260-331
260-331
    WAGO(万可电子)
260-331 数据手册
Printview: 4-conductor terminal block; with fixing flange; for screw or similar mounting types; fixing hole 3.2 mm Ø; with 209-123 mounting carrier for DIN 35 rail - Item No.: 260-331 . 4-conductor terminal block; with fixing flange; for screw or similar mounting types; fixing hole 3.2 mm Ø; with 209-123 mounting carrier for DIN 35 rail Item No.: 260-331 . 4-conductor terminal block; with fixing flange; for screw or similar mounting types; fixing hole 3.2 mm Ø; with 209-123 mounting carrier for DIN 35 rail . Marking . Business data Supplier WAGO Item no. 260-331 GTIN / EAN 4044918592802 Content 1 Order amount 50 Customer item number . Notes Technical data Miscellaneous Total number of connection points 4 Total number of potentials 1 Color gray Pollution degree (1) 3 Rated voltage EN (1) [V] 400 [V] Rated surge voltage (1) [kV] 6 [kV] Nominal current [A] 18 [A] Connection technology (1) CAGE CLAMP® WAGO Kontakttechnik GmbH & Co. KG 1 Printview: 4-conductor terminal block; with fixing flange; for screw or similar mounting types; fixing hole 3.2 mm Ø; with 209-123 mounting carrier for DIN 35 rail - Item No.: 260-331 Technical data Solid sizes 1 0.08 … 1.5 mm² / 28 … 16 AWG Fine-stranded wires 1 0.08 … 1.5 mm² / 28 … 16 AWG Strip length 1 8 … 9 mm / 0.31 … 0.35 in Type of wiring Side-entry wiring Design horizontal Marking level Side marking Fire load [MJ] 0.042 [MJ] Weight [g] 2.524 [g] Width 8 mm / 0.315 in Height from the surface 17 mm / 0.669 in Length 25 mm / 0.984 in WAGO Kontakttechnik GmbH & Co. KG 2 Printview: 4-conductor terminal block; with fixing flange; for screw or similar mounting types; fixing hole 3.2 mm Ø; with 209-123 mounting carrier for DIN 35 rail - Item No.: 260-331 Images & drawings . WAGO Kontakttechnik GmbH & Co. KG 3 Printview: 4-conductor terminal block; with fixing flange; for screw or similar mounting types; fixing hole 3.2 mm Ø; with 209-123 mounting carrier for DIN 35 rail - Item No.: 260-331 Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 4
260-331 价格&库存
很抱歉,暂时无法提供与“260-331”相匹配的价格&库存,您可以联系我们找货
    • 1+363.65119
    库存:650
    260-331
      库存:50
      260-331
