YTE-140-03-M-Q-340
YTE-140-03-M-Q-340
    SAMTEC(申泰)
YTE-140-03-M-Q-340 数据手册
YTE–120–03–G–5–700 F-224 SUPPLEMENT YTE–110–02–G–6–500 YTE–114–03–M–Q–368 (2.00 mm) .0787" YTE SERIES HIGH-DENSITY ELEVATED SOCKET STRIP SPECIFICATIONS For complete specifications see www.samtec.com?YTE Mates with: YTT, YTW, YTE Body Height from (8.64 mm) .340" to (20.32 mm) .800" Insulator Material: Black Liquid Crystal Polymer Contact Material: Phosphor Bronze Operating Temp Range: -55 °C to +105 °C Plating: Sn or Au over 50 µ" (1.27 µm) Ni Insertion Depth: (2.62 mm) .103" to (5.03 mm) .198" with (0.38 mm) .015" wipe Max Cycles: 100 with 10 µ" (0.25 µm) Au RoHS Compliant: Yes Lead–Free Solderable: Wave only RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality FILE NO. E111594 OTHER SOLUTIONS (2.00 mm) .0787" pitch Paste In Hole (PIH) processing. (Not recommended for self-nesting.) Contact Samtec ASP Group. YTE 1 LEAD STYLE NO. PINS PER ROW Specify LEAD STYLE 02 thru 50 from chart PLATING OPTION —G = 20 µ" (0.51 µm) Gold (Recommended for self-nesting) —M = 20 µ" (0.51 µm) Gold on contact, Tin on tail 300 No. of positions x (2.00) .0787 + (0.30) .012 06 —F = Gold flash on contact, Tin on tail 01 (2.00) .0787 (6.35) .250 A Note: This Series is non-standard, non-returnable. (0.50) .020 SQ (2.00) .0787 —“XXX” = Body Height (in inches) (8.64 mm) .340" min. for —Q (9.53 mm) .375" min. for —5 & —6 —L = 10 µ" (0.25 µm) Gold on contact, Tin on tail No. of rows x (2.00) .0787 295 BODY HEIGHT ROW OPTION (2.00) .0787 BODY TAIL HEIGHT (1.27) .050 MIN OTHER OPTION –“XXX” =Polarized Position (Indicate position number) —Q = Quad Row —5 = Five Row —6 = Six Row LEAD STYLE A MAX MAX BODY TAIL HEIGHT (13.72) – 02 (21.59) .850 .540 (20.32) .800 (3.76) –03 (11.63) .458 .148 (10.36) .408 WWW.SAMTEC.COM Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
YTE-140-03-M-Q-340 价格&库存
很抱歉,暂时无法提供与“YTE-140-03-M-Q-340”相匹配的价格&库存,您可以联系我们找货
