F-218 (Rev 05OCT17)
SMM–135–02–L–D–K
SMM–108–02–L–S
SMM–115–02–S–D
SMM–110–02–L–S
(2.00 mm) .0787"
SMM SERIES
TIGER EYE SOCKET STRIP
Available with optional
Pick & Place Pads
Board Mates:
TMM, TMMH, MTMM, MMT,
LTMM, TW, PTT, ZLTMM
SPECIFICATIONS
For complete specifications and
recommended PCB layouts
see www.samtec.com?SMM
High-reliability
Tiger Eye™ contacts
(Four point redundancy)
Cable Mates:
TCMD
Insulator Material:
Black Liquid Crystal Polymer
Contact Material:
BeCu
Plating: Sn or Au over
50 µ" (1.27 µm) Ni
Current Rating (TMM/SMM):
3.2 A per pin
(2 pins powered)
Voltage Rating:
350 VAC
Operating Temp Range:
-55 °C to +125 °C
Insertion Depth:
(3.05 mm) .120" to
(3.25 mm) .128"
Max Cycles:
100 with 10 µ" (0.25 µm) Au
RoHS Compliant:
Yes
10 YEAR MFG
WITH 30 µ" GOLD
(3.56 mm)
.140"
EXTENDED LIFE
PRODUCT
HIGH MATING
CYCLES
(2.00 mm)
.0787" pitch
PROCESSING
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max
SMM
1
NO. PINS
PER ROW
02
PLATING
OPTION
ROW
OPTION
OTHER
OPTION
RECOGNITIONS
For complete scope of
recognitions see
www.samtec.com/quality
–F
= Gold flash
on contact,
Matte Tin on tail
02 thru 40
–L
FILE NO. E111594
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
No. of positions x (2.00) .0787
ALSO AVAILABLE
• Locking clip
(Manual placement required)
• Other platings
Contact Samtec.
(2.00)
.0787
01
POLARIZING KEY
= 30 µ" (0.76 µm)
Gold on contact,
Matte Tin on tail
(2.00)
.0787
–S Row
(3.81) .150
x (7.62) .300
–D Row
(5.71) .225
x (10.01) .394
80
(2.00) (4.00)
.0787 .158
79
(3.56)
.140
(0.51)
.020
(4.32)
.170
(6.30)
.248
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
–K
= (5.50 mm)
.217" DIA
Polyimide
Film
Pick &
Place Pad
(2 positions
minimum,
–02 thru –05
requires –TR)
–P
–TR
–P
01
(0.38)
.015
–“XX”
= Polarized
Position
= Plastic Pick
& Place Pad
(–02 thru –05
requires –TR)
02
Specify PK–01–07 for polarizing
key (Available in wheels of six
each). Also polarizes TCSD Series
IDC Cable.
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
–D
= Double
Row
–S
40
(MOQ Required)
–S
= Single
Row
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
= Tape & Reel
Packaging
(27 positions
maximum)
很抱歉,暂时无法提供与“SMM-112-02-L-S-09”相匹配的价格&库存,您可以联系我们找货
