FHP-17-01-H-S
FHP-17-01-H-S
    SAMTEC(申泰)
    插件,P=3.96mm
    排母 间距:3.96mm 1x17P 插件
FHP-17-01-H-S 数据手册
F-218 FHP–17–01–T–S FHP–12–02–T–S (3.96 mm) .156" FHP SERIES POWER SOCKETS Surface Mount or Through-hole Mates with: FWJ, HFWJ, JW SPECIFICATIONS For complete specifications and recommended PCB layouts see www.samtec.com?FHP Insulator Material: Black LCP Contact Material: BeCu Plating: Sn over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +105 °C Voltage Rating: 600 VAC/845 VDC Insertion Depth: (3.57 mm) .140" to (8.76 mm) .345" or pass-through from top Wiping Distance: (0.38 mm) .015" Standard Creepage: (1.74 mm) .069" (without -LC) (0.89 mm) .035" (with -LC) Standard Clearance: (1.39 mm) .055" (without -LC) (0.59 mm) .023" (with -LC) RoHS Compliant: Yes PINS 1 2 3 4 24 (8.89 mm) .350" FHP/HFWJ CURRENT RATING (PER CONTACT) 13.1 A 11.2 A 10.3 A 9.2 A 6.7 A (3.96 mm) .156" pitch • Three-finger Power Eye contact • Locking clip option NO. OF PINS PER ROW FHP PROCESSING Lead–Free Solderable: Yes SMT Lead Coplanarity: (0.10 mm) .004" max LEAD STYLE PLATING OPTION –01 RECOGNITIONS –LC = Throughhole 02 thru 24 For complete scope of recognitions see www.samtec.com/quality = Locking Clip (Manual placement required) (–02 lead style only) –T = Matte Tin (1.19) .047 –02 = Surface Mount FILE NO. E111594 –K (1.01) .040 CREEPAGE AND CLEARANCE No. of Positions x (3.96) .156 (5.08) .200 (3.96) .156 Selectively loading contacts achieves customer specific creepage and clearance requirements. Contact asp@samtec.com (0.46) .018 (MOQ Required) Note: Some lengths, styles and options are non-standard, non-returnable. (0.94) .037 (1.42) .056 (2.46) .097 (9.35) .368 (1.14) .045 (7.11) .280 –02 –01 Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply. = (6.50 mm) .256" DIA Polyimide film Pick & Place Pad (2-4 positions require –TR) (–02 lead style only) –TR –LC (8.89) .350 (2.59) .102 ALSO AVAILABLE • Alignment pins Contact Samtec. OTHER OPTION S = Tape & Reel Packaging (Available on positions 2-18) –02 lead style only
FHP-17-01-H-S 价格&库存
很抱歉,暂时无法提供与“FHP-17-01-H-S”相匹配的价格&库存,您可以联系我们找货
