T1M44-M-2830-01-G
T1M44-M-2830-01-G
    SAMTEC(申泰)
    带印记 引脚 触点 镀金 28-30 AWG 压接
T1M44-M-2830-01-G 数据手册
F-224 SUPPLEMENT TFSDT–05–30–G–05.00–D–NUS TSDF–10–D–S T1M44-M–2830–01–G (1.27 mm) .050" TFSD, TFSDT, TSDF, T1M44-R, T1M44-M SERIES DISCRETE WIRE COMPONENTS & TOOLING Mates with: SFM, SFC (–TR requires TFM–WT option), SFML (–XL end option required) SPECIFICATIONS For complete specifications see www.samtec.com?TFSD or www.samtec.com?TFSDT Insulator Material: Black LCP Contact Material: BeCu Plating: Au over 50 µ" (1.27 µm) Ni Operating Temp Range: -10 °C to +80 °C (PVC) -40 °C to +125 °C (*Teflon™ Fluoropolymer) Wire: 28 or 30 AWG RoHS Compliant: Yes TYPE STRIP POSITIONS PER ROW –03, –04, –05, –07, = Double Row –10, –15, PVC Cable –20, –25, TFSDT –40, –50 = Double –30 TFSD Row Blue *Teflon™ Fluoropolymer Cable 02 For complete scope of recognitions see www.samtec.com/quality 01 = 30 AWG –28 = 28 AWG PLATING OPTION ASSEMBLED LENGTH –G –“XX.XX” = 10 µ" (0.25 µm) Gold on contact (82.60 mm) 03.25" min. for –D, –T, –TF, & –TR end option End 1 Notch (Always Down) *Teflon™ Fluoropolymer cable is intended for crimp only. Contact Samtec for solderable cable applications. For complete specifications see www.samtec.com?TSDF, www.samtec.com?T1M44-R or www.samtec.com?T1M44-M Insulator Material: Black LCP Contact Material: BeCu TOOLING • Hand Tool: CAT-HT-144-2830-12 Note: Some sizes, styles and options are non-standard, non-returnable. –D –NUS = Double Ended –T = Transfer End Terminal on End 1 Socket on End 2 –TR (6.10) .240 = Notch up, straight –NDS = Notch down, straight –NUX = Notch up, crossed –NDX = Transfer End with Retention Latch (TFM –WT option required for mating) (14.26) .562 Assembled Length ± (3.18) .125 (6.05) .238 End 2 Notch (NDS) End 2 Notch (NUS) –NDS OR –NUS POSITIONS PER ROW TYPE –03, –04, –05, –07, TSDF = Housing –10, –15, No. of Positions x (1.27) .050 –25, –20, + (2.54) .100 (1.27) .050 –40, –50 02 ROW OPTION S –D = Double Row (Standard sizes) 01 (6.10) .240 • Mini Applicator CAT-MC-144-2830-XX-01 • Extraction Tool: CAT-EX-169-01 –S = Single Ended = Transfer End with Friction Lock (–05 & –07 positions not available.) (1.27) .050 Some lengths, styles and options are non-standard, non-returnable. SPECIFICATIONS Requires –D, –TF or –TR (End 1 Notch Down). –TF End 1 Notch (Always Down) FILE NO. E111594 Notes: For wiring option and pin position location information, refer to drawings on web. END 2 OPTION END OPTION = Assembled Length in Inches (76.20 mm) 03.00" min. for –S end option (Standard sizes) No. of Positions x (1.27) .050 + (2.54) .100 RECOGNITIONS WIRE GAUGE (4.83) .190 End 2 Notch (NDX) End 2 Notch (NUX) –NDX OR –NUX TYPE T1M44–R = Terminal, Full Reel (35,000 parts per Reel) = Notch down, crossed *Teflon™ is a trademark of The Chemours Company FC, LLC used under license by Samtec. WIRE GAUGE 01 PLATING –G = 10 µ" (0.25 µm) Gold on contact –2830 = 28 to 30 AWG (0.46) .018 DIA T1M44–M = Terminal, Mini Reel (5,000 parts per Reel) (14.26) .562 (6.05) .238 (3.81) .150 WWW.SAMTEC.COM Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
T1M44-M-2830-01-G 价格&库存
很抱歉,暂时无法提供与“T1M44-M-2830-01-G”相匹配的价格&库存,您可以联系我们找货
T1M44-M-2830-01-G
  • 1+3.712471+0.48169
  • 10+3.1508210+0.40882
  • 25+2.7721225+0.35968
  • 50+2.5491650+0.33076
  • 100+2.44832100+0.31767
  • 250+2.19889250+0.28531
  • 500+2.09896500+0.27234
  • 1000+1.749131000+0.22695
  • 2500+1.599212500+0.20750
库存:14566
T1M44-M-2830-01-G
  • 5000+1.435125000+0.18621
  • 10000+1.3666210000+0.17732
  • 15000+1.3281015000+0.17232
  • 25000+1.2811125000+0.16623
  • 35000+1.2510835000+0.16233
  • 50000+1.2301350000+0.15961
库存:13700
T1M44-M-2830-01-G
  • 1+2.958291+0.38384
  • 10+2.5225510+0.32730
  • 25+2.3657825+0.30696
  • 50+2.2530050+0.29233
  • 100+2.14396100+0.27818
  • 250+2.00984250+0.26078
  • 500+1.91375500+0.24831
  • 1000+1.822211000+0.23643
  • 2500+1.708052500+0.22162
库存:13700
