25
(0.50 mm) .0197" PITCH • QTH/QSH SERIES
QTH
Board Mates:
QSH
QTH
QSH
–030, –060,
–090
Board Mates:
QTH
–020, –040,
–060
Cable Mates:
HQCD, HQDP
Standoffs:
SO
LEAD
STYLE
Insulator Material:
Liquid Crystal Polymer
Contact Material:
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Current Rating:
Contact:
2 A per pin (2 pins powered)
Ground Plane:
25 A per ground plane
(1 ground plane powered)
Operating Temp Range:
-55 °C to +125 °C
Voltage Rating:
175 VAC (5 mm Stack Height)
Max Cycles:
100
–F
= Gold flash
on contact,
Matte Tin on tail
–L
–D
A
HEIGHT
WITH QSH*
–01
(4.27) .168
(5.00) .197
–02
(7.26) .286
(8.00) .315
–03
(10.27) .404
(11.00) .433
–04
(15.25) .600
(16.00) .630
–05
(18.26) .718
(19.00) .748
–07
(24.24) .954
(25.00) .984
–09
(13.26) .522
(14.00) .551
OTHER
OPTIONS
A
TYPE
–K
= SingleEnded
–D-DP
= Differential
Pair
(–01 only)
–TR
=Tape & Reel
(Not available
with –05 & –07
lead style)
–FR
–L
= Full Reel
Tape & Reel
(must order max.
quantity per reel;
contact Samtec
for quantity
breaks)
(Not available
with –05 & –07
lead style)
= Latching
Option
(–01 lead
style only)
(Not available
on –060 (–D–DP)
& –090)
= 50 µ" (1.27 µm)
Electro-Polished
Selective Gold
on contact,
Matte Tin on tail
(passes 10 year
MFG testing)
”X”R
Leave blank for
Tray Packaging
= (7.00 mm)
.275" DIA
Polyimide film
Pick &
Place Pad
(Not available
with -05 & -07
lead style)
–C
QTH
LEAD
STYLE
–D = (No. of Pins per Row/30) x (20.00) .7875
–DP = (No. of Pairs per Row/20) x (20.00) .7875
(20.00) .7875
(7.11)
.280
(0.76)
.030
A
A
*Processing conditions will affect
mated height. See SO Series for board
space tolerances.
–01 & –02
–03 THRU –09
View complete specifications at: samtec.com?QTH
PROCESSING
QSH
PINS PER ROW
NO. OF PAIRS
–F
= Gold flash
on contact, Matte
Tin on tail
(60 total pins per
bank = –D)
–L
–020, –040,
–060
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
(20 pairs per bank
= –D–DP)
TYPE
–D
= SingleEnded
–D–DP
= Differential
Pair
–C
PISMO™ 1:
Visit samtec.com/standards
for more information.
(20.00) .7875 + (1.27) .050
10 YEAR MFG
PLATING
OPTION
01
–030, –060,
–090
STANDARDS
= 50 µ" (1.27 µm)
Electro-Polished
Selective Gold
on contact,
Matte Tin on tail
(passes 10 year
MFG testing)
- A
OTHER
OPTIONS
–K
= (8.25 mm)
.325" DIA
Polyimide film
Pick & Place Pad
–L
= Latching
Option
(Not available on
–060 (–D–DP)
& –090)
”X”R
Leave blank for
Tray Packaging
–TR
=Tape & Reel
(N/A –05 to –07
lead style)
–FR
= Full Reel
Tape & Reel
(must order max.
quantity per reel;
contact Samtec
for quantity
breaks) )
(20.00) .7875
EXTENDED LIFE
PRODUCT
HIGH MATING
CYCLES
PLATING
OPTION
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
(20 pairs per bank
= –D–DP)
SPECIFICATIONS
Specify
LEAD
STYLE
from
chart
(60 total pins per
bank = –D)
QTH/QSH
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max
(030-060)
(0.15 mm) .006" max (090)*
*(.004" stencil solution may
be available; contact
ipg@samtec.com)
Board Stacking:
For applications requiring
more than two connectors
contact ipg@samtec.com
PINS PER ROW
NO. OF PAIRS
(7.49)
.295
(7.24)
.285 (0.76)
.030
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
(3.05)
.120
(3.25)
.128
View complete specifications at: samtec.com?QSH
samtec.com/QSeries
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
F-224
QTH-100-03-L-D-DP-A 价格&库存
很抱歉,暂时无法提供与“QTH-100-03-L-D-DP-A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 24+233.3592824+30.16417
