SACC-M12MS-8Q SH
SACC-M12MS-8Q SH
    PHOENIXCONTACT(菲尼克斯)
    SACC-M12MS-8Q SH
SACC-M12MS-8Q SH 数据手册
https://www.phoenixcontact.com/us/products/1543236 Bus system connector - SACC-M12MS-8Q SH - 1543236 Please be informed that the data shown in this PDF Document is generated from our Online Catalog. Please find the complete data in the user's documentation. Our General Terms of Use for Downloads are valid (http://phoenixcontact.com/download) Bus system connector, Ethernet CAT5 (1 Gbps), 8-position, shielded, Plug straight M12, A-coded, Insulation displacement connection, Knurl material: Zinc die-cast, nickel-plated, External cable diameter 4 mm ... 8 mm Why buy this product  Safe use in the field, thanks to a high degree of protection  Flexible: connectors for on-site assembly  Insulation displacement connection: innovative and time-saving assembly without stripping the single wire  Reliable signal transmission - 360° shielding in environments with electromagnetic interference Key Commercial Data Packing unit 1 STK GTIN GTIN 4046356097390 Weight per Piece (excluding packing) 46.000 g Custom tariff number 85366990 Country of origin Germany Technical data Dimensions External diameter 4 mm ... 8 mm Stripping length of the sheath ≥ 35 mm Ambient conditions Ambient temperature (operation) -40 °C ... 85 °C Degree of protection IP67 02/15/2017   Page 1 / 7 https://www.phoenixcontact.com/us/products/1543236 Bus system connector - SACC-M12MS-8Q SH - 1543236 Technical data General Rated current at 40°C 2A Rated voltage 30 V Number of positions 8 Insulation resistance ≥ 100 MΩ Coding A - standard Standards/regulations M12 connector IEC 61076-2-101 Signal type/category Ethernet CAT5 (IEC 11801), 1 Gbps Status display No Overvoltage category II Degree of pollution 3 Connection method Insulation displacement connection Conductor cross section 0.14 mm² ... 0.34 mm² Conductor cross section AWG 26 ... 22 Wire diameter incl. insulation ≤ 1.6 mm Frequency of connections between conductors of the same cross section ≤ 10 Insertion/withdrawal cycles ≥ 100 Torque 0.4 Nm (M12 knurl) 0.8 Nm (Connector with coupling sleeve) 3 Nm (Pressure nut with coupling sleeve) Material Flammability rating according to UL 94 V0 Contact material CuSn Contact surface material Ni/Au Contact carrier material PA 66 Material of grip body Zinc die-cast, nickel-plated Material, knurls Zinc die-cast, nickel-plated Sealing material Neoprene Standards and Regulations Standard designation M12 connector Standards/regulations IEC 61076-2-101 Flammability rating according to UL 94 V0 Environmental Product Compliance China RoHS Environmentally Friendly Use Period = 50 For details about hazardous substances go to tab “Downloads”, Category “Manufacturer's declaration” 02/15/2017   Page 2 / 7 https://www.phoenixcontact.com/us/products/1543236 Bus system connector - SACC-M12MS-8Q SH - 1543236 Drawings Schematic diagram Dimensional drawing Ø19 M12 ca. 61 Pin assignment M12 plug, 8-pos., view plug side SW16 SW13 Plug, M12 x 1, straight, shielded Classifications eCl@ss eCl@ss 4.0 27140815 eCl@ss 4.1 27260701 eCl@ss 5.0 27143423 eCl@ss 5.1 27143423 eCl@ss 6.0 27143423 eCl@ss 7.0 27449001 eCl@ss 8.0 27440104 eCl@ss 9.0 27440102 ETIM ETIM 3.0 EC002062 ETIM 4.0 EC002062 ETIM 5.0 EC002062 ETIM 6.0 EC002062 UNSPSC UNSPSC 6.01 31251501 UNSPSC 7.0901 31251501 UNSPSC 11 31251501 UNSPSC 12.01 31251501 UNSPSC 13.2 39121413 Approvals Approvals 02/15/2017   Page 3 / 7 https://www.phoenixcontact.com/us/products/1543236 Bus system connector - SACC-M12MS-8Q SH - 1543236 Approvals Approvals EAC / EAC Ex Approvals Approval details EAC      7500651.22.01.00246 EAC      EAC-Zulassung Accessories Accessories Data cable by the meter Network cable - VS-OE-OE-94B/... - 1417333 Network cable, Ethernet CAT5 (1 Gbps), 8-position, PUR halogen-free, water blue RAL 5021, shielded, free cable end, on free cable end, Cable length: Free entry (0.5 ... 400.0 m)     Network cable - VS-OE-OE-94C/... - 1417346 Network cable, Ethernet CAT5 (1 Gbps), 8-position, PUR halogen-free, water blue RAL 5021, shielded, free cable end, on free cable end, Cable length: Free entry (0.5 ... 400.0 m), For drag chains     02/15/2017   Page 4 / 7 https://www.phoenixcontact.com/us/products/1543236 Bus system connector - SACC-M12MS-8Q SH - 1543236 Accessories Network cable - VS-OE-OE-94F/... - 1417359 Network cable, Ethernet CAT6A (10 Gbps), 8-position, PUR halogen-free, water blue RAL 5021, shielded, free cable end, on free cable end, Cable length: Free entry (0.5 ... 400.0 m)     Electronics pliers Diagonal cutter - MICROFOX-SB - 1212489 Electronic diagonal cutter, round head, without chamfer, with opening spring, mirror-polished and oiled, 2-component grip, cutting capacity: soft 0.2 - 2.0 mm; medium hard 1.2 mm; hard 0.5 mm diameter     Protective cap Sealing cap - PROT-M12 FS-PA-CHAIN - 1430873 M12 sealing cap made of plastic with fixing band, for sensor cables, for free M12 sockets     Screwdriver tools Tool - SACC BIT M12-D20 - 1208445 Nut for assembling M12 connectors for assembly with a knurl diameter of 20 mm, for 4 mm hexagonal drive     02/15/2017   Page 5 / 7 https://www.phoenixcontact.com/us/products/1543236 Bus system connector - SACC-M12MS-8Q SH - 1543236 Accessories Adapter insert - TSD-M SAC-BIT ADAPTER - 1212600 Adapter bit for TSD-M...torque tools, E6.3-1/4" drive with 4 mm hexagon to accommodate SAC bits     Shield connection Shielding foil - ALU-SB - 1404531 Shielding foil, for fixing the braided shield of shielded cables. Length: 4 cm, width: 1.2 cm     Stripping tool Stripping tool - WIREFOX-D 40 - 1212161 Stripping tool, for stripping cables of 4.5 mm ‑ 40 mm‑Ø, insulation thickness of up to 4.5 mm, pivoting blade for round, lengthwise, and spiral cuts     Torque tool Torque screwdriver - TSD 04 SAC - 1208429 Torque screwdriver, with preset torque of 0.4 Nm and 4 mm hexagonal drive for M12 connectors     02/15/2017   Page 6 / 7 https://www.phoenixcontact.com/us/products/1543236 Bus system connector - SACC-M12MS-8Q SH - 1543236 Accessories Torque screwdriver - TSD-M 1,2NM - 1212224 Torque screw driver, accuracy as per EN ISO 6789 standard, adjustable from 0.3 ‑ 1.2 Nm     Torque screwdriver - TSD 08 SAC - 1212597 Torque screw driver with preset torque of 0.8 Nm, with 4 mm hexagon for accommodating SAC bits, two-component handle with non-slip grip     Stripping tool - VS-CABLE-STRIP-VARIO - 1657407 Stripping tool, for the multi-level stripping of shielded cables     Phoenix Contact 2017 © - all rights reserved http://www.phoenixcontact.com 02/15/2017   Page 7 / 7
SACC-M12MS-8Q SH 价格&库存
很抱歉,暂时无法提供与“SACC-M12MS-8Q SH”相匹配的价格&库存,您可以联系我们找货
SACC-M12MS-8Q SH
  • 1+502.243751+64.97864
  • 10+369.1907310+47.76468
  • 25+362.8771725+46.94785
  • 100+356.74707100+46.15476
  • 500+354.18495500+45.82328
  • 1000+345.492731000+44.69871
库存:15
