UPT-04-01-01-L-RA-LC 数据手册
HIGH POWER SYSTEMS
20-60 A
p er bla de
FEATURES & BENEFITS
• Current Rating: 23 A - 58.7 A per power blade
• 3.81 mm, 5.00 mm and 6.35 mm pitch
• Dual blade contact system
• Power only or power/signal combinations available
• Right-angle and vertical orientations
• Rugged screw down and locking clip options
• Discrete wire cable assemblies with 10-16 AWG wire
(see pages 246-248)
• “Hinged” for unique mating in any orientation
from 0° to 90° and space confined applications
CREEPAGE & CLEARANCE
Hermaphroditic options
samtec.com?MPPT and
samtec.com?UPPT
Hinging options available
samtec.com?FMPT and
samtec.com?FMPS
PITCH
CREEPAGE
CLEARANCE
UPT/UPS/UPPT
5.50 mm
1.51 mm
MPT/MPS/MPTC/MPSC
2.95 mm
2.71 mm
PET/PES/PETC/PESC
3.66 mm
3.31 mm
Selectively loading contacts achieves customer specific
creepage and clearance requirements.
KEY SPECIFICATIONS
SERIES
SERIES
INSULATOR CONTACT
MATERIAL MATERIAL
PLATING
OPERATING
TEMP RANGE
CURRENT RATING
VOLTAGE
RATING
LEAD-FREE
SOLDERABLE
UPT/UPS
(3.81 mm)
.150"
Black LCP
BeCu
Sn or Au over
-55 ºC to +105 ºC (Sn)
50 µ" (1.27 µm) Ni -55 ºC to +125 ºC (Au)
23 A
(1 pin powered)
438 VAC
Yes
UPPT
(3.81 mm)
.150"
Black LCP
Copper Alloy
Sn or Au over
21.4 A
(1 pin powered)
425 VAC
Yes
MPT/MPS
(5.00 mm)
.1969"
Black LCP
Copper Alloy
Sn or Au over
28.8 A
(1 pin powered)
575 VAC
Yes
(5.00 mm)
.197" (pwr)
MPTC/MPSC (2.00 mm)
.079" (sig)
Black LCP
Signal:
Phosphor
Sn or Au over
Bronze
Terminal:
Copper Alloy
28.8 A
(pwr - 1 pin powered)
5A
(sig - 4 pins powered)
250 VAC
Yes
PET/PES
(6.35 mm)
.250"
Black LCP
Copper Alloy
Sn or Au over
58.7 A
(1 pin powered)
450 VAC
Yes
PETC/PESC
(6.35 mm)
.250" (pwr)
(2.54 mm)
.100" (sig)
Black LCP
Copper Alloy
Sn or Au over
31.4 A
5.7 A
650 VAC (pwr)
450 VAC (sig)
Yes
F-224
samtec.com/PowerStrip
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
POWER™
STRIP 20
(3.81 mm) .150" PITCH • 20 A DUAL BLADE/LEAF POWER SYSTEMS
SERIES
POWER
PINS
UPT
–02
Terminal
–04
UPS
–06
Socket
–08
LEAD STYLE
–01
TAIL
LENGTH
–01
= RA only
–03.0
= (03.0 mm) .118"
(UPT–V & UPT–PV only)
–04.0
= (04.0 mm) .157"
(UPS–V & UPS–PV only)
–07.0
–L
= Use with
(1.60 mm) .062"
Thick PCB
(–V & –RA only)
–03
= Use with
(1.60 mm) .062"
Thick PCB
(–PV only)
–RA
–T
–PV
= Press-fit,
Vertical
"X"R
Leave blank for
tube packaging
= Locking
Clip
(Manual
placement
required)
Not available
with –PV
option
= Right-angle
= Matte Tin
(–RA & –PV
options only)
OTHER
OPTION
–LC
= Vertical
(Not available
with –T plating)
1RRISRZHUSLQV[
Board Mates:
UPS
TAIL
–V
= 10 µ"
(0.25 µm)
Gold on
contact,
Matte Tin
on tail
= (07.0 mm) .276"
UPT
PLATING
OPTION
–TR
= Tape & Reel
–FR
= Full Reel
Tape & Reel
(must order max.
quantity per reel;
contact Samtec for
quantity breaks)
1RRISRZHUSLQV[
MATED HEIGHT*
UPS
No. of power pins x
(3.81) .150 + (6.76) .266
Board Mates:
UPT
No. of power pins x
A
(3.00)
.118
B
UPT LEAD
STYLE
–03.0
–04.0
(7.00) .276
–07.0
(10.00) .394
*Processing
conditions will
affect mated height.
(12.74)
.502
(7.00)
.276
UPS
LEAD
STYLE
(2.82)
.111
(8.00)
.315
LEAD
STYLE
A
B
–04.0
(3.75) (6.75)
.148
.266
–07.0
(6.75)
.266
(9.75)
.384
View complete specifications at: samtec.com?UPT & samtec.com?UPS
SERIES
UPPT
Hermaphroditic
NO. OF POSITIONS
–02, –04, –06, –08
01
TAIL
LENGTH
–01
= (1.60 mm) .062"
Thick PCB
PLATING
OPTION
RA
–L
–TR
–FR
= Full Reel
Tape & Reel
(must order max.
quantity per reel;
contact Samtec for
quantity breaks)
1RRISRVLWLRQV[
View complete specifications at: samtec.com?UPPT
"X"R
= Tape & Reel
–T
Board Mates:
UPPT
Leave blank for
tube packaging
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
= Matte Tin
UPPT
SD
Note:
Some lengths, styles and
options are non-standard,
non-returnable
F-224
UPT-04-01-01-L-RA-LC 价格&库存
很抱歉,暂时无法提供与“UPT-04-01-01-L-RA-LC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+50.236351+6.50258
