TEM-145-02-07.0-H-D-WT 数据手册
RUGGED TIGER EYE™ SYSTEMS
(0.80 mm) .0315" PITCH
FEATURES & BENEFITS
MAX
2.9
• High-reliability, multi-finger BeCu contact
A
m
p
s
8
G b p s
• Micro pitch and slim body for space savings
• 6 mm, 7 mm and 10 mm stack heights
• Locking clip, alignment pins and weld tab ruggedizing features
• Rugged latching system for increased withdrawal force
• Vertical and right-angle mating headers
• Discrete wire assembly available with 32 AWG
*Teflon™ Fluoropolymer (See page 241).
Contact asp@samtec.com for custom solutions.
• Extended Life Product™ testing available
Locking for increased
unmating force
(Visit samtec.com?SEML
for more information)
*Teflon™ is a trademark of The Chemours Company FC, LLC
used under license by Samtec.
Components
(ISDE/CC396)
and tooling
available:
samtec.com/tooling
KEY SPECIFICATIONS (SEM/TEM)
STACK INSULATOR
HEIGHTS MATERIAL
CONTACT
MATERIAL
BeCu (SEM)
6 - 10 mm
F-224
Black LCP
Phosphor
Bronze (TEM)
PLATING
OPERATING
TEMP RANGE
CURRENT
RATING
Au or Sn over
50 µ" (1.27 µm) Ni
-55 °C to +125 °C
2.9 A per pin
(2 pins powered)
MAX.
CYCLES
VOLTAGE
RATING
100 with 10 µ"
235 VAC/330 VDC
(0.25 µm) Au
LEAD-FREE
SOLDERABLE
Yes
samtec.com/080mm-TigerEye
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
(0.80 mm) .0315" PITCH • MICRO TIGER EYE™ SOCKET AND HEADER
SERIES
SEM
Socket
SEMS
Slim Socket
TEM
1
NO. PINS PER ROW
- 02 -
05, 10, 15, 20, 25
–03.0
(SEM, SEMS,
TEM, TEMS only)
(SEM/TEM only)
(Standard sizes)
TEMS
Leave blank
for SEMS/TEMS
–A
–G
= 7 mm
Stack Height
(TEM/TEMS only)
= 10 µ"
(0.25 µm)
Gold on contact,
Gold Flash on tail
= Alignment Pin
(Not available
with –LC or –WT)
–H
= Locking Clip
(Not available
with –A or –WT)
(Manual
placement
required)
–LC
= 30 µ"
(0.76 µm)
Gold on contact,
Gold Flash on tail
–07.0
= 10 mm
Stack Height
(TEM/TEMS only)
OPTIONS
= Gold Flash
–04.0
Slim Header
-D-
PLATING
OPTION
–FG
= 6 mm
Stack Height
(–03.0 required for
SEM/SEMS Series)
30, 35, 40, 45, 50
Header
STACK
HEIGHT
–WT
= Weld Tab
(Not available
with –A or –LC)
SEM
Board Mates:
TEM
OTHER
OPTIONS
–K
= (3.50 mm) .138"
DIA Polyimide film
Pick & Place Pad
(Required for
SEMS)
= (5.50 mm) .217"
DIA Polyimide film
Pick & Place Pad
(Required for
TEMS)
–TR
= Tape & Reel
–FR
= Full Reel
Tape & Reel
(must order max.
quantity per reel;
contact Samtec
for quantity
breaks)
(No. of Positions
x (0.80) .0315)
+ (1.60) .063
(No. of Positions x (0.80) .0315)
+ (4.50) .177
(3.20)
.126
SEMS
SEMS
Board Mates:
TEMS
(4.50)
.177
(3.75)
.148
SEM
View complete specifications at: samtec.com?SEM & samtec.com?SEMS
TEM
Board Mates:
SEM, SEML
TEMS
Board Mates:
SEMS
(No. of Positions
x (0.80) .0315)
+ (3.35) .132
A
(No. of Positions x
(0.80) .0315) + (9.00) .354
(5.00)
.197
(5.50) .217
TEMS
TEM
MATED HEIGHTS
STACK HEIGHT
A
MATED HEIGHT*
–03.0
(5.610) .2209
6 mm
–04.0
(6.610) .2602
7 mm
–07.0
(9.610) .3783
10 mm
SEM
MATED
HEIGHT
TEM
*Processing conditions will affect mated height.
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
View complete specifications at: samtec.com?TEM & samtec.com?TEMS
F-224
TEM-145-02-07.0-H-D-WT 价格&库存
很抱歉,暂时无法提供与“TEM-145-02-07.0-H-D-WT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 56+126.3719056+16.21495
