Data sheet | Item number: 736-108
Double-deck PCB terminal block; 2.5 mm²; Pin spacing 5 mm; 2 x 8-pole;
CAGE CLAMP®; 2,50 mm²; gray
www.wago.com/736-108
Color:
Subject to changes.
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
29.12.2019 Page 1/11
(1) Solder pins in a row
L = (pole no. x pin spacing) + 1 mm
Item description
PCB terminal strips with screwdriver-actuated CAGE CLAMP®
High-density, double-deck design for space-efficient wiring of multiple conductors in confined areas
Custom marking for all termination levels
Data
Electrical data
Ratings per IEC/EN 60664-1
Ratings note
Between the modules
Rated voltage (III / 3)
250 V
Rated impulse voltage (III / 3)
4 kV
Rated voltage (III / 2)
320 V
Rated impulse voltage (III / 2)
4 kV
Rated voltage (II / 2)
630 V
Rated impulse voltage (II / 2)
4 kV
Rated current
21 A
Ratings according to 2
IEC/EN 60664-1
Ratings note 2
Between the decks
Rated voltage (III / 3) 2
320 V
Rated impulse voltage (III / 3) 2
4 kV
Rated voltage (III / 2) 2
320 V
Rated impulse voltage (III / 2) 2
Subject to changes.
Hansastr. 27
32423 Minden
4 kV
29.12.2019 Page 2/11
4 kV
Rated voltage (II / 2) 2
630 V
Rated impulse voltage (II / 2) 2
4 kV
Rated current (2)
21 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
Approvals per UL 1059
Rated voltage UL (Use Group B)
300 V
Rated current UL (Use Group B)
10 A
Rated voltage UL (Use Group D)
300 V
Rated current UL (Use Group D)
10 A
Approvals per CSA
Rated voltage CSA (Use Group B)
300 V
Rated current CSA (Use Group B)
10 A
Rated voltage CSA (Use Group D)
300 V
Rated current CSA (Use Group D)
10 A
Connection data
Connection technology
CAGE CLAMP®
Actuation type
Operating tool
Solid conductor
0.08 … 2.5 mm² / 28 … 12 AWG
Fine-stranded conductor
Fine-stranded conductor with ferrule with plastic collar
0.25 … 1.5 mm²
Fine-stranded conductor with ferrule without plastic collar
0.25 … 2.5 mm²
Strip length
5 … 6 mm / 0.2 … 0.24 inch
Conductor entry angle to the PCB
45 °
No. of poles
8
Total number of connection points
16
Total number of potentials
16
Number of connection types
1
Number of levels
2
Note (conductor cross-section)
12 AWG: THHN, THWN
Geometrical Data
Pin spacing
Width
Subject to changes.
Hansastr. 27
32423 Minden
5 mm / 0.197 inch
41 mm / 1.614 inch
29.12.2019 Page 3/11
Width
41 mm / 1.614 inch
Height
30.5 mm / 1.201 inch
Height from the surface
26.5 mm / 1.043 inch
Depth
21 mm / 0.827 inch
Solder pin length
4 mm
Solder pin dimensions
0.7 x 0.7 mm
Drilled hole diameter (tolerance)
1.3(- … +0.1) mm
PCB contact
PCB contact
THT
Solder pin arrangement
within the terminal block, in line
Number of solder pins per potential
1
Material Data
Color
gray
Material group
I
Insulating material
Polyamide 66 (PA 66)
Flammability class per UL94
V0
Clamping spring material
Chrome nickel spring steel (CrNi)
Contact material
Electrolytic copper (ECu)
Contact plating
tin-plated
Fire load
0.285 MJ
Weight
18.6 g
Environmental Requirements
Limit temperature range
-60 … +105 °C
Commercial data
Product Group
4 (Printed Circuit)
Packaging type
BOX
Country of origin
PL
GTIN
4044918913447
Customs Tariff No.
85369010000
Approvals / Certificates
Country specific Approvals
Subject to changes.
Hansastr. 27
32423 Minden
Certificate
29.12.2019 Page 4/11
Logo
Approval
Additional Approval Text
Certificate
name
CCA
DEKRA Certification B.V.
EN 60947
2160584.37
CCA
EN 60947
NTR NL7143
CCA
IEC 60947-7-4
NTR NL7307
CSA
C22.2 No. 158
70049157
Approval
ABS
American Bureau of Shipping
19HG1869876PDA
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAE000016Z
Ship Approvals
Logo
Certificate
name
UL-Approvals
Logo
Approval
UR
Underwriters Laboratories Inc.
UL 1059
Certificate
name
E45172,
sec. 6
Compatible products
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 5/11
ferrule
Item no.: 216-101
Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated
www.wago.com/216-101
Item no.: 216-102
Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated
www.wago.com/216-102
Item no.: 216-103
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated
www.wago.com/216-103
Item no.: 216-104
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated
www.wago.com/216-104
Item no.: 216-106
Ferrule; Sleeve for 2.5 mm² / AWG 14; uninsulated; electro-tin plated
www.wago.com/216-106
Item no.: 216-121
www.wago.com/216-121
Item no.: 216-122
www.wago.com/216-122
Item no.: 216-123
www.wago.com/216-123
Item no.: 216-124
www.wago.com/216-124
Item no.: 216-131
Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated
www.wago.com/216-131
Item no.: 216-132
Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated
www.wago.com/216-132
Item no.: 216-141
Ferrule; Sleeve for 0.5 mm² / 20 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 1/08.92
www.wago.com/216-141
Item no.: 216-142
Ferrule; Sleeve for 0.75 mm² / 18 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-142
Item no.: 216-143
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-143
Item no.: 216-144
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-144
Item no.: 216-151
www.wago.com/216-151
Item no.: 216-152
Subject to changes.
Hansastr. 27
32423 Minden
www.wago.com/216-152
29.12.2019 Page 6/11
Item no.: 216-152
Item no.: 216-201
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white
www.wago.com/216-201
Item no.: 216-202
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray
www.wago.com/216-202
Item no.: 216-203
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red
www.wago.com/216-203
Item no.: 216-204
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black
www.wago.com/216-204
Item no.: 216-221
www.wago.com/216-221
Item no.: 216-222
www.wago.com/216-222
Item no.: 216-223
www.wago.com/216-223
Item no.: 216-224
www.wago.com/216-224
Item no.: 216-241
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; white
www.wago.com/216-241
Item no.: 216-242
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; gray
www.wago.com/216-242
Item no.: 216-243
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243
acc. to DIN 46228, Part 4/09.90; red
Item no.: 216-244
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; black
www.wago.com/216-244
Item no.: 216-262
www.wago.com/216-262
Item no.: 216-263
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-263
Item no.: 216-264
www.wago.com/216-264
Item no.: 216-284
www.wago.com/216-284
Item no.: 216-301
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 7/11
Item no.: 216-301
Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow
www.wago.com/216-301
Item no.: 216-302
Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green
www.wago.com/216-302
Item no.: 216-321
www.wago.com/216-321
Item no.: 216-322
www.wago.com/216-322
Item no.: 210-657
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; short
www.wago.com/210-657
Item no.: 210-658
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; angled; short
www.wago.com/210-658
Item no.: 210-720
www.wago.com/210-720
tools
Marking accessories
Item no.: 210-332/500-202
www.wago.com/210-332
Marking strips; as a DIN A4 sheet; MARKED; 1-16 (160x); Height of marker strip: 3 mm; Strip length 182
/500-202
mm; Horizontal marking; Self-adhesive; white
Item no.: 210-332/500-204
Marking strips; as a DIN A4 sheet; MARKED; 17-32 (160x); Height of marker strip: 3 mm; Strip length
182 mm; Horizontal marking; Self-adhesive; white
/500-204
Item no.: 210-332/500-205
Marking strips; as a DIN A4 sheet; MARKED; 1-32 (80x); Height of marker strip: 3 mm; Strip length 182
/500-205
Item no.: 210-332/500-206
Marking strips; as a DIN A4 sheet; MARKED; 33-48 (160x); Height of marker strip: 3 mm; Strip length
/500-206
check
Item no.: 231-126
Testing plug module with contact stud; for 280, 736, 737, 738, 780 Series; Pin spacing 5 mm / 0.197 in; www.wago.com/231-126
2,50 mm²; gray
Item no.: 231-155
Testing plug module with contact stud; Pin spacing 5 mm / 0.197 in; 2,50 mm²; gray
www.wago.com/231-155
Downloads
Documentation
Additional Information
Technical explanations
Subject to changes.
Hansastr. 27
32423 Minden
Apr 3, 2019
pdf
Download
3.6 MB
29.12.2019 Page 8/11
3.6 MB
CAD/CAE-Data
CAD data
2D/3D Models 736-108
URL
Download
CAE data
EPLAN Data Portal 736-108
Download
PCB Design
Symbol and Footprint 736-108
URL
Download
CAx data for your PCB design, consisting of "schematic symbols and PCB footprints",
allow easy integration of the WAGO component into your development environment.
Supported formats:
Accel EDA 14 & 15
Altium 6 to current version
Cadence Allegro
DesignSpark
Eagle Libraries
KiCad
Mentor Graphics BoardStation
Mentor Graphics Design Architect
Mentor Graphics Design Expedition 99 and 2000
OrCAD 9.X PCB and Capture
PADS PowerPCB 3, 3.5, 4.X, and 5.X
PADS PowerPCB and PowerLogic 3.0
PCAD 2000, 2001, 2002, 2004, and 2006
Pulsonix 8.5 or newer
STL
3D STEP
TARGET 3001!
View Logic ViewDraw
Quadcept
Zuken CadStar 3 and 4
Zuken CR-5000 and CR-8000
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 9/11
PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian
Installation Notes
Inserting a conductor
Inserting a conductor via 3.5 mm
screwdriver.
Screwdriver actuation parallel to conductor
entry.
Application
Low space requirements due to high-density
design
– double-deck PCB terminal strip – 736
Series.
Possible combination:
Double- (736 Series) and triple-deck PCB
terminal strips (737 Series) upon request
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 10/11
Double- (737 Series) and quadruple-deck
PCB terminal strips (738 Series) upon
request
request
Testing
Testing via contact area above the
conductors.
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 11/11
很抱歉,暂时无法提供与“736-108”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+51.14880
- 10+43.22160
- 42+38.39400
- 国内价格 香港价格
- 1+122.077071+15.81395
- 10+86.7873810+11.24250
- 25+76.9896725+9.97330
- 50+71.0890850+9.20893
- 100+66.33018100+8.59246
- 250+61.50246250+7.96707
- 500+58.74581500+7.60998
- 1000+56.598601000+7.33183
