S1SS-07-28-T-11.82-L1 数据手册
TM
MICRO
(1.00 mm) .0394" PITCH • SINGLE ROW DISCRETE WIRE SOCKET
SERIES
S1SS
= Single Row
PVC Cable
S1SST
= Single Row
Blue *Teflon™
Fluoropolymer Cable
(28 AWG only)
PINS
PER ROW
–02, –03,
–05, –07,
–10 –15, –20
–28
= 28 AWG Color
Coded Cable
(S1SS only)
–L1
ISS1
= Single Row Body
–L3
S1SS CABLE
COLOR CODING
= 30 AWG Color
Coded Cable
(S1SS only)
–L
= Single Ended With Latch
= Double Ended Latch down,
straight (Pin 1 to Pin 1)
–30C
Insulator Material:
Nylon, White (with latch)
Black, LCP (without latch)
Contact Material:
Phosphor Bronze
Plating:
Au over 50 µ" (1.27 µm) Ni
Operating Temp Range
(S1SS(T)/T1M):
-10 °C to +85 °C (PVC)
-40 °C to +125 °C
(*Teflon™ Fluoropolymer)
Current Rating (28 AWG):
2.7 A per pin (1 pin powered)
Voltage Rating:
250 VAC/353 VDC
Wire: 28 or 30 AWG
(Required Callout)
= Assembled
Length in Inches
(45.72 mm) 01.80" min.
–30
SPECIFICATIONS
OPTION
–“XX.XX”
= 30 AWG
Board Mates:
T1M
Cable Mates:
T1SS(T), T1PS(T)
ASSEMBLED
LENGTH
= 3 µ" (0.07 µm)
Gold on contact
and tail
–28C
(Standard sizes)
PLATING
OPTION
–GF
= 28 AWG
S1SS(T)
SERIES
WIRE
GAUGE
(4.45)
.175
(2.80)
.110
No. of
positions x
(1.00) .03937
+ (1.20) .047
No. of positions
x (1.00) .03937
+ (3.00) .118
(5.00)
.197
COLOR
1
2
3
4
5
6
7
8
9
10
ETC
BROWN
RED
ORANGE
YELLOW
GREEN
BLUE
VIOLET
GRAY
WHITE
BLACK
REPEAT
–S
= Single Ended No Latch
–D–NUS
= Double Ended No Latch,
“N” up, straight
–D–NDS
“N” down, straight
*Teflon™ is a trademark of
The Chemours Company
FC, LLC used under
license by Samtec.
Assembled
Length
±(3.18)
.125
Assembled
Length
±(3.18)
.125
LATCH (–L)
PIN
= Double Ended Latch up,
straight (Pin 1 to Pin N)
Note:
cable is intended for
crimp only. Contact
Samtec for solderable
cable applications.
NO LATCH
View complete specifications at: samtec.com?S1SS & samtec.com?S1SST
NO. OF POSITIONS
–02, –03, –05,
–07, –10, –15, –20
SERIES
LATCH
(Leave blank for no latch)
–L
= Positive Latch
No. of positions
x (1.00) .03937
+ (1.20) .047
No. of
positions x
(1.00) .03937
+ (1.20) .047
01
CC09R
PLATING
–GF
= Contact, Full Reel
(25,000 Parts per Reel)
= 3 µ" (0.07 µm) Gold
contact and tail
CC09M
= Contact, Mini Reel
(5,000 Parts per Reel)
No. of
positions x
(1.00) .03937
+ (3.00) .118
No. of positions
x (1.00) .03937
+ (3.00) .118
(2.10)
.083
(9.01)
.355
(3.81)
.150
(4.20)
.165
LATCH (–L)
(5.00)
.197
NO LATCH
TOOLING
Hand Tool: CAT-HT-309-2830-12
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
F-224
Clamp for mounting hand tool: CAT-HT-MNT-01
Mini Applicator: CAT-MC-309-2830-XX-01
View complete specifications at: samtec.com?ISS1, samtec.com?CC09R & samtec.com?CC09M
samtec.com/MicroMate
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
S1SS-07-28-T-11.82-L1 价格&库存
很抱歉,暂时无法提供与“S1SS-07-28-T-11.82-L1”相匹配的价格&库存,您可以联系我们找货
