IPBT-108-H1-T-D
IPBT-108-H1-T-D
    SAMTEC(申泰)
IPBT-108-H1-T-D 数据手册
F-214 (Rev 17MAR14) IPBT–105–H2–T–D–K IPBT–108–H1–T–D–RA–K IPBT–105–H1–T–D–GP (4,19 mm) .165" IPBT SERIES ISOLATED TERMINAL POWER HEADER SPECIFICATIONS For complete specifications see www.samtec.com?IPBT Insulator Material: Black Liquid Crystal Polymer Contact Material: High Copper Alloy Plating: Sn over 50µ" (1,27 µm) Ni Operating Temp Range: -55°C to +105°C Voltage Rating: 400 VAC/565 VDC RoHS Compliant: Yes Lead–Free Solderable: Yes RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality Latching mechanism for mating with IPBD Series Mates with: IPBS, IPBD, PMSD, PMSS PINS POWERED 2 4 6 8 30 Keyed Polarization IPBT/IPBS CURRENT RATING (PER CONTACT) 9.3 A 7.4 A 6.4 A 5.9 A 4.4 A • Individually shrouded contacts Individually shrouded pins • Polarized guide post hole option FILE NO: 090871_0_000 APPLICATION LEAD STYLE NO. OF POSITIONS PER ROW 1 IPBT ROW OPTION PLATING OPTION OPTION IPBS MATED HEIGHT 02, 03, 04, 05, 08, 10, 15 IPBT –S = Single Row = Double Row (–S only) (Standard sizes) IPBT/IPBS MATED LEAD STYLE HEIGHT* (15,25) .600 (16,84) .663 –RA = Right Angle (Lead Style –H1 only) –D = Surface Mount 02, 03, 04, 05, 08, 10 –H2/–02 –T = Matte Tin –H2 (–D only) H1/–01 –H1 = Through-Hole (10,29) .405 (9,65) .380 –GP (3,30) .130 *Processing conditions will affect mated height. –H1–D (1,14) .045 SQ –H1–S (11,43) .450 No. of Positions x (4,19) .165 + (1,33) .052 ALSO AVAILABLE 01 (MOQ Required) (11,40) .449 • Other sizes • Other lead styles Contact Samtec. 15 02 (6,58) .259 (9,60) (1,27) .378 .050 16 –H2–S (4,19) .165 (15,62) .615 –H2–D (5,51) .217 16 –H1–S–RA (3,43) .135 DIA (3,73) .147 15 02 (6,58) .259 (1,52) .060 Note: Some lengths, styles and options are non-standard, non-returnable. 01 –K = Keyed Polarization (not available with -GP option, is required callout if -GP not called out) 30 No. of Positions x (4,19) .165 + (12,27) .483 No. of Positions x (4,19) .165 + (6,10) .240 (3,73) .147 = Guide Post Holes (8 positions not available) (10,77) .424 (5,21) .205 –GP OPTION WWW.SAMTEC.COM (1,52) .060 30 (4,06) .160 –H1–D–RA
IPBT-108-H1-T-D 价格&库存
很抱歉,暂时无法提供与“IPBT-108-H1-T-D”相匹配的价格&库存,您可以联系我们找货
