236-408/000-009/999-950
    WAGO(万可电子)
236-408/000-009/999-950 数据手册
Printview: Ex e II PCB terminal strip; 2 solder pins/pole; 8-pole; suitable for Ex e II applications; pin spacing 5/5.08 mm / 0.2 in - Item No.: 236-408/000-009/999-950 . Ex e II PCB terminal strip; 2 solder pins/pole; 8-pole; suitable for Ex e II applications; pin spacing 5/5.08 mm / 0.2 in Item No.: 236-408/000-009/999-950 . Ex e II PCB terminal strip; 2 solder pins/pole; 8-pole; suitable for Ex e II applications; pin spacing 5/5.08 mm / 0.2 in . Marking . Business data Supplier WAGO Item no. 236-408/000-009/999-950 EAN 4044918777353 Content 1 Order amount 25 Customer item number . Notes Terminal strips with CAGE CLAMP® connection, screwdriver actuation parallel or perpendicular to conductor entryOperating tools for factory wiring45° connection angle permits a wide range of uses and wiring optionsSet to metric or inch pin spacing by compressing terminal strips together or pulling them apart Technical data Miscellaneous No. of Poles 8 Total number of connection points 8 Total number of potentials 8 Color light gray Nominal current [A] 16 [A] Rated voltage EN (Ex e II) [V] 176 [V] Nominal current (Ex e II) [A] 16 [A] WAGO Kontakttechnik GmbH & Co. KG 1 Printview: Ex e II PCB terminal strip; 2 solder pins/pole; 8-pole; suitable for Ex e II applications; pin spacing 5/5.08 mm / 0.2 in - Item No.: 236-408/000-009/999-950 Technical data Ratings according to 4 ATEX: PTB 06 ATEX 1061 U / IECEx: PTB 06.0042 U Connection technology (1) CAGE CLAMP® Conductor type (1) solid Cross section from (1) [mm²] 0.08 [mm²] Cross section up to (1) [mm²] 2.5 [mm²] Cross section from (1) [AWG] 28 [AWG] Cross section up to (1) [AWG] 12 [AWG] Conductor type (2) fine-stranded Cross section from (2) [mm²] 0.08 [mm²] Cross section up to (2) [mm²] 2.5 [mm²] Conductor type (3) fine-stranded (with insulated ferrule) Cross section from (3) [mm²] 0.25 [mm²] Cross section up to (3) [mm²] 1.5 [mm²] Conductor type (4) fine-stranded (with uninsulated ferrule) Cross section from (4) [mm²] 0.25 [mm²] Cross section up to (4) [mm²] 1.5 [mm²] Stripped length from (1) [mm] 5 [mm] Stripped length up to (1) [mm] 6 [mm] Strip length from [inch] [in] 0.2 [in] Strip length up to [inch] [in] 0.24 [in] Stripped length (1) [in] 0.22 [in] Conductor entry angle to the PCB (degrees) [°] 45 [°] Type of wiring Front-/Side-entry wiring Solder pin length [mm] 4 [mm] Solder pin width A [mm] 0.7 [mm] Solder pin width B [mm] 0.7 [mm] Drilled hole diameter [mm] [mm] 1.1 [mm] Tolerance of drilled hole diameter [mm] [mm] +0.1 [mm] Material group I Insulating material Polyamide 6.6 (PA 6.6) Flammability rating per UL 94 V0 Lower limit temperature -60 [C] [C] Upper temperature limit [C] 105 [C] Clamping spring material Chrome-nickel spring steel (CrNi) WAGO Kontakttechnik GmbH & Co. KG 2 Printview: Ex e II PCB terminal strip; 2 solder pins/pole; 8-pole; suitable for Ex e II applications; pin spacing 5/5.08 mm / 0.2 in - Item No.: 236-408/000-009/999-950 Technical data Contact material Electrolytic copper (Ecu) Contact plating tin-plated Fire load [MJ] 0.1 [MJ] Weight [g] 7.132 [g] Width [mm] 42.3 [mm] Width [in] 1.665 [in] Height [mm] 13 [mm] Height [in] 0.512 [in] Length [mm] 14 [mm] Length [in] 0.551 [in] Pin spacing from [mm] 5 [mm] Pin spacing up to [mm] 5.08 [mm] Pin spacing from [in] 0.197 [in] Pin spacing up to [in] 0.2 [in] Approbation Item No. Registration Registration no. Voltage [V] Current [A] Cross section [mm², AWG] 236-408/000009/999-950 AEX E185892 300 15 28-12 236-408/000009/999-950 ATEx PTB 06 Atex 1061 176 U 16 0.08-2.50 236-408/000009/999-950 GOSENERGO-Ex 99.041 175 16 0,5-2,5 236-408/000009/999-950 PTB IECExPTB06.004 176 2U 16 0,5-2,5 236-408/000009/999-950 PTB PTB06ATEX1061 176 U 16 0,5-2,5 236-408/000009/999-950 RosTest 8189158 16 0,5-2,5 176 Accessories WAGO Kontakttechnik GmbH & Co. KG 3 Printview: Ex e II PCB terminal strip; 2 solder pins/pole; 8-pole; suitable for Ex e II applications; pin spacing 5/5.08 mm / 0.2 in - Item No.: 236-408/000-009/999-950 Accessories General accessory Item no. Description Pack. unit (Sub Pack) 209-130 Operating tool; suitable for 264, 280 and 281 Series; 1-way; of insulating material 1 210-191 Stickers for operating instructions; for PCB terminal blocks; 236 Series 100 210-657 Operating tool with partially insulated shaft; blade (3.5 x 0.5) mm; short; suitable for 260, 261, 1 262, 264, 270, 280, 281, 869, 870 and 880 Series 210-658 Operating tool with partially insulated shaft; blade (3.5 x 0.5) mm; short; angled; particularly 1 suitable for 280 Series actuator and sensor terminal blocks and also for Series 260, 261, 262, 264, 280, 281, 869, 870, 880, 2002, 210-720 Operating tool with partially insulated shaft; Type 2, blade (3.5 x 0.5) mm; suitable for 260, 1 261, 262, 264, 270, 280, 281, 290, 775, 776, 777, 769, 780, 781, 869, 870, 880, 2002, 2003, 2004, 2005 and 2022 Series 236-332 Operating tool; plastic 50 WAGO Kontakttechnik GmbH & Co. KG 4 Printview: Ex e II PCB terminal strip; 2 solder pins/pole; 8-pole; suitable for Ex e II applications; pin spacing 5/5.08 mm / 0.2 in - Item No.: 236-408/000-009/999-950 Images & drawings . Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 5
236-408/000-009/999-950 价格&库存
很抱歉,暂时无法提供与“236-408/000-009/999-950”相匹配的价格&库存,您可以联系我们找货
