SEAMP-30-02.0-S-10-TR 数据手册
HIGH-DENSITY
OPEN-PIN-FIELD ARRAYS
(1.27 mm) .050" PITCH
FEATURES & BENEFITS
• Maximum grounding & routing flexibility
• Up to 560 Edge Rate® contacts optimized for signal
integrity performance.
10 YEAR MFG
WITH 30 µ" GOLD
• 7 mm to 40 mm stack heights
• Variety of designs and options: Right-Angle, Guide Posts,
85 Ω Elevated Risers, 85 Ω Tuned, Press-Fit and Press-Fit
Right-Angle, Guide Post Field Termination Kits
• Cable mates (SEAC Series) and Jack Screw Standoffs
(JSO Series) also available
EXTENDED LIFE
PRODUCT
HIGH MATING
CYCLES
Solder Charges
MAXIMUM GROUNDING & ROUTING FLEXIBILITY
• Standards: VITA 47, VITA 57.1 FMC, VITA 57.4 FMC+,
VITA 74 VNX, PISMO™ 2
• Supports high-speed protocols such as Ethernet,
PCI Express®, Fibre Channel & InfiniBand™
• Severe Environment Testing qualified (SEAM/SEAF);
aligns with MIL-DTL-55302. Visit samtec.com/set
SERIES
INSULATOR
MATERIAL
CONTACT
MATERIAL
SEAM/SEAF
Black LCP
Copper Alloy
SEAM-RA/SEAF-RA
Black LCP
SEAM-GP
(1.12 mm) .044"
Nominal Wipe
Single-Ended
Power
CURRENT
RATING
VOLTAGE
RATING
LEAD-FREE
SOLDERABLE
Au or Sn over 50 µ"
-55 °C to +125 °C
(1.27 µm) Ni
2.7 A
(10 pins powered)
240 VAC
Yes
Copper Alloy
Au or Sn over 50 µ"
-55 °C to +125 °C
(1.27 µm) Ni
1.9 A
(10 pins powered)
260 VAC
Yes
Black LCP
Copper Alloy
Au or Sn over 50 µ"
-55 °C to +125 °C
(1.27 µm) Ni
2.7 A
(10 pins powered)
240 VAC
Yes
SEAMP/SEAFP
Natural High
Temp Nylon
Copper Alloy
(SEAMP)
BeCu Alloy
(SEAFP)
Au or Sn over 50 µ"
-55 °C to +125 °C
(1.27 µm) Ni
1.9 A
(6 pins powered)
225 VAC
Not
Available
SEAR
Black LCP
Hard Gold
Plated
Contact Samtec
240 VAC
Not
Available
SEAMI
Black LCP
Copper Alloy
Not Available
Not
Available
Yes
PLATING
Au over 50 µ"
(1.27 µm) Ni
OPERATING
TEMP RANGE
Differential Pair
-55 °C to +125 °C
Au or Sn over 50 µ"
-55 °C to +125 °C
(1.27 µm) Ni
Note: Some lengths, styles and options
are non-standard, non-returnable
F-224
samtec.com/SEARAY
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
(1.27 mm) .050" PITCH • PRESS-FIT & 85 Ω OPEN-PIN-FIELD ARRAYS
SERIES
SEAMP
POSITIONS
PER ROW
–10, –20,
Terminal
–02.0
(SEAFP only)
NO. OF
ROWS
–S
SEAMP
Board Mates:
SEAF,
SEAF-RA-GP,
SEAFP
–GP
NO. OF
ROWS
1RRISRVLWLRQV[
PACKAGING
–TR
Guide Post
(SEAMP only)
SEAFP: -04 &
-06 Rows only
= 30 µ" (0.76 µm)
Gold on contact area,
Matte Tin on tail
OPTION
–04, –06,
–08, –10
= 10 µ" (0.25 µm)
Matte Tin on tail
–05.0
Socket
PLATING
OPTION
–L
(SEAMP only)
–30, –40, –50
SEAFP
LEAD
STYLE
= Tape & Reel
–FR
= Full Reel
Tape & Reel
(must order max.
quantity per reel;
contact Samtec for
quantity breaks)
A
–04
(7.06) .278
–06
(9.60) .378
–08
(12.14) .478
–10
(14.68) .578
SEAFP
1RRISRVLWLRQV[
Board Mates:
SEAM,
SEAM-RA,
SEAMP
1RRISRVLWLRQV[
NO. OF
ROWS
A
–04
(5.61) .221
–06
(8.15) .321
View complete specifications at: samtec.com?SEAMP & samtec.com?SEAFP. Visit samtec.com?SEAFP-RA for right-angle socket.
SERIES
POSITIONS PER ROW
SEAR
–40, –50
85 Ω Tuned
Riser
LEAD STYLE
–10.0 = 20 mm Mated Height
–20.0 = 30 mm Mated Height
–30.0 = 40 mm Mated Height
SEAR
085
–06, –08, –10
B
A
Board Mates:
SEAFC
NO. OF ROWS
POSITIONS
PER ROW
A
–40
(71.42) 2.812
–50
(84.12) 3.312
NO. OF
ROWS
SERIES
POSITIONS
PER ROW
SEAMI
85 Ω Tuned
Terminal
–40
–50
- 11.0 -
PLATING OPTION
–L
= 10 µ" (0.25 µm) Gold on contact
area, Matte Tin on solder tail
–S
NO. OF
ROWS
–08
–10
= 30 µ" (0.76 µm) Gold on contact
SEAMI
Board Mates:
SEAF
Note: Some lengths,
styles and options
are non-standard,
non-returnable
SOLDER TYPE
–1
= Tin/Lead Alloy
SolderCharge
–2
= Lead-Free Solder
Charge
No. of positions x (1.27) .050 + (4.98) .196
A
(14.66)
.577
View complete specifications at: samtec.com?SEAR & samtec.com?SEAMI.
B
–06
(11.43) .450
–08
(13.97) .550
–10
(16.51) .650
-A-K-
"X"R
–TR
= Tape & Reel
–FR
= Full Reel
Tape & Reel
(must order max.
quantity per reel;
contact Samtec for
quantity breaks)
NO. OF
ROWS
A
–08
(13.41) .528
–10
(15.95) .628
samtec.com/SEARAY
F-224
SEAMP-30-02.0-S-10-TR 价格&库存
很抱歉,暂时无法提供与“SEAMP-30-02.0-S-10-TR”相匹配的价格&库存,您可以联系我们找货
