MMS-111-02-F-DV
MMS-111-02-F-DV
    SAMTEC(申泰)
    2MM SOCKET STRIPS
MMS-111-02-F-DV 数据手册
F-217 MMS–112–02–F–SH MMS–112–01–L–DH MMS–116–02–L–DV MMS–108–01–L–SV (2.00 mm) .0787" MMS SERIES TIGER CLAW SOCKET STRIP ™ Board Mates: TMMH, TMM, MTMM, MMT, TW, LTMM, ZLTMM, TSH MMS NO. PINS PER ROW 1 ROW OPTION PLATING OPTION 01 Cable Mates: TCMD 02 thru 40 SPECIFICATIONS For complete specifications see www.samtec.com?MMS Insulator Material: Black LCP Contact Material: Phosphor Bronze Plating: Sn or Au over 50 µ" (1.27 µm) Ni Current Rating (MMS/TMM): 3.9 A per pin (1 pin powered per row) Operating Temp Range: -55 °C to +125 °C with Gold -55 °C to +105 °C with Tin Contact Resistance: 10 mΩ Insertion Depth: DH = (2.13 mm) .084" to (2.79 mm) .110", SH = (2.13 mm) .084" minimum or pass-through Top Entry DV/SV = (2.13 mm) .084" to (4.32 mm) .170" Bottom Entry DV/SV = (4.27 mm) .168" minimum (Plus board) RoHS Compliant: Yes PROCESSING (2.00) .0787 01 –SV –SH 80 79 –DV –SH –DV = Double Vertical –DH = Double Horizontal 01 –DH (4.45) .175 –SH –DH –SV MMS (4.70) .185 (2.92) .115 1 NO. PINS PER ROW ALSO AVAILABLE –SH 80 40 –S Row (3.81) .150 x (7.62) .300 02 (2.00) (4.17) .0787 .164 (4.00) .157 79 (1.22) .048 –P = Single Vertical –SH = Single Horizontal = 10 µ" (0.25 µm) Gold contact, Matte Tin on tail –DV = Double Vertical –DH = Double Horizontal (5.08) .200 x (5.71) .225 –DH No. of positions x (2.00) .0787 + (0.56) .022 –SV –D Row (5.71) .225 x (10.01).394 01 –DV ROW OPTION –L –M (1.39) .055 –SV –SH OTHER OPTION –“XX” = Polarized Position –K = (5.50 mm) .217" DIA Polyimide Film Pick & Place Pad (–SV & –DV only) (–SV= 3 positions min.) (–DV= 4 positions min.) –M = Metal Pick & Place Pad (4 positions min.) (–DV only) = Plastic Pick & Place Pad (4 pos. min., –SV only) (5 pos. min., –DV only) –TR (1.39) .055 (4.50) .177 (3.05) .120 –P (4.70) .185 (1.22) .048 (4.70) .185 –DH –DV = Gold flash on contact, Matte Tin on tail (2.16) .085 –SV (2.00) .079 –F (2.00) .0787 01 (2.92) .115 PLATING OPTION 02 02 thru 40 FILE NO: 090871_0_000 (3.05) .120 –SH –SV –DV (2.00) .0787 Note: Some lengths, styles and options are non-standard, non-returnable. = Polarized Position No. of positions x (2.00) .0787 + (0.56) .022 For complete scope of recognitions see www.samtec.com/quality • Alignment Pin (–DV only) • Locking clips and Throughhole pass-through options • Other platings Contact Samtec. = Single Horizontal (2.00) .0787 (4.00) .157 RECOGNITIONS (MOQ Required) –L = 10 µ" (0.25 µm) Gold contact, Matte Tin on tail 40 –“XX” = Single Vertical 02 Lead–Free Solderable: Yes SMT Lead Coplanarity: (0.15 mm) .006" max FILE NO. E111594 –SV –F = Gold flash on contact, Matte Tin on tail (2.00) .0787 OTHER OPTION = Tape & Reel Packaging –DV –DH WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice.
MMS-111-02-F-DV 价格&库存
很抱歉,暂时无法提供与“MMS-111-02-F-DV”相匹配的价格&库存,您可以联系我们找货
