PNIRP-11V-S
PNIRP-11V-S
    JST
    P=2mm
    1X11P 2MM
PNIRP-11V-S 数据手册
PNI CONNECTOR 2.0 mm pitch/Disconnectable Crimp style connectors PNI CONNECTOR Specifications • Current rating: 3 A AC/DC (AWG #22) • Voltage rating: 100 V AC/DC • Temperature range: -25℃ to +85℃                     (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 10 mΩ max. After environmental tests/ 20 mΩ max. • Insulation resistance: 1,000 MΩ min. • Withstanding voltage: 800 VAC/minute • Applicable wire: Conductor size/ AWG #28 to #22 Insulation O.D./ 0.76 to 1.5 mm • Applicable PC board thickness: 1.6 mm * In using the products,refer to "Handling Precautions for Terminals and Connectors" described on our website (Technical documents of Product information page). * RoHS2 compliance * Dimensional unit: mm * Contact JST for details. This is a 2.0 mm pitch wire-to-board connector, having incomplete mating prevention mechanism. ● Inertial lock structure ● Finger-friendly design ● Secure locking structure Standards ® ® ® Recognized E60389 ® ® PC board layout and Assembly layout (6.65) 1.4±0.05 +0.1 0 +0.1 0 1.9 φ0.7 ±0.05 (12.25) φ1.1 Note: 1  . The above figure is the figure viewed from the connector mounting side. 2. Tolerances are non-cumulative: ± 0.05 mm for all centers. 3. Hole dimensions differ according to the type of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details. 1 (13.75) A±0.05 2±0.05 PNI CONNECTOR Contact Applicable wire Model No. mm2 Insulation O.D. (mm) Q’ty/ reel SPND-001T-C0.5 0.13~0.33 26~22 1.0~1.5 8,000 SPND-002T-C0.5 0.08~0.22 28~24 0.76~1.5 8,000 PNI CONNECTOR Material and Finish 7.5 3 AWG # Copper alloy, tin-plated (reflow treatment) 1.5 3.9 RoHS2 compliance 2.08 Applicator Dies Crimping machine Crimp applicator Contact SPND-001T-C0.5 SPND-002T-C0.5 MKS-L AP-K2N Crimp applicator with dies MK/SPND-001-05 APLMK SPND001-05 MK/SPAD/ND-002-05 APLMK SPAD/ND002-05 Note: Contact JST for fully automatic crimping applicator. Housing 6.45 6.45 B 10.05 10.05 5.7 Circuit No.1 2 2 A Circuit No.1 6.45 B No. of circuits Model No. PNIRP-02V-S PNIRP-03V-S PNIRP-04V-S PNIRP-05V-S PNIRP-06V-S PNIRP-07V-S PNIRP-08V-S PNIRP-09V-S PNIRP-10V-S 2 3 4 10.05 5 6 7 8 9 10 2 A Q'ty/ bag - 5.7 1,000 4.0 7.7 1,000 6.0 9.7 1,000 8.0 11.7 1,000 10.0 13.7 1,000 12.0 15.7 1,000 14.0 17.7 1,000 16.0 19.7 1,000 18.0 21.7 1,000 Material and Finish Circuit No.1 Glass-filled PBT, UL94V-0, natural (white) RoHS2 compliance B 6.45 As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. 10.05 ex. A Dimensions (mm) A B 2 Circuit No.1 PNIRP-02V-SS...natural (white) M...green R...red E...blue H...gray LG...light green K...black Y...yellow 2 PNI CONNECTOR Shrouded header Glass-filled PBT B Model No. With boss B02B-PNISK-1 B03B-PNISK-1 B04B-PNISK-1 B05B-PNISK-1 No. of circuits 6.55 2 A 3 4 5 Dimensions (mm) A B Q'ty/ box 2.0 6.0 1,000 4.0 8.0 1,000 6.0 10.0 500 8.0 12.0 500 10.2 Material and Finish Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Glass-filled PBT, UL94V-0, natural (white) 3.4 RoHS2 compliance This product displays (LF)(SN) on a label. 2 1.4 Glass-filled PA 66 1.9 No. of circuits 2 3 4 5 6.55 B 6 A 7 8 9 10.2 10 Model No. With boss B02B-PNISK-1A B03B-PNISK-1A B04B-PNISK-1A B05B-PNISK-1A B06B-PNISK-1A B07B-PNISK-1A B08B-PNISK-1A B09B-PNISK-1A B10B-PNISK-1A Dimensions (mm) A B Q'ty/ box 2.0 6.0 1,000 4.0 8.0 1,000 6.0 10.0 500 8.0 12.0 500 10.0 14.0 350 12.0 16.0 300 14.0 18.0 250 16.0 20.0 250 18.0 22.0 250 Material and Finish 3.4 Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Glass-filled PA 66, UL94V-0, natural (white) 2 1.4 1.9 RoHS2 compliance This product displays (LF)(SN) on a label. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. B02B-PNISK-1S...natural (white) M...green R...red E...blue H...gray K...black ex. B02B-PNISK-1AS...natural (white) M...green R...red E...blue H...gray LG...light green Y...yellow Retainer No. of circuits B Model No. PNIS-02V PNIS-03V PNIS-04V PNIS-05V PNIS-06V PNIS-07V PNIS-08V PNIS-09V PNIS-10V 2 3 (7) 4 5 6 7 8 2 9 A 2.25 10 Q'ty/ bag 2.0 6.3 1,000 4.0 8.3 1,000 6.0 10.3 1,000 8.0 12.3 1,000 10.0 14.3 1,000 12.0 16.3 1,000 14.0 18.3 1,000 16.0 20.3 1,000 18.0 22.3 1,000 Material and Finish Glass-filled PA 66, UL94V-0, natural (ivory) RoHS2 compliance 3 Dimensions (mm) A B
PNIRP-11V-S 价格&库存
很抱歉,暂时无法提供与“PNIRP-11V-S”相匹配的价格&库存,您可以联系我们找货
PNIRP-11V-S
    库存:4795
    PNIRP-11V-S
      库存:16000
