Data sheet | Item number: 235-403/331-000
PCB terminal block; push-button; 1.5 mm²; Pin spacing 5/5.08 mm; 3-pole;
Push-in CAGE CLAMP®; 1,50 mm²; gray
www.wago.com/235-403_331-000
Color:
L = (pole no. x pin spacing) + 1.5 mm
Item description
PCB terminal strips with push-buttons
Subject to changes.
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
29.12.2019 Page 1/10
Push-in terminations of solid and ferruled conductors
Convenient termination/removal of fine-stranded conductors via push-buttons
Set to metric or inch pin spacing by compressing terminal strips or pulling them apart
Data
Electrical data
Ratings per IEC/EN 60664-1
Rated voltage (III / 3)
250 V
Rated impulse voltage (III / 3)
4 kV
Rated voltage (III / 2)
320 V
Rated impulse voltage (III / 2)
4 kV
Rated voltage (II / 2)
630 V
Rated impulse voltage (II / 2)
4 kV
Rated current
17.5 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
Approvals per UL 1059
Rated voltage UL (Use Group B)
300 V
Rated current UL (Use Group B)
10 A
Rated voltage UL (Use Group D)
300 V
Rated current UL (Use Group D)
10 A
Approvals per CSA
Rated voltage CSA (Use Group B)
300 V
Rated current CSA (Use Group B)
15 A
Connection data
Connection technology
Push-in CAGE CLAMP®
Actuation type
Push-button
Solid conductor
0.2 … 1.5 mm² / 20 … 14 AWG
Fine-stranded conductor
0.75 … 1.5 mm² / 20 … 14 AWG
Fine-stranded conductor with ferrule with plastic collar
0.25 … 1 mm²
Fine-stranded conductor with ferrule without plastic collar
0.25 … 1 mm²
Strip length
9 … 10 mm / 0.35 … 0.39 inch
Conductor entry angle to the PCB
Subject to changes.
Hansastr. 27
32423 Minden
0 °
29.12.2019 Page 2/10
0 °
No. of poles
3
Total number of connection points
3
Total number of potentials
3
Number of connection types
1
Number of levels
1
Geometrical Data
Pin spacing
5/5.08 mm / 0.197/0.2 inch
Width
16.5 mm / 0.65 inch
Height
19.1 mm / 0.752 inch
Height from the surface
15.5 mm / 0.61 inch
Depth
12.5 mm / 0.492 inch
Solder pin length
3.6 mm
Solder pin dimensions
0.4 x 0.8 mm
Drilled hole diameter (tolerance)
1(- … +0.1) mm
PCB contact
PCB contact
THT
Solder pin arrangement
over the entire terminal strip, in line
Number of solder pins per potential
2
Material Data
Color
gray
Material group
I
Insulating material
Polyamide 66 (PA 66)
Flammability class per UL94
V0
Clamping spring material
Chrome nickel spring steel (CrNi)
Contact material
Electrolytic copper (ECu)
Contact plating
tin-plated
Fire load
0.043 MJ
Weight
2.4 g
Environmental Requirements
Limit temperature range
-60 … +105 °C
Commercial
data
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 3/10
Commercial data
Product Group
4 (Printed Circuit)
Packaging type
BOX
Country of origin
CN
GTIN
4055143258630
Customs Tariff No.
85369010000
Approvals / Certificates
Country specific Approvals
Logo
Certificate
name
Approval
Additional Approval Text
CCA
DEKRA Certification B.V.
EN 60947
NTR NL7144
CCA
EN 60998
NTR NL
6919
CCA
EN 60947
2149549.02
CCA
EN 60947-7-4
NTR NL7625
CSA
C22.2
1673956
VDE
VDE Prüf- und Zertifizierungsinstitut
EN 60947
40029328
Ship Approvals
Logo
Approval
ABS
American Bureau of Shipping
Certificate
name
19HG1869876PDA
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 4/10
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAE000016Z
UL-Approvals
Logo
Approval
UL
UL International Germany GmbH
Certificate
name
E45172
sec. 6
Compatible products
Marking accessories
Item no.: 210-332/500-202
www.wago.com/210-332
Marking strips; as a DIN A4 sheet; MARKED; 1-16 (160x); Height of marker strip: 3 mm; Strip length 182
/500-202
mm; Horizontal marking; Self-adhesive; white
Item no.: 210-332/500-204
Marking strips; as a DIN A4 sheet; MARKED; 17-32 (160x); Height of marker strip: 3 mm; Strip length
182 mm; Horizontal marking; Self-adhesive; white
/500-204
Item no.: 210-332/500-205
Marking strips; as a DIN A4 sheet; MARKED; 1-32 (80x); Height of marker strip: 3 mm; Strip length 182
/500-205
Item no.: 210-332/500-206
Marking strips; as a DIN A4 sheet; MARKED; 33-48 (160x); Height of marker strip: 3 mm; Strip length
/500-206
Item no.: 210-332/508-202
/508-202
Item no.: 210-332/508-204
/508-204
Item no.: 210-332/508-205
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 5/10
/508-205
Item no.: 210-332/508-206
/508-206
Item no.: 210-657
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; short
www.wago.com/210-657
Item no.: 210-720
www.wago.com/210-720
Item no.: 216-101
Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated
www.wago.com/216-101
Item no.: 216-102
Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated
www.wago.com/216-102
Item no.: 216-103
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated
www.wago.com/216-103
Item no.: 216-121
www.wago.com/216-121
Item no.: 216-122
www.wago.com/216-122
Item no.: 216-123
www.wago.com/216-123
Item no.: 216-131
Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated
www.wago.com/216-131
Item no.: 216-132
Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated
www.wago.com/216-132
Item no.: 216-141
Ferrule; Sleeve for 0.5 mm² / 20 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 1/08.92
www.wago.com/216-141
Item no.: 216-142
Ferrule; Sleeve for 0.75 mm² / 18 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-142
Item no.: 216-143
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-143
Item no.: 216-151
www.wago.com/216-151
tools
ferrule
Item no.: 216-152
Subject to changes.
Hansastr. 27
32423 Minden
www.wago.com/216-152
29.12.2019 Page 6/10
Item no.: 216-152
Item no.: 216-201
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white
www.wago.com/216-201
Item no.: 216-202
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray
www.wago.com/216-202
Item no.: 216-203
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red
www.wago.com/216-203
Item no.: 216-221
www.wago.com/216-221
Item no.: 216-222
www.wago.com/216-222
Item no.: 216-223
www.wago.com/216-223
Item no.: 216-241
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; white
www.wago.com/216-241
Item no.: 216-242
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; gray
www.wago.com/216-242
Item no.: 216-243
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243
acc. to DIN 46228, Part 4/09.90; red
Item no.: 216-262
www.wago.com/216-262
Item no.: 216-263
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-263
Item no.: 216-301
Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow
www.wago.com/216-301
Item no.: 216-302
Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green
www.wago.com/216-302
Item no.: 216-321
www.wago.com/216-321
Item no.: 216-322
www.wago.com/216-322
Downloads
Documentation
Additional Information
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 7/10
Technical explanations
Apr 3, 2019
pdf
3.6 MB
Download
URL
Download
CAD/CAE-Data
CAD data
2D/3D Models 235-403/331-000
CAE data
EPLAN Data Portal 235-403/331-000
Download
PCB Design
Symbol and Footprint 235-403/331-000
URL
Download
CAx data for your PCB design, consisting of "schematic symbols and PCB footprints",
allow easy integration of the WAGO component into your development environment.
Supported formats:
Accel EDA 14 & 15
Altium 6 to current version
Cadence Allegro
DesignSpark
Eagle Libraries
KiCad
Mentor Graphics BoardStation
Mentor Graphics Design Architect
Mentor Graphics Design Expedition 99 and 2000
OrCAD 9.X PCB and Capture
PADS PowerPCB 3, 3.5, 4.X, and 5.X
PADS PowerPCB and PowerLogic 3.0
PCAD 2000, 2001, 2002, 2004, and 2006
Pulsonix 8.5 or newer
STL
3D STEP
TARGET 3001!
View Logic ViewDraw
Quadcept
Zuken CadStar 3 and 4
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 8/10
Zuken CR-5000 and CR-8000
PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian
Installation Notes
Inserting a conductor
Inserting/removing fine-stranded
conductors via push-button.
conductors with ferrules via push-button.
Inserting solid conductors via push-in
termination
Combining 1- and 2-conductor terminal
blocks with different pin spacing.
Testing
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 9/10
Application example: field-wiring terminal
strip
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 10/10
很抱歉,暂时无法提供与“235-403/331-000”相匹配的价格&库存,您可以联系我们找货
