IPL1-115-01-S-D-RE1-K-WT 数据手册
MAX
4.8
A
(2.54 mm) .100" PITCH • DISCRETE WIRE TERMINAL
IPL1
1
PINS PER
ROW
02, 03,
04, 05,
06, 08,
10, 12,
LEAD
STYLE
–01
PLATING
OPTION
–L
= Throughhole
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
–02
= Surface
Mount
15, 16,
–S
–RA
=Right-angle
(–01 lead style only)
–SH
s
TAIL OPTION
= Single Row
K
–K
=Keyed
Polarization
–RE1
= Single Row
Horizontal
(–02 lead
style only)
–D
p
=Right-angle Elevated
(–K is a required
callout)
OPTION
–TR
= Tape & Reel
(–02 lead style only)
Comes with Polyimide
Pick & Place Pad
–FR
= Full Reel Tape &
Reel (must order max.
quantity per reel;
contact Samtec for
quantity breaks) (-02 lead
style only) Comes with
Polyimide Pick & Place
Pad
= Double Row
20, 25
IPL1
ROW
OPTION
m
(Standard
sizes)
Cable Mates:
MMSD, MMSS,
MMSDT, MMSST
SPECIFICATIONS
Insulator Material:
Natural LCP
Terminal Material:
Phosphor Bronze
Plating:
Sn or Au over
50 µ" (1.27 µm) Ni
Operating Temp Range:
-55 °C to +125 °C
Voltage Rating:
675 VAC/954 VDC
(8.76)
.345
(8.76)
.345
(8.76)
.345
PROCESSING
Lead–Free Solderable:
Yes
–S & –D (–02 Lead Style)
SMT Lead Coplanarity:
(0.10 mm) .004" max (02-05)
(0.13 mm) .005" max (06-10)*
(0.15 mm) .006" max (11-25)*
*(.004" stencil solution
may be available; contact
IPG@samtec.com)
–SH SMT Lead Coplanarity:
(0.15 mm) .006" max (02-25)*
ipg@samtec.com)
(7.04)
.277
(7.04)
–02–S
.277
(8.76)
.345
(8.76)
.345
(9.58)
.377
(9.58)
.377
WIRE
GUAGE
CURRENT
RATING
(PER PIN)
4.8 A
22
4.3 A
24
3.9 A
26
3.5 A
28
2.6 A
30
2.1 A
2 PINS POWERED
(6.10)
.240
(5.08)
.200
(6.86)
.270
(6.86)
.270
(6.35)
.250
(6.86)
.270
(6.35)
.250
(6.35)
.250
(8.76)
.345
–02–D
–01–D
(5.59)
.220
(5.59)
.220
ALSO AVAILABLE
MOQ Required
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
MMSD/IPL1
(7.04)
(9.58)
.277
.377
(5.59)
.220
Other sizes
With or without plug polarization
Guide post holes
Other platings
Weld tab
–01, –02 & –RA =
No. of positions x
(2.54) .100 + (1.52) .060
–01, –02 & –RA =
–SH
–RE1 = x
No.
of &positions
No..100
of positions
(2.54)
+ (1.52) x.060
(2.54) .100 + (4.06) .160
–SH–02
& –RE1
–01,
& –RA= =
No.
No. of
of positions
positions xx
(2.54)
(2.54) .100
.100 ++ (4.06)
(1.52) .160
.060
(6.10)
(5.08)
–SH & –RE1 =
.240
.200
No. of positions x
(2.54) .100 + (4.06) .160 (6.10)
(5.08)
.240
.200
–02–SH
(7.62)
.300
(8.13)
.320
(7.62)
.300
(8.13)
.320
(7.62)
.300
(8.13)
.320
–02
–01
–RA
–01–S
–01–S–RE1
(8.26)
.325
(8.26)
.325
(8.26)
.325
–01–S-RA
–01–D–RA
–01–D–RE1
View complete specifications at: samtec.com?IPL1
samtec.com/minimate
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
F-224
IPL1-115-01-S-D-RE1-K-WT 价格&库存
很抱歉,暂时无法提供与“IPL1-115-01-S-D-RE1-K-WT”相匹配的价格&库存,您可以联系我们找货
