SFM-135-01-S-D-LC-K
SFM-135-01-S-D-LC-K
    SAMTEC(申泰)
    .050'' X .050
SFM-135-01-S-D-LC-K 数据手册
REVISION CP DO NOT SCALE FROM THIS PRINT NOTES: SFM-1XX-XX-XXX-D-XXX 1. C REPRESENTS A CRITICAL DIMENSION. C1 2. MINIMUM PUSHOUT FORCE: .5 LB. 3. COPLANARITY: .004[0.10] = POS 05 THRU 26 .006[0.15] = POS 27 THRU 50 4. TUBE ALL POSITIONS. PARTS TO BE TUBED WITH NOTCH GOING WITH ARROW. 5. PINS CAN BE ORIENTED IN ANY DIRECTION; BOTH ROWS MUST FACE SAME WAY. 6. SEE NOTCH FOR PROPER ORIENTATION. 7. MAXIMUM PIN HEIGHT VARIATION: .003[0.08]. 8. DUE TO HIGH AMOUNT OF INSERTION FORCE NEEDED, THE -LC OPTION IS NOT COMPATIBLE WITH AUTO PLACEMENT. SAMTEC RECOMMENDS MANUAL PLACEMENT FOR ALL ASSEMBLIES WITH THE -LC OPTION. No OF POSITIONS ALL POSITIONS AVAILABLE -02 THRU -50 (USE BODY: SFM-XX-D-XX-X) *: DIMENSIONS N/A FOR -N OPTION *.145 3.68 REF *.020 0.51 REF .120 3.05 REF *.080 2.03 REF .050 1.27 REF 02 CL 01 CL OPTIONS (LEAVE BLANK FOR STANDARD AND USE SFM-XX-D) -N: NO POLARIZATION NOTCH (USE SFM-XX-D-XX-N) -A: ALIGNMENT PIN (USE SFM-XX-D-A-X) (SEE FIG. 4, SHT 2) -LC: LOCKING CLIP (SEE FIG. 6, SHT. 3 & NOTE 8) (AVAILABLE ON ALL LEADS) -P: PICK AND PLACE PAD (SEE FIG. 5, SHT 2) -TR: TAPE & REEL (SEE SHT 4) (NOT AVAILABLE WITH -SD OPTION) -K: POLYIMIDE FILM PAD (.005[0.13] THICKNESS WITH SILICONE ADHESIVE) (SEE FIG. 3, SHT. 2) (USE K-500-300) -SN: SOLDER NAIL FOR .062 BOARD (SFM-XX-D-SN AND WT-27-01-T) (AVAILABLE WITH LEAD STYLE -02, -L2 & -T2) (NOT AVAILABLE WITH -A & -LC) -SN2: SOLDER NAIL FOR .093 BOARD (SFM-XX-D-SN AND WT-27-02-T) (AVAILABLE WITH LEAD STYLE -02, -L2 & -T2) (NOT AVAILABLE WITH -A & -LC) **-SD: SCREW DOWN FOR .062 BOARD (ONLY AVAILABLE WITH -01 & -02 LEAD STYLE) (NOT AVAILABLE WITH OPTIONS -N, -A, -LC, -RA, -SA, -WT, -RE1, -RE2, SN, OR SN2 (SFM-XX-D-SD, CPS-RR-XX-XX-X & ACCRT-01) (SEE FIG. 8, SHT. 3) LEAD STYLE -01: THROUGH HOLE (USE CONTACT: C-44-01-XXX) (SEE FIG. 1, SHT. 1) -02: SURFACE MOUNT (USE CONTACT: C-44-02-XXX) (SEE FIG. 2, SHT. 2) -03: STRAIGHT MODIFIED (USE CONTACT: C-44-03-XXX) (SEE FIG. 1, SHT. 1) -L1: THROUGH HOLE (LOW INSERTION) (USE CONTACT: C-61-01-XXX) (SEE FIG. 1, SHT. 1) -L2: SURFACE MOUNT (LOW INSERTION) (USE CONTACT: C-61-02-XXX) (SEE FIG. 2, SHT. 2) -L3: STRAIGHT MODIFIED (LOW INSERTION) (USE CONTACT: C-61-03-XXX) (SEE FIG. 1, SHT. 1) -T1: THROUGH HOLE (PHOS BRONZE) (USE CONTACT: C-119-01-XXX) (SEE FIG. 1, SHT. 1) -T2: SURFACE MOUNT (PHOS BRONZE) (USE CONTACT: C-119-02-XXX) (SEE FIG. 2, SHT. 2) (** = NOT RELEASED FOR PRODUCTION) BODY SPECIFICATION -D: DOUBLE ROW .050 1.27 REF (NO. OF POS x .050[1.27]) + .015[0.38] REF "A" SFM-XX-D-XX-X (NO. OF POS x .050[1.27]) + .155[3.94] REF CL C-XX-01-XXX (SEE NOTE 5) .180 4.57 REF .110 2.79 REF C2 "A" .015 0.38 REF "A" (SEE TABLE 1) CL 2 MAX SWAY (TYP) "B" REF .050 1.27 C3 1 MAX SWAY (TYP) FIG 1 (NO. OF POS x .050[1.27]) - .050[1.27] REF THROUGH HOLE/STRAIGHT MODIFIED SECTION "A"-"A" UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS ANGLES .XX: .01 [.3] 2 .XXX: .005 [.13] .XXXX: .0020 [.051] MATERIAL: C4 .005 0.13 REF PLATING SPECIFICATION CP -S: 30µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -F: 3µ" FLASH SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -H: 30µ" HEAVY GOLD IN CONTACT AREA, 3µ" GOLD ON TAIL -L: 10µ" LIGHT SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -STL: 30µ" SELECTIVE GOLD IN CONTACT AREA, TIN/LEAD (90/10+/-5%) TAIL (ONLY AVAILABLE ON -02 OR -L2 LEADSTYLES) -SM: 30µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -FM: 3µ" FLASH SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -LM: 10µ" LIGHT SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 3:1 INSULATOR: LCP, COLOR: BLACK CONTACT: TIGER EYE = BeCu TIGER EYE LITE = PHOSPHOR BRONZE CP F:\DWG\MISC\MKTG\SFM-1XX-XX-XXX-D-XXX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .050 x .050 SOCKET STRIP DOUBLE ROW ASSEMBLY DWG. NO. SFM-1XX-XX-XXX-D-XXX BY: JORDAN 12/11/89 SHEET 1 OF 4 REVISION CP "R" (SEE NOTE) (NO. OF POS x .050[1.27]) - .050[1.27] REF (TOL ACCUM ±.005[0.13] OVER 50 POS) C-XX-02-XXX C7 "S" (SEE NOTE) .019±.010 0.48±0.254 02 C5 01 .190 4.83 2 MAX SWAY (TYP) .1575±.0050 4.000±0.127 FIG 3 -K: POLYIMIDE FILM PAD (SAME AS FIG 1, DIFFERENT AS SHOWN) "B" NOTE: "R" = USED MEASURED DIMENSION REF "S" = {("R" - .1575[4.000])/2}±.020[0.51] SFM-XX-D-XX-X C6 +.002 +0.051 .185 - .005 4.70 - 0.127 (SEE NOTE 7) 4° SEE NOTE 2 "B" 2° SEE NOTE .161 4.09 REF SECTION "B"-"B" FIG 2 -X2: SURFACE MOUNT (SAME AS FIG 1, DIFFERENT AS SHOWN) .394 10.01 REF "A"±.010[0.25] (SEE TABLE 2) .225 5.72 REF (NO. OF POS x .050[1.91]) + .125[3.18] REF PPP-02 .062 1.57 SFM-XX-D-A-X .050 1.27 REF R REF (NO. OF POS x .050[1.91]) + .075[0.38] REF FIG 5 .050 1.27 REF -P: PICK AND PLACE PAD (PAD TO BE ORIENTED A SHOWN FOR 5-12 POSITION PARTS) (FOR 13-50 POSITION PARTS, PAD MAY BE ORIENTED IN EITHER DIRECTION) (SAME AS FIG 1, DIFFERENT AS SHOWN) PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. FIG 4 -A: ALIGNMENT PIN (SAME AS FIG 1, DIFFERENT AS SHOWN) DO NOT SCALE DRAWING SHEET SCALE: 3:1 F:\DWG\MISC\MKTG\SFM-1XX-XX-XXX-D-XXX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .050 x .050 SOCKET STRIP DOUBLE ROW ASSEMBLY DWG. NO. SFM-1XX-XX-XXX-D-XXX BY: JORDAN 12/11/89 SHEET 2 OF 4 REVISION CP SFM-XX-D-LC-X (NO OF POS x .050[1.27] + .360[9.14] .218 5.52 REF .065 1.65 REF 02 .010 0.25 REF .056 1.42 REF (NO OF POS x .050[1.27] + .075[1.91] REF LC-05-TM 01 FIG 6 -LC: LOCKING CLIP (SAME AS FIG 1, DIFFERENT AS SHOWN) (AVAILABLE IN ALL LEADS) CPS-RR-M2-01-X 'E' SFM-XX-D-SD .070 1.78 REF C8 .145 3.68 POSITION 1 INDICATOR .335 8.50 REF C9 .081 2.06 (NO OF POS x .050[1.27] + .600[15.24] REF .114 2.90 REF .012 0.30 REF ACCRT-01 DETAIL 'E' SCALE 6 : 1 (NO OF POS x .050[1.27] + .185[4.70] REF SFM-XX-D-SN "C" FLUSH TO .005[0.13] ABOVE "C" REF WT-27-XX-T "C" (NO OF POS x .050[1.27] + .085[1.27] REF PROPRIETARY NOTE .026 0.66 REF 2 MAX SWAY (TYP) FIG 8 -SD: SCREW DOWN (SAME AS FIG 7, DIFFERENT AS SHOWN) (NOT RELEASED FOR PRODUCTION) SECTION "C"-"C" THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING FIG 7 -SNX: SOLDER NAIL (SAME AS FIG 1, DIFFERENT AS SHOWN) SHEET SCALE: 3:1 F:\DWG\MISC\MKTG\SFM-1XX-XX-XXX-D-XXX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .050 x .050 SOCKET STRIP DOUBLE ROW ASSEMBLY DWG. NO. SFM-1XX-XX-XXX-D-XXX BY: JORDAN 12/11/89 SHEET 3 OF 4 REVISION CP CN PACKAGING VIEW PACKAGE PARTS IN TUBES AS SHOWN (SEE NOTE 4) PT-1-24-13-09 .630 16.00 PT-SFM004-X1-X3-D PT-SFM004-X1-X3-D 2.205 56.00 "D" PT-1-24-01-60 "D" UNWINDING DIRECTION (SEE NOTE 6) 5 POS -01 AND -03 LEAD STYLES MAY BE TUBED USING PT-1-24-15-09, TP-24-02 SECTION "D"-"D" SCALE 2 : 1 PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. PACKAGING VIEW -TR: TAPE AND REEL DO NOT SCALE DRAWING SHEET SCALE: 1.5:1 F:\DWG\MISC\MKTG\SFM-1XX-XX-XXX-D-XXX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .050 x .050 SOCKET STRIP DOUBLE ROW ASSEMBLY DWG. NO. SFM-1XX-XX-XXX-D-XXX BY: JORDAN 12/11/89 SHEET 4 OF 4
SFM-135-01-S-D-LC-K 价格&库存
很抱歉,暂时无法提供与“SFM-135-01-S-D-LC-K”相匹配的价格&库存,您可以联系我们找货
