XLR-08V
XLR-08V
    JST
    P=5mm
    线对板针座
XLR-08V 数据手册
XL CONNECTOR 5.0mm pitch/Disconnectable Crimp style Wire-to-wire connectors Specifications ––––––––––––––––––– • Current rating: 10A AC, DC max. • Voltage rating: 300V AC, DC max. • Temperature range: -25˚C to +90˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/7m Ω max. After environmental testing/10m Ω max. • Insulation resistance: 1,000M Ω min. • Withstanding voltage: 1,500V AC/minute • Applicable wire: AWG #26 to #16 0.13 to 1.25mm2 • Applicable panel thickness: 0.7 to 2.4mm * Compliant with RoHS. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. Note: The current rating varies depending on the number of circuits and the wire size used in each connector. The table below lists the current rating as a function of the number of circuits and wire size. Current unit: A Wire size (AWG) Circuits XL connectors are reliable wire-to-wire connectors, used for such electrical and electronic equipment as home appliances, vending machines, and office machines. #16 #18 #20 #22 #24 #26 2 10 6 5 4 3 3 4 9 5 4 3 3 2 8 6 4 3 3 2 2 12 6 4 3 3 2 2 16 5 3 2 2 1 1 Standards –––––––––––––––––––––– • Reliable housing construction • Easy contact insertion • Box-shaped contact • Two kinds of connections 0 Recognized E60389 1 Certified LR20812 2 R75052 Panel layout and Assembly layout 17.7 30.9 Shape I Shape II 6.5 B B Circuits 2 D C D C 7.8 4 8 2.7 12 A A 16 Receptacle housing Panel Panel hole dimensions (mm) General tolerance ±0.13 Applicable panel hole thickness (mm) A B C D shape XLR-02V XLR-04V XLR-08V XLR-12V XLR-16V 1 11.5 4.4 13.95 13.2 2 16.5 5.2 13.95 13.2 2 26.5 5.2 13.95 13.2 2 36.5 5.2 13.95 13.2 2 46.5 5.2 13.95 13.2 0.7∼2.4 Note: 1. Punch holes in the panel according to the figures and table shown above. Burrs must be removed. 2. The strength of the panel must be considered when punching two or more holes. 3. The connector must be inserted from the same side as the hole is punched. 1 XL CONNECTOR Contact Applicable wire Model No. Pin contact 1.85 Pin contact AWG # SYM-01T-P0.7 SXF-01T-P0.7 0.13∼0.5 SYM-41T-P0.7 SXF-41T-P0.7 18.4 1.2 2.5 26∼20 0.5 ∼1.25 20∼16 0.3+0.3∼ 0.5+0.5 22+22∼ 20+20 Insulation O.D. Q'ty / reel (mm) Pin contact SYM-01T-P0.7    :6,000 SYM-41T-P0.7 1.9∼3.1    :4,000 Socket 1.7+1.7∼ contact: 2.0+2.0    :3,000 1.3∼2.7 Material and Finish 0.65 1.1 mm2 Socket contact Phosphor bronze, tin-plated (reflow treatment) RoHS compliance Note: 1. Contact JST for special products. 2. Contact JST for brass products. Socket contact 3.0 SYM-01T-P0.7 12.0 4.0 2.5 1.2 SXF-01T-P0.7 1.1 AP-K2N SYM-41T-P0.7 3.35 Applicator Dies Crimp applicator with dies MKS-L MK/SYM-01-07 APLMK SYM01-07 − − − MKS-L MK/SXF-01-07 APLMK SXF01-07 Crimping machine Crimp applicator Contact SXF-41T-P0.7 − − − MKS-L MK/SYM-41-07 APLMK SYM41-07 − − − MKS-L MK/SXF-41-07 APLMK SXF41-07 − − − Contact position location numbers Contact position numbers are stamped Receptacle housing Plug housing Receptacle housing Plug housing 8 16 8 16 14 6 12 11 10 10 2 11 3 12 JST 4 4 JST 13 2 4 1 3 13 1 3 JST 2 1 JST 14 1 1 2 5 4 2 7 15 JST 3 1 4 2 3 1 15 2 4 JST 2 2 1 6 9 7 1 11 10 8 7 9 2 3 JST 8 7 6 5 1 6 5 4 3 2 1 4 8 7 4 3 8 7 6 5 4 3 2 1 2 JST 8 1 16 15 14 13 12 11 10 9 1 3 9 JST 5 6 5 4 3 2 1 JST 10 2 6 2 12 11 10 9 8 7 5 1 11 7 4 3 2 1 9 12 1 6 12 4 8 8 7 6 5 6 5 4 3 2 1 12 11 10 9 8 7 8 7 6 5 4 3 2 1 16 15 14 13 12 11 10 9 XL CONNECTOR Housing Material: PA 66, UL94V-0, white Circuits Voltage rating Current rating Receptacle housing(for pin contact) XLR-02V XLP-02V Q'ty / bag 10A 6.2 300V Q'ty / bag 6.2 2 Plug housing(for socket contact) 500 25.4 XLR-04V 9A XLP-04V Q'ty / bag 11.2 300V 18.7 11.2 4 Q'ty / bag 500 25.4 Q'ty / bag 500 18.7 XLP-08V Q'ty / bag 21.2 6A 12.35 21.2 300V 5.5 12.9 XLR-08V 8 500 5.5 12.35 12.9 500 500 5.5 25.4 XLR-12V 6A XLP-12V Q'ty / bag 31.2 300V Q'ty / bag 18.7 31.2 12 12.35 12.9 200 200 5.5 25.4 12.9 XLR-16V 5A XLP-16V Q'ty / bag 41.2 300V Q'ty / bag 18.7 41.2 16 12.35 100 200 5.5 25.4 12.9 12.35 18.7 RoHS compliance Note: 1. XL connectors with any number of circuits can be used either panel mounted or free hanging. See "Panel layout" for the hole dimensions. 2. Contact JST for special products. 3
XLR-08V 价格&库存
很抱歉,暂时无法提供与“XLR-08V”相匹配的价格&库存,您可以联系我们找货
XLR-08V
    库存:429
    XLR-08V
      • 1+2.237681+0.29041
      • 10+2.1593210+0.28024
      • 50+1.6107950+0.20905
      • 100+1.24509100+0.16159
      • 500+1.17544500+0.15255
      • 1000+1.123201000+0.14577
      • 2000+1.097082000+0.14238
      库存:257
      XLR-08V
      • 500+2.19796
      • 1000+1.92726
      • 2500+1.56433
      • 5000+1.49006
      XLR-08V
      • 500+2.73918500+0.35550
      XLR-08V
        • 500+1.09920
        库存:2000
        XLR-08V
          • 1+1.723981+0.22374
          • 100+1.60208100+0.20792
          • 300+1.23639300+0.16046
          • 500+1.16673500+0.15142
          • 1000+1.114491000+0.14464
          • 4000+1.070964000+0.13899
          库存:2
          XLR-08V
            • 1+1.637781+0.21256
            • 100+1.52197100+0.19753
            • 300+1.17457300+0.15244
            • 500+1.10840500+0.14385
            • 1000+1.058771000+0.13741
            • 4000+1.017414000+0.13204
            • 5000+1.017415000+0.13204
            库存:2766
