IJ5H-08-0610-S-2-01SP1 数据手册
F-224 WEB
IJ5H–08–0300–S–2–03SP2
IJ5H–02–0600–S–2–02SP2
IJ5H SERIES
(4.00 mm) .1575"
50 Ω HYBRID RF CABLE ASSEMBLY
SPECIFICATIONS
For complete specifications and
recommended PCB layouts see
www.samtec.com?IJ5H
Insulator Material:
Black LCP
Contact Material:
Copper Alloy
Pin Material:
Copper Alloy
Dielectric Material:
Black LCP
Plating:
Au over 50 µ" (1.27 µm) Ni
Operating Temp Range:
-40 °C to +90 °C
RoHS Compliant:
Yes
RG 316 Cable
Low-cost isolated
transmission line
system
Mates with:
IP5
End 2 Mates:
SMA, MCX,
MMCX, SMB5
Positive
latching
1, 2, 4, 6 or 8
Positions
Cable (-2):
Conductor Size:
26 AWG,
(0.51 mm) .020" dia.
Conductor Material:
Silver and Copper
Plated Steel Wire
Insulator Diameter:
(1.52 mm) .060"
Insulator Material:
PTFE
Shield Material:
Silver Plated Copper Wire
Jacket Material:
FEP
Jacket Diameter:
(2.54 mm) .100"
Bend Radius:
12.8 mm
Impedance:
50 Ω
Current Rating:
5 A DC
RoHS Compliant:
Yes
Choice of traditional
RF end options
NO. OF
POSITIONS
IJ5H
–01, –02,
–04, –06, –08
NO. OF
POSITIONS
–01
–02
–2
Specify
END 2
OPTION
from
chart.
= RG 316
cable
–01SP1
= SMA Straight Plug
(20.87) .822
–01RP1
= SMA Right-angle plug
–02SP1
= MCX Straight Plug
(48.87) 1.924
All Gold
–01BJ1
= SMA Bulkhead Jack
–01SR1
= SMA Straight Bulkhead Jack,
Sealed, Reversed Polarity
(25.17) .991
(4.00)
.1575
= 30 µ" (0.76 µm)
Gold on contact
END 2
OPTION
A
(40.87) 1.609
–08
–S
–“XXXX”
= Assembled Length
in millimeters
–0300 to –1000
(1000 mm) 39.40"
maximum
CABLE
TYPE
END 2 OPTION
(32.87) 1.294
–06
END 1
PLATING
END 2 OPTION
(24.87) .979
–04
ASSEMBLED
LENGTH
All Gold
–02RP1
= MCX Right-angle Plug
–03SP1
= MMCX Straight Plug
–03RP1
= MMCX Right-angle Plug
END 2 OPTION
Gold/Nickel
Combination
–02SP2
= MCX Straight Plug
–03SP2
–07SP2
= SMB Straight Plug
–07SP1
= SMB Straight Plug
A
01SP1 END OPTION SHOWN
Note:
This Series is non-standard,
non-returnable.
(8.55)
.336
ASSEMBLED LENGTH
WWW.SAMTEC.COM
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
IJ5H-08-0610-S-2-01SP1 价格&库存
很抱歉,暂时无法提供与“IJ5H-08-0610-S-2-01SP1”相匹配的价格&库存,您可以联系我们找货
