IPBD-08-D-K-M
IPBD-08-D-K-M
    SAMTEC(申泰)
    Conn Housing RCP 16 POS 4.19mm Crimp ST Cable Mount Power Mate® Bulk
IPBD-08-D-K-M 数据手册
(4.19 mm) .165" PITCH • DISCRETE WIRE CABLE & COMPONENTS - SERIES PMSD = Double Row PVC Cable PMSDT = Double Row Blue *Teflon™ Fluoropolymer Cable (24 AWG only) PMSS = Single Row PVC Cable - PINS PER ROW —02, —03, —04, —05, —08, —10, —15* (Standard sizes) *Only available for double row WIRE GAUGE - –16 K –K = Keyed Polarization –18 –206 - ASSEMBLED LENGTH - END OPTION –"XX.XX" - –S = Wire length in inches (88.90 mm) 03.50" min. –LUS = Single Ended = Plastic Latch up, straight –D = Plastic Latch down, straight –LDS = Double Ended (Latch Required) (20 AWG/ 600 volts) –22 –LUX* = Plastic Latch up, crossed –LDX* –24 PMSST = Single Row Blue *Teflon™ Fluoropolymer Cable (24 AWG) PMSD, PMSDT, PMSS, PMSST = Plastic Latch down, crossed *(PMSD/PMSDT only) PMSD/IPBT CURRENT RATING (PER PIN) WIRE GAUGE No. of Positions x (4.19) .165 + (1.02) .040 Board Mates: IPBT (7.95) .313 Assembled Length ± (3.18) .125 PMSS/PMSST SPECIFICATIONS Insulator Material: Valox 457 Contact Material: Phosphor Bronze Plating: Sn over 50 µ" (1.27 µm) Ni Operating Temp Range: -10 °C to +105 °C (PVC) -40 °C to +105 °C (Teflon™ Fluoropolymer) LATCH OPTION No. of Positions x (4.19) .165 + (1.02) .040 16 AWG *10.3 A 18 AWG *8.8 A 22 AWG *5.7 A 24 AWG *5.2 A VOLTAGE RATING 424 VAC/600 VDC (PVC) 300 VAC/424 VDC (PVC) 424 VAC/600 VDC (PVC) 300 VAC/424 VDC (PMSXT) *2 PINS POWERED *Teflon™ is a trademark of The Chemours Company FC, LLC used under license by Samtec. Notes: Teflon™ Fluoropolymer cable is intended for crimp only. Contact Samtec for solderable cable applications. (12.14) .478 PMSD/PMSDT For wiring option information refer to drawing on web. View complete specifications at: samtec.com?PMSD, samtec.com?PMSDT, samtec.com?PMSS & samtec.com?PMSST IPBD - - POSITIONS PER ROW —02, —03, —04, —05, —08, —10, —15 (Standard sizes) - ROW OPTION –S = Single Row –D K –K = Keyed Polarization = Double Row SERIES CC69L = Contact, Loose CC69R = Contact, Full Reel (4,000 Parts per Reel) (19.56) .770 (12.14) .478 –D - WIRE GAUGE –2024 = 20 to 24 AWG - 01 T - SP –T = Tin –1620 = 16 to 20 AWG (19.23) .757 (7.95) .313 (7.95) .313 –S TOOLING Hand Tool: CAT-HT-169-1620-13 (16-20 AWG) Hand Tool: CAT-HT-169-2024-13 (20-24 AWG) Note: Some lengths, styles and options are non-standard, non-returnable. Mini Applicator: CAT-MC-169-1620-XX-02 (16-20 AWG) Mini Applicator: CAT-MC-169-2024 XX-01 (20-24 AWG) Extraction Tool: CAT-EX-169-01 View complete specifications at: samtec.com?IPBD, samtec.com?CC69L & samtec.com?CC69R samtec.com/PowerMate Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-224
IPBD-08-D-K-M 价格&库存
很抱歉,暂时无法提供与“IPBD-08-D-K-M”相匹配的价格&库存,您可以联系我们找货
IPBD-08-D-K-M
  • 16+23.9042716+3.09416
IPBD-08-D-K-M
    • 1+86.74560
    • 192+34.61400
    • 496+33.45840
    • 992+32.88600
