Ha-VIS eCon 3000 Fast Ethernet Basic PoE / PoE+
5 to 8 Ethernet ports RJ45, FOC, and PoE / PoE+
English
Unmanaged Plug and Play Ethernet switches for DIN rail assembly in control
cabinets
Commercial temp.: 0 °C ... +55 °C / Industrial temp.: -40 °C ... +70 °C
Energy
Efficient
Ethernet
■ Energy supply of up to 4 terminal devices via PoE+ (137 watts) in
accordance with IEEE 802.3at
■ Fast Ethernet Non-Blocking Switch architecture in accordance with IEEE 802.3
■ Variants with industrial temperature range of -40 °C ... +70 °C
■ Surge protection and reverse polarity protection
■ Minimum energy consumption due to energy-efficient Ethernet
■ Optimised DIN rail bracket
Target markets
Machinery & Robotics
Automation
Industrial network
infrastructures
Wind Energy,
Solar Energy
Transportation
Shipbuilding
General description
The Ha-VIS eCon 3000 Fast Ethernet PoE family of unmanaged Ethernet
switches is equipped with up to 8 Fast Ethernet ports and allow for
cost-efficient and quick expansion and/or reconstruction of network
infrastructures. The switches work as power sourcing equipment (PSE)
and are capable of simultaneously providing the full PoE output of
34.2 watts on up to four ports. The slender design of the switches enables
an extremely high packing density on the DIN rail. The selection includes
various combinations of variants with RJ45 and fibre optic ports. Automatic
detection of the transmission rate (auto-negotiation) and of the wiring
of the twisted pair data cable (auto-polarity and auto-MDI(X)) allow for
simple plug and play. All variants are available with the temperature ranges
"Industrial" and "Commercial".
Technical characteristics
Switch features
Ethernet ports 10BASE-Te / 100BASE-TX
Enclosure width
25 mm
Type of connection
RJ45
Number of ports
5, 6, 7, 8
Auto-negotiation
Yes
Yes
Switching technology
Store and Forward
Auto-polarity
Supported standards
IEEE 802.3
Frame size
Auto-MDI(X)
1522 bytes
MAC table size
Transfer conditions
1k entries
Transfer speed
10 / 100 Mbit/s
Transfer length
100 m (Twisted Pair, Cat 5)
Packet buffer size
448 kbit
Non-blocking
Yes
Quality of Service
Yes
Energy-efficient Ethernet
Yes
PROFINET-compatible
Yes
EthernetIP-compatible
Yes
Yes
Twisted pair
Ethernet ports 100BASE-FX
Type of fibre
Multi-mode (MM)
Type of connection
Transfer conditions
FOC
Wavelength
Power supply
Nominal voltage
24 VDC
Permissible voltage range
48 VDC
9 VDC ... 60 VDC
Surge protection
Yes
Reverse polarity proof
Yes
Starting current
3.20 A
Overcurrent protection at input
Max. power consumption @ 24 VDC
Conductor cross-section
Type of connection
Pinout
54 VDC
6.40 A
Output power
Input sensitivity
7.20 A
Yes (12 A)
1.92 W ... 3.60 W
0.08 mm² ... 2.5 mm² (28 AWG ... 12 AWG)
3-pole, pluggable screw type terminal block
Supply circuit (according to 60950)
SELV (circuit breaker 10 A)
ICPN-Service@harting.com | Service hotline: +49 5772 47-9479
Fax: +49 5772 47-495 | www.HARTING.com/de/ethernet-switches
100 Mbit/s
2 km
15 km
-20 dBm ... -14 dBm
-15 dBm ... -8 dBm
≤ -30 dBm
≤ -32 dBm
Environmental conditions
Commercial temperature range
Industrial temperature range
Storage temperature range
0 °C ... +55 °C
-40 °C ... +70 °C
-40 °C ... +85 °C
Relative humidity (operation)
0% ... 95 % (non-condensing)
Relative humidity (storage and
transport)
Air pressure
HARTING Technology Group
P.O.Box 1473, D-32325 Espelkamp
Wilhelm-Harting-Straße 1, D-32325 Espelkamp, Germany
1310 nm
Transfer speed
Transfer length
Single-mode (SM)
SC Duplex
2000 m (795 hPa)
Note: We reserve the right to make technical changes to the products and to the content of this
document at any time without prior notification. The HARTING Technologiegruppe does not accept any responsibility for possible errors or incompletions in this document. We reserve all the
rights to this document and the topics and illustrations contained within it. Copying, disclosure to
third parties or use of its content - even partially - is forbidden without the prior written consent
of the HARTING Technologiegruppe.
Enclosures
PoE
Number of PoE ports
4
Standard
IEEE 802.3af / IEEE 802.3at
PoE type
PSE
Supported mode
Alternative A
Power supply PSE
48 VDC
54 VDC
Weight
480 g ... 508 g
2380 mA
Material enclosures
375 mA
638 mA
Anodised aluminium / powder-coated
steel sheet
15.4 W per port
61.6 W total
34.2 W per port
136.8 W total
Protection class (with pluggable
screw type terminal block)
Maximum current (PoE / PoE+)
Supported cabling
See 802.3at, section 33.1.4
Alternative A, MDI-X (1/2 = V-, 3/6 = V+)
Status and diagnostic displays
Power ("Pwr")
142 mm x 25 mm x 107.5 mm
35 mm DIN rail acc. to EN 60 715
1380 mA
PoE pinout
25 mm
Type of installation
Maximum power consumption
PSE
Maximum output power PSE
Enclosure width
Dimensions H x W x D (without
block and holding bracket)
illuminated green
Link/Activity ("L/A") off
Supply voltage is applied
No link
Link/Activity ("L/A") illuminated green
Link/Activity ("L/A") flashes green
Link is active
Link is active and data is transferred
Link speed ("Spd") off
10 Mbit/s
Link speed ("Spd") illuminated yellow
100 Mbit/s
PoE status
off
PoE status
illuminated green
Voltage in PoE range
PoE status
illuminated blue
Voltage in PoE+ range
PoE status
illuminated red
Fault
PoE is inactive / low voltage
IP30
Protection class
III
Approvals
CE, FCC CFR 47 Part 15, cUL US 508 listed, DNV, GL, ABS, NK, ABB IIT
EMC and environmental conditions
EMC interference immunity (EN 61000-6-1, 61 000-6-2 55024)
Electrostatic discharge (ESD) EN 61 000-4-2
Electromagnetic field EN 61 000-4-3
Rapid transients (burst) EN 61 000-4-4
Surge voltages EN 61 000-4-5 Conducted interference voltages EN 61 000-4-6
EMC interference emission (EN 61000-6-4, EN 55 022, FCC CFR 47 Part 15)
Mechanical stability (EN 60721-3)
IEC 60068-2-6 Vibration
IEC 60068-2-6 Resonance search
IEC 60068-2-27 Shock test
Included delivery
■ Pluggable screw type terminal block for power supply
■ Installation instructions
Drawings
Technical characteristics / order information
Ports / order information
SC
Enclosure
width
Power consumption @ 24 VDC
without PoE
MTBF in
million h
Switch
Part no.
Switch
Part no.
RJ45
SFP
4
1x MM (2 km)
25 mm
0.12 A
1.19
Ha-VIS eCon 3041B-AD-P
24 03 004 1130
Ha-VIS eCon 3041BT-AD-P
24 03 004 1120
4
1x SM (15 km)
25 mm
0.12 A
1.19
Ha-VIS eCon 3041B-AF-P
24 03 004 1230
Ha-VIS eCon 3041BT-AF-P
24 03 004 1220
4
2x MM (2 km)
25 mm
0.15 A
1.17
Ha-VIS eCon 3042B-AD-P
24 03 004 2130
Ha-VIS eCon 3042BT-AD-P
24 03 004 2120
4
2x SM (15 km)
25 mm
0.15 A
1.17
Ha-VIS eCon 3042B-AF-P
24 03 004 2230
Ha-VIS eCon 3042BT-AF-P
24 03 004 2220
6
25 mm
0.08 A
1.18
Ha-VIS eCon 3060B-A-P
24 03 006 0030
Ha-VIS eCon 3060BT-A-P
24 03 006 0020
6
1x MM (2 km)
25 mm
0.13 A
1.15
Ha-VIS eCon 3061B-AD-P
24 03 006 1130
Ha-VIS eCon 3061BT-AD-P
24 03 006 1120
6
1x SM (15 km)
25 mm
0.13 A
1.15
Ha-VIS eCon 3061B-AF-P
24 03 006 1230
Ha-VIS eCon 3061BT-AF-P
24 03 006 1220
8
25 mm
0.09 A
1.14
Ha-VIS eCon 3080B-A-P
24 03 008 0030
Ha-VIS eCon 3080BT-A-P
24 03 008 0020
Copyright© 2014
All rights reserved
Date of issue 02.2015
ICPN Datasheet 0844/01
很抱歉,暂时无法提供与“24030080020”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+4760.582611+597.21630
- 5+4474.322535+561.30490
