Emboss Tape
PB CONNECTOR
Specifications –––––––––––––––––––
Connector for button batteries used in the
compact mobile equipment such as mobile
phones. Mounting cost will be reduced by
using this connector in place of manual
soldering. And, button batteries can be
more easily disassembled after use for
recycling's sake.
• Applicable batteries: 614 type battery (φ6.8 mm × 1.4 height)
621 type battery (φ6.8 mm × 2.1 height)
• Temperature range: -25˚C to +85˚C
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/ 100 mΩ max.
After environmental tests/ 120 mΩ max.
• Insulation resistance: 1,000 MΩ min.
• Withstanding voltage: 500 VAC/minute
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
* Compliant with RoHS.
Standards ––––––––––––––––––––––
• Resistant to the shock
• Double contact point
Recognized E60389
Connector
614 type
0.8
2
0.65
6.7
Type
Holder part
614
Resin hook
621
Resin hook
Model No.
PB-614SS13-TF
PB-621SR13-TF
Q'ty / reel
2,000
2,000
Material and Finish
Contact: Copper alloy, nickel-undercoated, gold-plated
Housing: Glass-filled LCP, UL94V-0, natural (ivory)
0.8
0.65
9
4.75
RoHS compliance
※The dimension should be
measured from housing
bottom suface.
621 type
0.8
2.8
0.65
6.7
PB-614SS13-TF
PB-621SR13-TF
1.4 ±0.05
9
4.75
NEGATIVE(-)
8.6 ±0.05
10.8 ±0.05
Pattern prohibition area
0.8
0.65
POSITIVE(+)
bottom suface.
Note: The above figure is the figure viewed from the connector mounting side.
1
很抱歉,暂时无法提供与“PB-614SS13-TF”相匹配的价格&库存,您可以联系我们找货
