F-215
TD –108–G–AA
HTS–115–T–C–2
TS –119–G–A–1
(2,54 mm) .100"
TS, TD, HTS SERIES
PRECISION MACHINED TERMINAL STRIPS
SPECIFICATIONS
For complete specifications see
www.samtec.com?TS,
www.samtec.com?TD or
www.samtec.com?HTS
Insulator Material:
Black G.F. Polyester (TS, TD)
Black Liquid Crystal Polymer
(HTS)
Terminal Material:
Brass, except Style G is
Phosphor Bronze
Plating:
Au over 50µ" (1,27 µm) Ni or
Sn over 100µ" (2,54 µm) Cu
or 50µ" (1,27 µm) Ni
Operating Temp Range:
-55°C to +125°C with Gold
-55°C to +105°C with Tin
RoHS Compliant:
Yes
Lead-Free Solderable:
Wave only
Mates with:
SS, SD, HSS, SL,
SDL, ESS, ESD
1
PLATING
OPTION
NO. PINS
PER ROW
Note: Some lengths,
styles and options are
non-standard, non-returnable.
TS
= Single
Row Terminal
Strip
LEAD
STYLE
–G
= 20µ" (0,51 µm) Gold
Except –J & –L are
10µ" (0,25 µm) Gold
(2,54) .100 x No. of Positions
(2,54)
.100
(2,54)
.100 TYP
–T
= Tin
HTS
= Single Row
High Temp
Terminal Strip
(2,54)
.100
01 thru 32
=TS Series
RECOGNITIONS
For complete scope
of recognitions see
www.samtec.com/quality
TYPE
STRIP
(5,08)
.200
01 thru 36
(2,54)
.100
TD
= HTS & TD Series
(2,54)
.100 TYP
= Double Row
Terminal Strip
(2,54)
.100
–AA
(0,46)
.018
DIA
(1,78)
.070
DIA
(0,46)
.018
DIA
(4,22)
.166
(0,64)
.025
DIA
-A
(1,32)
.052
(1,32)
.052
Y
X
(1,32)
.052 DIA
(0,46)
.018 DIA
(1,83)
.072
DIA
(4,47)
.176
(4,75)
.187
Component No. = T-1R5-
(1,83)
.072
DIA
Y
(3,18)
.125
± .010
LEAD
STYLE
(3,99)
.157
X
Y
(DIA) (±.015)
(0,46) (3,96)
.018
.156
(0,64)
.025
(5,33)
(0,89) .210
.035
-C
(2,54)
.100
-C-1
-C-2
X
Y
-C Component No. =T-1R2-C-X Component No. =T-1R9-
–L–1, –L–2, –L–3
(1,07)
.042
DIA
(1,07)
.042
(1,83)
.072 DIA
LEAD
STYLE
-L-1
(3,81)
.150
(7,62)
.300
± .015
(0,89)
.035
(DIA) (±.015)
(0,46) (3,96)
.018
.156
(0,64)
.025
(5,33)
(0,89) .210
.035
–J
(0,51)
.020 DIA
(12,90)
(1,02) .508
.040 ± .015
X
-A Component No. =T-1R0-A-X Component No. =T-1R7
–G–1
(0,51)
.020
-A-1
-A-2
(1,78)
.070 DIA
LEAD
STYLE
(4,22)
.166
(1,78)
.070
DIA
(3,96)
.156
±.015
–C, –C–1, –C–2
–A, –A–1, –A–2
(1,32)
.052 DIA
(0,51)
.020 DIA
Component No. = S-1P1-
(0,76)
.030
-L-2
Z
(1,32)
.052
DIA
-L-3
Y
(0,64)
.025
SQ
Component No. = S-1W1
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
Y
Z
(DIA)
(±.015)
(12,95)
.510
(9,14)
.360
(6,60)
.260
(17,86)
.703
(14,05)
.553
(11,51)
.453
