SEAF-50-01-S-06-1-RA-GP-TR 数据手册
F-215
SEAF–20–01–L–06–2–RA–GP–TR
SEAF–20–01–L–04–2–RA–GP–TR
(1,27 mm) .050"
SEAF-RA SERIES
HI-DENSITY RIGHT ANGLE OPEN PIN FIELD
SPECIFICATIONS
Up to
500 pins
Mates with:
SEAM, SEAMP, SEAC
For complete specifications and
recommended PCB layouts see
www.samtec.com?SEAF-RA
OTHER SOLUTIONS
Insulator Material:
Black LCP
Contact Material:
Copper Alloy
Current Rating:
2.1 A per pin
(4 adjacent pins powered)
Operating Temp Range:
-55°C to +125°C
Plating:
Au or Sn over
50 µ" (1,27 µm) Ni
Contact Resistance:
17.1 mΩ max
Working Voltage:
280 VAC
Mated Cycles: 100
RoHS Compliant: Yes
Lead-Free Solderable: Yes
GPSK–01–01
Solder charge
terminations
Guide
post field
termination
kits also
available.
Contact
Samtec.
Low insertion/
extraction forces
RECOGNITIONS
For complete scope of
recognitions see
www.samtec.com/quality
Optional
guide post holes
GPPK–01–01
NO. PINS
PER ROW
SEAF
01
PLATING
OPTION
NO. OF
ROWS
SOLDER
TYPE
RA
OPTION
TR
ALSO AVAILABLE
(MOQ Required)
NO. OF ROWS
–04
–06
–08
–10
TEST
SEAF-RA/ SEAF-RA/
DATA*
SEAM-02 SEAM-RA
Single25 Gbps
24 Gbps
Ended
Differential 26 Gbps
22 Gbps
Pair
*@ 3dB insertion loss.
Test board losses deembedded
from performance data.
Complete test data available at
or contact sig@samtec.com
A
B
= Four Rows
= 10 µ" (0,25 µm)
Gold on contact area,
Matte Tin on solder tail
C
– 06
– 08*
= 30 µ" (0,76 µm)
(15,80) .622 (16,31) .642 (10,45) .411
(18,34) .722 (18,85) .742 (12,99) .511
= Tin/Lead Alloy
Solder Charge
= Six Rows
–S
(13,26) .522 (13,77) .542 (7,91) .311
–1
– 04
–L
– 20, – 30,
–40, –50
• Other platings
Contact Samtec.
–2
= Lead-Free
Solder Charge
= Eight Rows
– 10*
(20,88) .822 (21,39) .842 (15,53) .611
– GP
= Guide
Post Hole
– LP
= Latch Post
(06 row 30
positions only)
(Mates to
SEAC Series)
= Ten Rows
* Note: Fixturing required to process
eight and ten row options, see
www.samtec.com/searayfixture
(27,25) 1.073
B
A
–K
= Polyimide
film Pick &
Place Pad
(3,56)
.140
–GP= No. of positions x (1,27) .050 + (19,56) 0.77
Without –GP= No. of positions x (1,27) .050 + (9,40) 0.37
–LP (6 ROW) SHOWN
C
Note: Some sizes, styles and
options are non-standard,
non-returnable.
–GP (6 ROW) SHOWN
(1,27) .050
(0,64) .025
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
– TR
=Tape
& Reel
SEAF-50-01-S-06-1-RA-GP-TR 价格&库存
很抱歉,暂时无法提供与“SEAF-50-01-S-06-1-RA-GP-TR”相匹配的价格&库存,您可以联系我们找货
