SSM-117-L-SV-BE-LC-P-TR 数据手册
TIGER CLAW™ SURFACE
MOUNT SOCKET
8
G b p s
(2.54 mm) .100" PITCH • SSM SERIES
SSM
Mates:
TSW, MTSW,
TST, TSS, ZST, ZSS,
DW, EW, ZW, TSM,
HMTSW, HTSW, TSSH,
BST, HTSS, TLW, MTLW
SSM
1
PROCESSING
Lead–Free Solderable:
Yes
–DH Coplanarity:
Less than 28 positions
(0.15 mm) .006" max*
More than 27 positions
(0.20 mm) .008" max*
–SH, –SV, –DV Coplanarity:
*(.004" stencil solution
may be available; contact
ipg@samtec.com)
ALSO AVAILABLE
MOQ Required
Alignment pin
PLATING
OPTION
02 thru 36
–F
(–SV, – SH, –DH)
(–DV)
= Single Row
Vertical Pin
–DV
–L
= Double Row
Vertical Pin
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
–SH
= Single Row
Horizontal Pin
–S
= 30 µ" (0.76 µm)
Gold on contact,
Matte Tin on tail
[1RRI3RVLWLRQV
–DH
= Double Row
Horizontal Pin
ROW
OPTION
–SV
= Gold flash
on contact,
Matte Tin on tail
02 thru 40
SPECIFICATIONS
Insulator Material:
Black Liquid Crystal Polymer
Contact Material:
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Current Rating (SSM/TSW):
5.2 A per pin
(2 pins powered)
Voltage Rating:
405 VAC / 572 VDC
Operating Temp Range:
-55 °C to +125 °C with Gold
-55 °C to +105 °C with Tin
Insertion Depth:
SV/DV = (4.34 mm) .171" to
(7.24 mm) .285" or pass-through
from top; (5.56 mm) .219"
plus board thickness minimum
from bottom;
SH/DH = (4.34 mm) .171" to
(6.35 mm) .250"
NO. PINS
PER ROW
—SH
OTHER
OPTION
–“XXX”
= Polarized Position
(–BE not available)
–BE
= Bottom Entry
(–DV & –SV only)
–LC
= Locking Clip
(–DV & –SV only)
Contact Samtec for
–DH & –SH
–K
= (6.50 mm) .256" DIA
Polyimide film
Pick & Place Pad
(2 positions min.)
–DV & –SV only
–M
= Metal Pick
& Place Pad
(5 positions min.)
–DV only
—DH
–P
= Plastic Pick
& Place Pad
(–DV & –SV only)
(6 positions min.
Contact Samtec
for availability on
smaller positions)
–TR
= Tape & Reel
(29 positions max.)
–FR
= Full Reel
Tape & Reel
(must order max.
quantity per reel;
contact Samtec for
quantity breaks)
(29 positions max.)
[1RRI3RVLWLRQV
—SV
10 YEAR MFG
WITH 30 µ" GOLD
EXTENDED LIFE
PRODUCT
HIGH MATING
CYCLES
Notes:
Severe Environment
Testing qualified; aligns
with MIL-DTL-55302.
Visit samtec.com/set
Some sizes, styles and
options are non-standard,
non-returnable.
F-224
[1RRI3RVLWLRQV
—DV
—LC
—P
—M
samtec.com?SSM
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
SSM-117-L-SV-BE-LC-P-TR 价格&库存
很抱歉,暂时无法提供与“SSM-117-L-SV-BE-LC-P-TR”相匹配的价格&库存,您可以联系我们找货
