SQT-138-01-L-S
SQT-138-01-L-S
    SAMTEC(申泰)
    插件,P=2mm
    排母 间距:2mm 插件
SQT-138-01-L-S 数据手册
COST-EFFECTIVE RUGGED SOCKETS (2.00 mm) .0787" PITCH • SQW/SQT SERIES SQW/SQT Board Mates: TMMH, TMMS, TMM, MTMM, MMT, TW, TSH, LTMM, ZLTMM, PTT Cable Mates: TCMD SQW - NO. PINS PER ROW 1 - 01 - 02 thru 50 –F –D–VS –T –LC –Q = Locking Clip (5 positions minimum) (Not available with -A) (Manual placement required) = Four Row –5 = Five Row –K –6 = (4.25 mm) .167" DIA Polyimide Film Pick & Place Pad (4 positions minimum) = Six Row –P = Pick & Place Pad (4 positions minimum) (2.29) .090 –TR (1.27) .050 (6.35) .250 = Tape & Reel (4–28 positions only) –FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) (4–28 positions only) (4.74) .187 —D, —T, —Q, —5, —6 —D—VS 1 NO. PINS PER ROW - 02 thru 50 LEAD STYLE - Specify LEAD STYLE from chart G b p s - PLATING OPTION ROW OPTION –F No. of rows x (2.00) .0787 - –S = Gold flash on contact, Matte Tin on tail = Single Row –D = Double Row –L –T = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail No. of positions x (2.00) .0787 + (0.30) .012 = Triple Row –Q = Four Row LEAD STYLE A –01 (2.29) .090 –02 (15.24) .600 –03 (5.28) .208 –5 = Five Row OTHER OPTION –RA = Right-angle (–Q, –5 & –6 Row not available) (Lead Style –01 only) –“XXX” = Polarized Position (Indicate position number) –6 = Six Row (2.29) .090 (6.35) .250 Note: Some lengths, styles and options are non-standard, non-returnable. –A = Alignment Pin (5 positions minimum) Metal or plastic at Samtec discretion. (Not available with -LC) = Triple Row No. of rows x (2.00) .0787 4 –“XXX” = Polarized Position –D–VS only options: = Double Row Surface Mount No. of positions x (2.00) .0787 + (0.30) .012 - OPTION –D = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail SQT - ROW OPTION = Double Row –L PROCESSING SQW Lead–Free Solderable: Yes, for -D & -D-VS (Wave only for -T, -Q, -5 & -6) SQT Lead–Free Solderable: Yes SMT Lead Coplanarity: (0.10 mm) .004" max (02-10) (0.15 mm) .006" max (11-50)* *(.004" stencil solution may be available; contact ipg@samtec.com) - = Gold flash on contact, Matte Tin on tail SPECIFICATIONS Insulator Material: Black Liquid Crystal Polymer Contact Material: Phosphor Bronze Plating: Sn or Au over 50 µ" (1.27 µm) Ni SQW Current Rating (SQW/TMMH): 3.8 A per pin (2 pins powered) SQT Current Rating (TMMH/SQT): 5.1 A per pin (2 pins powered) Voltage Rating: 281 VAC mated with TMM; 250 VAC mated with TMMH Operating Temp Range: -55 °C to +125 °C SQW Insertion Depth: (2.62 mm) .103" to (5.03 mm) .198" with (0.38 mm) .015" wipe SQT Insertion Depth: (2.62 mm) .103" to (5.03 mm) .198" Max Cycles: 100 with 10 µ" (0.25 µm) Au PLATING OPTION A —RA OPTION (—Q, —5 & —6 not available) samtec.com?SQW or samtec.com?SQT Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-224
SQT-138-01-L-S 价格&库存
很抱歉,暂时无法提供与“SQT-138-01-L-S”相匹配的价格&库存,您可以联系我们找货
