F-215 (Rev 31JUL15)
IPBT–105–H2–T–D–K
IPBT–108–H1–T–D–RA–K
IPBT–105–H1–T–D–GP
(4.19 mm) .165"
IPBT SERIES
ISOLATED TERMINAL POWER HEADER
SPECIFICATIONS
For complete specifications
see www.samtec.com?IPBT
Insulator Material:
Black Liquid Crystal Polymer
Contact Material:
High Copper Alloy
Plating:
Sn over 50µ" (1.27 µm) Ni
Operating Temp Range:
-55°C to +105°C
Voltage Rating:
400 VAC/565 VDC
RoHS Compliant:
Yes
Lead–Free Solderable:
Yes
RECOGNITIONS
For complete scope
of recognitions see
www.samtec.com/quality
Latching
mechanism
for mating
with IPBD
Series
Mates with:
IPBS, IPBD,
PMSD, PMSS
PINS
POWERED
2
4
6
8
30
Keyed
Polarization
IPBT/IPBS
CURRENT RATING
(PER CONTACT)
10.3 A
8.4 A
7.6 A
7.1 A
6.0 A
• Individually
shrouded contacts
Individually
shrouded pins
• Polarized guide
post hole option
FILE NO: 090871_0_000
APPLICATION
LEAD
STYLE
NO. OF POSITIONS
PER ROW
1
IPBT
ROW
OPTION
PLATING
OPTION
OPTION
IPBS
MATED
HEIGHT
02, 03, 04, 05, 08, 10, 15
IPBT
–H1
–T
–S
= Through-Hole
= Matte
Tin
= Single
Row
–H2
(–D only)
–D
= Surface Mount
= Double
Row
(–S only)
IPBT/IPBS
MATED
LEAD STYLE HEIGHT*
H1/–01
–H2/–02
–GP
= Guide
Post Holes
(8 positions
not available)
(Standard sizes)
(15.25)
.600
(16.84)
.663
(10.29)
.405
*Processing conditions
will affect mated height.
(9.65)
.380
(3.30)
.130
–H1–D
(1.14) .045 SQ
–H1–S
(11.43)
.450
No. of Positions x (4.19) .165 + (1.33) .052
ALSO AVAILABLE
(MOQ Required)
01
(11.40)
.449
• Other sizes
• Other lead styles
Contact Samtec.
15
02
(6.58)
.259
(9.60) (1.27)
.378 .050
16
–H2–S
(4.19)
.165
(15.62)
.615
(3.73) .147
01
–H2–D
(5.51)
.217
16
–H1–S–RA
(3.43)
.135 DIA
(3.73) .147
15
02
(6.58)
.259
(1.52)
.060
–K
= Keyed
Polarization
(not available
with -GP
option, is
required
callout if -GP
not called out)
30
No. of Positions x (4.19) .165 + (12.27) .483
No. of Positions x (4.19) .165 + (6.10) .240
Note: Some lengths, styles
and options are non-standard,
non-returnable.
–RA
= Right Angle
(Lead Style
–H1 only)
(10.77)
.424
(5.21)
.205
(1.52)
.060
30
(4.06) .160
–GP OPTION
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
–H1–D–RA
很抱歉,暂时无法提供与“IPBT-115-H4-T-D-GP”相匹配的价格&库存,您可以联系我们找货
