F-215
JW–13–04–T–S–550–150
FWJ–08–01–T–S
FWJ–05–02–T–S–RA
(3,96 mm) .156"
FWJ, HFWJ, JW SERIES
POWER HEADERS & BOARD STACKERS
Mates with:
FHP
TYPE
STRIP
NO. OF
PINS
LEAD
STYLE
PLATING
OPTION
OTHER
OPTION
S
SPECIFICATIONS
For complete specifications
and recommended PCB layouts
see www.samtec.com?FWJ
or www.samtec.com?HFWJ
Insulator Material:
FWJ = Black Glass
Filled Polyester
HFWJ = Natural Liquid
Crystal Polymer
Terminal Material:
Phosphor Bronze
Plating:
Sn over 50µ" (1,27 µm) Ni
Operating Temp Range:
-55°C to +105°C
RoHS Compliant: Yes
Processing:
FWJ
= Standard
Header
HFWJ
= High Temp
Header
PINS
1
2
3
4
ALL
Note: Some lengths, styles
and options are non-standard,
non-returnable.
Leave
blank for
Through-hole
–RA
E
(6,35)
.250
01 thru 24
(1,14) .045
SQ TYP
C
–01
–02
(3,18)
.125
–04
–05
NO. OF
PINS
B
(4,45)
.175
(3,96)
.156
(12,07)
.475
C
(10,46)
.412
(11,73)
.462
(19,10)
.752
D
D
E
F
(4,45)
.175
(3,96)
.156
(8,13)
.320
(13,56)
.534
(2,54)
.100
(4,95)
.195
*FWJ Only
No. of Positions x (3,96) .156
JW
A
(11,43)
.450
(12,70)
.500
(20,55)
.809
(3,81)
.150
F
(2,54)
.100
(1,02) .040
B
LEAD
STYLE
(3,96)
.156
TYP
= Right Angle
(Style –02 &
–04 only)
Specify LEAD STYLE
from chart below.
A
RECOGNITIONS
Mates with:
FHP
= Matte Tin
(0,51)
.020
Lead–Free Solderable:
FWJ = Wave only
HFWJ = Yes
SMT Lead Coplanarity:
(0,20 mm) .008" max (02-16)
(0,25 mm) .010" max (17-24)
For complete scope of
recognitions see
www.samtec.com/quality
–T
FHP/HFWJ
CURRENT RATING
(PER CONTACT)
13.1 A
11.2 A
10.3 A
9.2 A
6.7 A
04
PLATING
OPTION
S
STACK
HEIGHT
POST
HEIGHT
SPECIFICATIONS
For complete specifications and
recommended PCB layouts see
www.samtec.com?JW
Insulator Material:
Natural Liquid Crystal Polymer
Terminal Material:
Phosphor Bronze
Plating:
RoHS Compliant: Yes
–T
Note:
This Series is
non-standard,
non-returnable.
= Matte Tin
02 thru 24
Lead–Free Solderable: Yes
recognitions see
–“XXX”
(3,96)
.156
TYP
POST
HEIGHT
(0,00)
.000
MIN
STACKER
HEIGHT
(27,43) 1.080
MAX WITH
(0,00) .000 POST
(6,35) .250
(3,18)
MIN
.125
(2,29)
.090
STACKER
HEIGHT
(29,21) 1.15
MAX WITH
(0,00) .000 POST
(8,89) .350
MIN
(1,14) .045 SQ
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
–P
= Pick & Place
Pad (3 Pos. min.)
(6,98 mm) .275"
min. post height
(–VS only)
OTHER
OPTION
Leave
blank for
Through-hole
–VS
Example: –250 = (6,35 mm) .250"
Processing:
RECOGNITIONS
–“XXX”
= Stacker Height
(in inches) (0,13 mm) .005" increments
–VS
= Surface Mount
Requires HFWJ
(2 pins/row
minimum)
Style –05
not available.
= Post Height
(in inches)
= Surface
Mount
(2 pins/row
minimum)
–P
= Pick &
Place Pad
(3 Pos. min.)
(6,98 mm)
.275" min.
post height
(–VS only)
