 (3.12) .123 (3.30) .130 –P –A = Full Reel Tape & Reel (must order maximum quantity per reel; contact Samtec for quantity breaks) samtec.com?CLM or samtec.com?MLE Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
MLE-135-01-G-DV-A-K-TR 价格&库存
很抱歉,暂时无法提供与“MLE-135-01-G-DV-A-K-TR”相匹配的价格&库存,您可以联系我们找货
