SFMC-102-02-S-D
SFMC-102-02-S-D
    SAMTEC(申泰)
    SMD,P=1.27mm
    排母 间距:1.27mm 2x2P 立贴
SFMC-102-02-S-D 数据手册
F-215 SFMC–125–T2–L–D–P SFMC–117–T1–L–D ™ SFMC–105–T2–L–D SYSTEM SFMC–112–03–L–D (1,27 mm) .050" SFMC SERIES ™ FLEXIBLE PIN COUNT TIGER EYE SOCKETS SPECIFICATIONS Mates with: TFM, FMTP, FFMD For complete specifications and recommended PCB layouts see www.samtec.com?SFMC Insulator Material: Black Liquid Crystal Polymer Contact Material: Tiger Eye™ = BeCu Tiger Eye™ LITE= Phosphor Bronze Plating: Au or Sn over 50µ" (1,27 µm) Ni Operating Temp Range: -55°C to +125°C Contact Resistance: 15 mΩ Insertion Depth: (3,05 mm) .120" to (4,06 mm) .160" Insertion Force: (Single contact only) Standard= 2.5 oz (0,69 N) avg. LITE= 2.0 oz (0,56 N) avg. LIF= 1.5 oz (0,42 N) avg. Normal Force: Standard= 132g (1,29 N) avg. LIF= 90g (0,88 N) avg. Withdrawal Force: (Single contact only) Standard= 2.0 oz (0,56 N) avg. LITE= 1.5 oz (0,42 N) avg. LIF= 1.5 oz (0,42 N) avg. Max Cycles: 10,000 with 30µ" (0,76 µm) Au RoHS Compliant: Yes Any number of positions from 2 through 50 High reliability Tiger Eye™ contacts ™ Slotted SMT tails Available with optional Pick & Place Pads SFMC 1 LEAD STYLE NO. PINS PER ROW PLATING OPTION D OPTION –01, –03 02 thru 50 Processing: Lead-Free Solderable: Yes SMT Lead Coplanarity: (0,10 mm) .004" max (02-26) (0,15 mm) .006" max (27-50) = Through-hole –L –L1, –L3 = 10µ" (0,25 µm) Gold on contact, Matte Tin on tail = Low Insertion Force Through-hole LEAD STYLE RECOGNITIONS A –02 B = Surface Mount – 01, –L1, –T1 (3,05) (0,51) For complete scope of recognitions see www.samtec.com/quality – 03, –L3 FILE NO: 090871_0_000 .120 (1,91) .075 .020 (0,41) .016 (1,27) .050 x No. of Positions + (0,38) .015 –T1 = Surface Mount Tiger Eye™ LITE (1,27) .050 TYP (10,00) .394 x (5,72) .225 = Through-hole Tiger Eye™ LITE –T2 (3,05) .120 ALSO AVAILABLE –P –L2 = Low Insertion Force Surface Mount (1,27) .050 TYP (1,27) .050 –P OPTION (0,58) .023 (0,13) .005 TYP (4,57) .180 (0,51) .020 A B = Plastic Pick & Place Pad (5 positions minimum) –TR = Tape & Reel (MOQ Required) • Other platings Contact Samtec. –K = (4,00 mm) .157 DIA Polyimide film Pick & Place Pad (4 positions minimum) (0,13) .005 TYP Note: Some sizes, styles and options are non-standard, non-returnable. WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. (4,19) .165
SFMC-102-02-S-D 价格&库存
很抱歉,暂时无法提供与“SFMC-102-02-S-D”相匹配的价格&库存,您可以联系我们找货
SFMC-102-02-S-D
  • 1+20.711001+2.63780
  • 50+16.6761050+2.12390
  • 100+14.69360100+1.87140
  • 500+14.61200500+1.86100
  • 1000+12.547901000+1.59810
  • 2000+11.743202000+1.49570
  • 5000+10.670405000+1.35900
  • 10000+10.2156010000+1.30110
库存:154
