F-219 (Rev 30APR19)
SL–120–G–10
SDL–125–TT–12
SDL–115–G–19
(2.54 mm) .100"
SL, SDL SERIES
SL–110–TT–11
LOW-PROFILE MACHINED SOCKET STRIPS
FEATURES
• Achieve low-profile
without sacrificing
insertion depth!
• Choice of four precision
screw machined lead
styles.
• Exceptionally low-profile,
down to (2.11 mm) .083"
off of board.
• Mates with BBL or BDL
for board stacking
spaces down to
(3.89 mm) .153"
SPECIFICATIONS
Mates with:
TS, TD, HTS, BBS, BBD,
BBL, BDL, BHS
1
NO. PINS
PER ROW
LEAD
STYLE
SL
SDL
= Double Row Low-Profile Socket Strip
–G
= 30 µ" (0.76 µm)
Gold contact,
10 µ" (0.25 µm)
Gold shell
01
(2.54) .100 X No. of Positions
+ (0.23) .009
thru
(2.54)
.100
(2.54)
.100
TYP
(1.27)
.050
+ (0.23) .009
(5.08)
.200
32
–T
= 30 µ" (0.76 µm)
Gold contact,
Tin shell
01
(2.54)
.100
thru
(1.27)
.050
(2.54)
.100
TYP
–TT
36
= Tin contact and shell
(LIF not available)
Low Insertion Force (LIF) Available
–10
= Low-Profile
(Hollow Leg)
–12
–11
For complete scope of
recognitions see
www.samtec.com/quality
(1.83)
.072 DIA
(1.83)
.072 DIA
(5.84)
.230
(1.32)
.052
DIA
(0.76)
.030
DIA
Contact Length =
(2.11 mm) .083"
Lead DIA Accepted =
(0.38 mm) .015" to (0.51 mm) .020"
Insertion Depth =
(2.67 mm) .105" to (4.32 mm) .170"
Style 10 Component Part No. =
SC-3P1
(6.10)
.240
(0.51)
.020
(3.35)
.132
(1.32)
.052
DIA
(4.83)
.190
(1.83)
.072 DIA
(2.41)
.095
(0.51)
.020
(1.32)
.052
DIA
(4.19)
.165
(0.74)
.029
DIA
Standard
Socket
(Reference only.
Not available
with SL & SDL)
Contact Length =
(1.58 mm) .062"
Lead DIA Accepted =
(0.41 mm) .016" to (0.51 mm) .020"
Insertion Depth =
(1.65 mm) .065" to (3.56 mm) .140"
Style 19 Component Part No. =
SC-8P1
Style 39 Component Part No. =
EZ-8P1
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
(4.45)
.175
(1.32)
.052
DIA
Micro
Socket
Contact Length =
(1.58 mm) .062"
Lead DIA Accepted =
Insertion Depth =
(1.65 mm) .065" to (3.81 mm) .150"
Style 12 Component Part No. =
SC-5P1
(0.25)
.010
(2.11)
.083
(0.76)
.030
DIA
(0.51)
.020
DIA
Contact Length =
(1.58 mm) .062"
Lead DIA Accepted =
(0.41 mm) .016" to (0.53mm) .021"
Insertion Depth =
(2.03 mm) .080" to (2.67 mm) .105"
Style 11 Component Part No. =
SC-4P1
Style 31 Component Part No. =
EZ-4P1
= Micro-Socket
(Hollow Leg)
For LIF specify –39
(2.11 mm)
3
8
ly
n
O
ard
above p.c. bo
(1.83)
.072 DIA
FILE NO. E111594
(3.10)
.122
(0.76)
.030
–19
= Micro-Socket
(Hollow Leg)
= Low-Profile
(Standard Mount)
For LIF specify –31
RECOGNITIONS
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
PLATING
OPTION
= Single Row Low-Profile Socket Strip
For complete specifications
see www.samtec.com?SL or
www.samtec.com?SDL
Insulator Material:
Black Glass Filled Polyester
(SDL)
Black Liquid Crystal Polymer
(SL)
Contact/Shell Materials:
BeCu/Brass
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Operating Temp Range:
-55 °C to +125 °C with Gold
-55 °C to +105 °C with Tin
RoHS Compliant:
Yes
Lead-Free Solderable:
Wave only
TYPE
STRIP
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
很抱歉,暂时无法提供与“SDL-109-T-12”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 24+46.8572324+6.04080
