231-232/001-000
231-232/001-000
    WAGO(万可电子)
    插件,P=7.5mm
    接线端子 1x2P 间距:7.5mm 排数:1 每排Pin数:2
231-232/001-000 数据手册
Male Headers with Solder Pins MCS MIDI Classic 6 445 630 V/6 kV/2 16 A >3,8< With 1 x 1 mm angled solder pins Pin spacing: 7.5 mm / 0.295 in. 630 V/6 kV/2 12A 300 V/10 A 4,1 7,5 >3,8< 7,5 (_10 _) 4,1 > 6,4 7,5 < 4,1 4,1 5 1 4,1 4,1 300 V/15 A (8,4) > 3,8< 7,5 > 5 300 V/10 A (8,4) > 3,8< 1 > 5 630 V/6 kV/2 12A With 1.2 x 1.2 mm straight solder pins Pin spacing: 7.5 mm / 0.295 in. >3,8 7,5 < With 1 x 1 mm straight solder pins Pin spacing: 7.5 mm / 0.295 in. L = (pole no. – 1) x pin spacing + 8.2 mm Pole No. Item No. L = (pole no. – 1) x pin spacing + 8.2 mm Pack. Unit Male header with 1 x 1 mm straight solder pins, gray Pole No. Item No. L = (pole no. – 1) x pin spacing + 8.2 mm L1 = L + 5 mm L2 = L1 + 7.4 mm Pack. Unit Male header with 1.2 x 1.2 mm straight solder pins, gray Pole No. Item No. Pack. Unit Male header with 1 x 1 mm angled solder pins, gray  2  3  4  5  6  7  8  9 10 11 12 13 231-232/001-000 231-233/001-000 231-234/001-000 231-235/001-000 231-236/001-000 231-237/001-000 231-238/001-000 231-239/001-000 231-240/001-000 231-241/001-000 231-242/001-000 231-243/001-000 200 200 100 100 100 50 50 50 50 50 50 50  2  3  4  5  6  7  8  9 10 11 12 13 231-262/001-000 231-263/001-000 231-264/001-000 231-265/001-000 231-266/001-000 231-267/001-000 231-268/001-000 231-269/001-000 231-270/001-000 231-271/001-000 231-272/001-000 231-273/001-000 200 200 100 100 100 50 50 50 50 50 50 50  2  3  4  5  6  7  8  9 10 11 12 13 231-832/001-000 231-833/001-000 231-834/001-000 231-835/001-000 231-836/001-000 231-837/001-000 231-838/001-000 231-839/001-000 231-840/001-000 231-841/001-000 231-842/001-000 231-843/001-000 200 200 100 100 100 50 50 50 50 50 50 50 16 231-246/001-000 50 16 231-276/001-000 50 16 231-846/001-000 50 1 M  CS MIDI male headers with straight solder pins are also available with 3.8 mm pin projection upon request. Replace item no. suffix: . . . /001-000 with . . . /046-000 for this. For other lengths, please contact factory. 6
231-232/001-000 价格&库存
很抱歉,暂时无法提供与“231-232/001-000”相匹配的价格&库存,您可以联系我们找货
