TFM-110-02-L-S-A-K-TR
    SAMTEC(申泰)
    SMD
    线对板针座 立贴
TFM-110-02-L-S-A-K-TR 数据手册
RUGGED TIGER EYE™ SYSTEMS (1.27 mm) .050" PITCH MAX 8 3.7 A m p G b p s s FEATURES & BENEFITS • S crew down, locking clip, friction latching and weld tab ruggedizing options • Shrouded, polarized and keyed • Surface mount or through-hole tails • High-density, four row design (FOLC/MOLC Series) • Discrete wire assemblies available in single or double row, 28 and 30 AWG PVC or *Teflon™ Fluoropolymer (See pages 238-239). Contact asp@samtec.com for custom solutions. • Cable components (ISDF/CC03) and tooling available: samtec.com/tooling • Severe Environment Testing qualified (SFM/TFM); aligns with MIL-DTL-55302. Visit samtec.com/set *Teflon™ is a trademark of The Chemours Company FC, LLC used under license by Samtec. KEY SPECIFICATIONS SERIES STACK INSULATOR HEIGHTS MATERIAL CONTACT MATERIAL BeCu (SFM) SFM/TFM 6 to 12 mm Black LCP SFC/TFC Black LCP 6 to 12 mm F-224 (Rev 04APR24) Phosphor Bronze (TFM) Phosphor Bronze IDC cable assemblies with rugged strain relief (FFSD/FFMD, FFTP/FMTP) Locking for increased unmating force (SFML/TFML) PLATING OPERATING TEMP RANGE CURRENT RATING VOLTAGE RATING MAX. CYCLES LEAD-FREE SOLDERABLE Au or Sn over 50 µ" (1.27 µm) Ni -55 °C to +125 °C 3.7A per pin (2 pins powered) 275 VAC 10,000 with 30 µ" (0.76 µm) Au Yes Au or Sn over 50 µ" (1.27 µm) Ni -55 °C to +125 °C 3.1 A per pin (2 pins powered) 350 VAC (Call Samtec for E.L.P.™ plating option) Yes samtec.com/127mm-TigerEye Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. MAX 3.7 A (1.27 mm) .050" • SMT/THROUGH-HOLE HEADER SERIES -1 TFM NO. PINS PER ROW - 03, 04, 06, 08 = Standard (TFM –01 & –02 only) TFML = Locking (–01 & –02 lead style only) 05, 07, 10, 15, 20, 25, 30, 35, 40, 45, 50 LEAD STYLE Specify LEAD STYLE from chart - PLATING OPTION –L = 15 µ" (0.38 µm) Gold on post, Matte Tin on tail (Call Samtec for E.L.P.™ plating option) (Standard sizes) TFM - TFML Board Mates: SFML Cable Mates: SFSD, TFSD (-T end option)  [ 1RRI3RVLWLRQV   Specify only –RA, –RE1 or –RE2 –D = Right-angle (Lead style –01 only) = Double Row –DH* = Double Horizontal (TFM lead style –02 only) (05 thru 50 positions only) (–TR or –FR option only available) –RE1 = Right-angle Elevated for (1.60 mm) .062" PCB (Requires TFM lead style –01, –D row and –WT) (9.91) .390 (11.81) .465 LEAD STYLE (T/H) MATED HEIGHT* TFM SFM -01 (5.97) .235 –03 (5.97) .235 -11 (7.75) .305 -13 (7.75) .305 -01 -21 (9.53) .375 -23 (9.53) .375 -31 (11.43) .450 *Processing conditions will affect mated height.   DOUBLE ROW LEAD STYLE (SMT) $ A –02 (5.72) .225 –12* (7.49) .295 –22* (9.27) .365 –32* (11.18) .440 * N/A with 07, -DH or -S row option & SURFACE MOUNT –WT –RA (8.13) .320 -02 -32  [ 1RRI3RVLWLRQV   6HHZHEVLWHIRU²5(; ²'+²'6²:72$/ –A 8 G b p s OPTIONS –S = Single Row (TFM only) -22 SINGLE ROW –LC s - ROW OPTION –12   THROUGH-HOLE p SMT lead styles only Specify only –A, Specify only –K or –P –LC, –DS or –WT Not available with –RA, –RE1 and –RE2 unless –K otherwise noted. = Polyimide Film Pick & Place Pad –A = Alignment Pin –LC = Locking Clip (Manual Placement required) –P = Plastic Pick & Place Pad (5 positions min.) (Not available with 5 position with –WT) Specify –TR or -FR last –DS (Not available with –DS) = Dual –RE2 Screw Down = Right-angle –TR for (1.60 mm) Elevated for = Tape & Reel .062" PCB (2.36 mm) .093" PCB (05, 07, 10, 15, 20, (Requires TFM lead 25, 30, 35, 40 –FR style –01, –D row positions only) = Full Reel and –WT) (TFM lead styles Tape & Reel –01 and –02 only) (must order max. (Requires –D quantity per reel; row option) contact Samtec for (Mates with quantity breaks) MATED HEIGHTS* SFM–DS option and SFSD/SFSDT –SS and LEAD STYLE (SMT) –DS option only) MATED HEIGHT* TFM SFM (Not available with –A, –LC, –WT, –K, –P, –XR) -02 (6.35) .250 Board Mates: SFM, SFMC Cable Mates: SFSD, SFSS % m –DS LEAD STYLE (T/H) –WT = Weld Tab (TFM lead styles –01 and –02 only) (Required callout for –RE1 & –RE2) (Mates to SFSS/SFSD –SR and –DR option only) (05, 07, 10, 15, 20, 25, 30, 35, 40, 45, 50 positions only) B C –01 (5.59) .220 (1.97) .078 –03* (5.59) .220 (2.77) .109 –11* (7.37) .290 (1.97) .078 –13* (7.37) .290 (2.77) .109 –21* (9.14) .360 (1.97) .078 –23* (9.14) .360 (2.77) .109 –31* (11.05) .435 (1.97) .078 * Not Available with 07 or -S row option –DH* –RA –RE1 & –RE2 Notes: Severe Environment Testing qualified (TFM); aligns with MIL-DTL-55302. Visit samtec.com/set Some lengths, styles and options are non-standard, non-returnable. View complete specifications at: samtec.com?TFM & samtec.com?TFML samtec.com/127mm-TigerEye F-224 (Rev 04APR24) Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
TFM-110-02-L-S-A-K-TR 价格&库存
很抱歉,暂时无法提供与“TFM-110-02-L-S-A-K-TR”相匹配的价格&库存,您可以联系我们找货
