F-224 SUPPLEMENT
T1M74–L–01–F
IPM1–08–D
MMTD–06–20–F–03.25–D–TUS
(2.54 mm) .100"
MMTD, MMTDT, MMTS, MMTST, IPM1, T1M74-L, T1M74-R SERIES
DISCRETE WIRE COMPONENTS & TOOLING
Mates with:
MMSD(T), MMSS(T)
–TXS Mates with:
IPL1
SPECIFICATIONS
For complete specifications see
www.samtec.com?MMTD,
www.samtec.com?MMTDT,
www.samtec.com?MMTS or
www.samtec.com?MMTST
Insulator Material:
Nylon, White
Contact Material:
Phosphor Bronze
Wire:
20 to 30 AWG
Plating:
Au over 50 µ" (1.27 µm) Ni
Operating Temp Range:
-10 °C to +105 °C (20-26 AWG)
-10 °C to +80 °C (28-30 AWG)
-40 °C to +125 °C
(*Teflon™ Fluoropolymer)
Voltage Rating:
600 VAC
RoHS Compliant:
Yes
*Teflon™ is a trademark of
The Chemours Company FC,
LLC used under license by
Samtec.
RECOGNITIONS
For complete scope
of recognitions see
www.samtec.com/quality
PINS PER
ROW
TYPE
–02, –03,
MMTD –04, –05,
= Double Row
–06, –08,
PVC Cable
–10, –12,
MMTDT –15, –16,
= Double Row
–20, –25
Blue *Teflon
Fluoropolymer (Standard sizes)
Cable
MMTD(T)
(20. 24, 28 & 30
(7.62)
Wire Gauge only)
.300
MMTS
= Single Row
(7.62)
.300
PVC Cable
(8.89)
.350
MMTST
= Single
Row
(8.89) ™
Blue *Teflon
.350
Fluoropolymer
Cable
(20, 24, 28 & 30
Wire Gauge only)
–20
–20C
= Color
Coded Cable
(MMTD &
MMTS only)
–22
–24
–24C
= Color
Coded Cable
(MMTD &
MMTS only)
–26
–28
–28C
PLATING
OPTION
–F
= Gold flash
on contact
–L
= 10 µ"
(0.25 µm)
Gold on
contact
Assembly
Length
± (3.18)
.125
ASSEMBLY
LENGTH
END
OPTION
–“XX.XX”
= Single
End
= Assembly
Length in Inches
–S= (76.2 mm)
03.00" min.
–D= (82.6 mm)
03.25" min.
–S
01
No. of positions x (2.54) .100
+ (1.78) .070
(2.54)
.100
20 .100
–TDS
10
= Socket
on End 2,
latch down
(2.54)
20 –24C,
.100 –28C
–20C,
CABLE
COLOR CODING
(PVC CABLE ONLY)
PIN
COLOR
1
2
3
4
5
6
7
8
9
10
ETC
(17.53)
.690
–30
–TUS
= Socket
on End 2,
latch up
APPLICATION
(2.54)
(2.54)
.100
(Only available
with –D)
= Double
End
10
11
11
OPTION
–D
Note:
Some lengths, styles and options
+ (1.78) .070
are non-standard, non-returnable.
01
= Color Assembly
(7.62) Coded Cable Length
.300
(MMTD & ± (3.18)
.125
MMTS only)
(7.62)
Note:
.300
Cable is intended for
crimp only. Contact
Samtec for solderable
cable applications.
FILE NO. E111594
WIRE
GAUGE
(5.08)
.200
MMTS(T)
(17.53)
BROWN
.690
RED
ORANGE
YELLOW
GREEN
BLUE
VIOLET
GRAY
WHITE
BLACK
REPEAT
(5.08)
.200
SPECIFICATIONS
www.samtec.com?IPM1,
www.samtec.com?T1M74-L or
www.samtec.com?T1M74-R
TOOLING
• Hand Tool:
CAT-HT-174-2030-13
• Mini Applicator (20-24 AWG):
CAT-MC-174-2024-XX-01
• Mini Applicator (26-30 AWG):
CAT-MC-174-2630-XX-01
TYPE
POSITIONS
PER ROW
–02, –03, –04,
IPM1 –05, –06, –08,
= Body,
–10, –12, –15,
Loose
–16, –20, –25
(Standard sizes)
(7.62)
.300
ROW
OPTION
–S
= Single
Row
–D
= Double
Row
(5.08)
.200
(17.53)
.690
–01
= 26 to 30 AWG
T1M74-L
–02
= Contact,
Loose
= 20 to 24 AWG
T1M74-R
= Contact,
Full Reel
(15,300 Parts
per Reel)
–F
= Gold flash
on contact
–L
= 10 µ" (0.25 µm)
Gold on contact
(19.33)
.761
(1.57)
.062
DIA
(1.91)
.075
• Extraction Tool:
CAT-EX-74-01
PLATING
OPTION
WIRE
GAUGE
TYPE
(3.81)
.150
–D
(3.17)
.125
–S
WWW.SAMTEC.COM
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
