SEAM-20-01-L-08-2-RA-TR
    SAMTEC(申泰)
    SEAM .050 PITCH TERMINAL ARRAY A
SEAM-20-01-L-08-2-RA-TR 数据手册
HIGH-DENSITY OPEN-PIN-FIELD ARRAYS (1.27 mm) .050" PITCH FEATURES & BENEFITS • Maximum grounding & routing flexibility • Up to 560 Edge Rate® contacts optimized for signal integrity performance. 10 YEAR MFG WITH 30 µ" GOLD • 7 mm to 40 mm stack heights • Variety of designs and options: Right-Angle, Guide Posts, 85 Ω Elevated Risers, 85 Ω Tuned, Press-Fit and Press-Fit Right-Angle, Guide Post Field Termination Kits • Cable mates (SEAC Series) and Jack Screw Standoffs (JSO Series) also available EXTENDED LIFE PRODUCT HIGH MATING CYCLES Solder Charges MAXIMUM GROUNDING & ROUTING FLEXIBILITY • Standards: VITA 47, VITA 57.1 FMC, VITA 57.4 FMC+, VITA 74 VNX, PISMO™ 2 • Supports high-speed protocols such as Ethernet, PCI Express®, Fibre Channel & InfiniBand™ • Severe Environment Testing qualified (SEAM/SEAF); aligns with MIL-DTL-55302. Visit samtec.com/set SERIES INSULATOR MATERIAL CONTACT MATERIAL SEAM/SEAF Black LCP Copper Alloy SEAM-RA/SEAF-RA Black LCP SEAM-GP (1.12 mm) .044" Nominal Wipe Single-Ended Power CURRENT RATING VOLTAGE RATING LEAD-FREE SOLDERABLE Au or Sn over 50 µ" -55 °C to +125 °C (1.27 µm) Ni 2.7 A (10 pins powered) 240 VAC Yes Copper Alloy Au or Sn over 50 µ" -55 °C to +125 °C (1.27 µm) Ni 1.9 A (10 pins powered) 260 VAC Yes Black LCP Copper Alloy Au or Sn over 50 µ" -55 °C to +125 °C (1.27 µm) Ni 2.7 A (10 pins powered) 240 VAC Yes SEAMP/SEAFP Natural High Temp Nylon Copper Alloy (SEAMP) BeCu Alloy (SEAFP) Au or Sn over 50 µ" -55 °C to +125 °C (1.27 µm) Ni 1.9 A (6 pins powered) 225 VAC Not Available SEAR Black LCP Hard Gold Plated Contact Samtec 240 VAC Not Available SEAMI Black LCP Copper Alloy Not Available Not Available Yes PLATING Au over 50 µ" (1.27 µm) Ni OPERATING TEMP RANGE Differential Pair -55 °C to +125 °C Au or Sn over 50 µ" -55 °C to +125 °C (1.27 µm) Ni Note: Some lengths, styles and options are non-standard, non-returnable F-224 samtec.com/SEARAY Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. (1.27 mm) .050" PITCH • RIGHT-ANGLE & GUIDE POST - SERIES POSITIONS PER ROW SEAM - 01 - –20 Right-Angle Terminal SEAF –L –40 = 30 µ" (0.76 µm) Gold on contact area, Matte Tin on solder tail SEAM-RA - RA - SOLDER TYPE –04 –1 –08 -08 & -10 Row options require fixturing to process –K –LP   :LWKRXW²*3 1RRISRVLWLRQV[           SEAF-RA Board Mates: SEAM, SEAMP –FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) Latch Post (Available with SEAF in -06 Row with 30 positions only; Required for mating to SEAC) ²*3 1RRISRVLWLRQV[     Board Mates: SEAF, SEAF-RA, SEAFP = Tape & Reel = Polyimide Film Pick & Place Pad = Lead-Free Solder Charge "X"R –TR = Guide Post/Hole –2 –10 - OPTIONS –GP = Tin/Lead Alloy Solder Charge –06 –S –50 - NO. OF ROWS = 10 µ" (0.25 µm) Gold on contact area, Matte Tin on solder tail –30 Right-Angle Socket - PLATING OPTION B A –GP = No. of positions x (1.27) .050 + (19.56) 0.77 Without –GP = No. of positions x (1.27) .050 + (9.40) 0.37 NO.PINS PER ROW A –04 (13.77) .542 (7.91) .311 –06 (16.31) .642 (10.45) .411 B –08 (18.85) .742 (12.99) .511 –10 (21.39) .842 (15.53) .611 View complete specifications at: samtec.com?SEAM-RA & samtec.com?SEAF-RA SERIES - SEAM Terminal with Guide post SEAM-GP Board Mates: SEAF-RA-GP POSITIONS PER ROW –20, –30, –40, –50 - 02.0 - PLATING OPTION - NO. OF ROWS –L –04 –S –08 = 10 µ" (0.25 µm) Gold on contact area, Matte Tin on solder tail = 30 µ" (0.76 µm) Gold on contact area, Matte Tin on solder tail - SOLDER TYPE –1 –06 = Tin/Lead Alloy Solder Charge –10 = Lead-Free Solder Charge –2 No. of positions x (1.27) .050 + (19.46) .766 (12.65) .498 - A - GP - K - "X"R –TR = Tape & Reel –FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) (5.54) .218 View complete specifications at: samtec.com?SEAM Note: Some lengths, styles and options are non-standard, non-returnable samtec.com/SEARAY Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-224
SEAM-20-01-L-08-2-RA-TR 价格&库存
很抱歉,暂时无法提供与“SEAM-20-01-L-08-2-RA-TR”相匹配的价格&库存,您可以联系我们找货
