MEC1-160-02-L-D-RA1-SL
    SAMTEC(申泰)
    SMD,P=1mm,卧贴
    CONN EDGEDUAL FMALE 120POS 0.039
MEC1-160-02-L-D-RA1-SL 数据手册
F-215 MEC1–120–02–F–D–A MEC1–130–02–F–D–A MEC1–140–02–L–D (1,00 mm) .0394" MEC1 SERIES MINI EDGE CARD SOCKET SPECIFICATIONS For complete specifications and recommended PCB layouts see www.samtec.com?MEC1 Insulator Material: Black LCP Contact Material: BeCu Plating: Sn or Au over 50µ" (1,27 µm) Ni Operating Temp Range: -55°C to +125°C Current Rating: 2.2 A per pin (2 adjacent pins powered) Voltage Rating: 300 VAC Insertion Depth: (5,84 mm) .230" to (8,13 mm) .320" RoHS Compliant: Yes Processing: Lead–Free Solderable: Yes SMT Lead Coplanarity: (0,10 mm) .004" max (05-20) (0,15 mm) .006" max (30-70) Mates with (1,60 mm) .062" card Mates with: (1,60 mm) .062" card APPLICATION MEC1 Rated @ 3dB Insertion Loss* 9,04 mm Stack Height Single-Ended Signaling 5.5 GHz / 11 Gbps Differential Pair Signaling 6.5 GHz / 13 Gbps *Performance data includes effects of a non-optimized PCB. Complete test data available at www.samtec.com?MEC1 or contact sig@samtec.com 1 MEC1 POSITIONS PER ROW Optional Alignment pin PLATING OPTION 02 D NP OTHER OPTION RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality –A 05, 08, 20, 30, 40, 50, 60, 70 –F –NP = Gold flash on contact, Matte tin on tail –L = No Polarization (05, 08, 20 & 30 positions only) = 10µ" (0,25 µm) Gold on contact, Matte Tin on tail Leave Blank for polarization ALSO AVAILABLE (MOQ Required) • Locking Clip (Manual placement required) • Other platings Contact Samtec. (No. of Positions + 2) x (1,00) .03937 + (2,54) .100 02 140 (6,99) .275 01 Note: While optimized for 50Ω applications, this connector with alternative signal/ground patterns may also perform well in certain 75Ω applications. Contact Samtec for further information. Important Note: Samtec recommends that pads on the mating board be Gold plated. 139 (0,36) (1,00) .014 .03937 (No. of Positions + 2) x (1,00) .03937 (8,89) .350 (1,83) .072 (9,04) .356 POSITIONS PER ROW POLARIZED POSITIONS (No Contact) 05 08 20 30 40 50 60 70 3, 4 5, 6 15, 16 21, 22 31, 32 41, 42 31, 32, 63 & 64 53, 54, 115 & 116 (0,15) .006 (1,40) .055 (8,51) .335 (0,89) .035 DIA –A OPTION Note: Some sizes, styles and options are non-standard, non-returnable. WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. = Alignment Pin metal or plastic at Samtec discretion. –K = (7,87 mm) .310" DIA Polyimide film Pick & Place Pad –TR = Tape & Reel
MEC1-160-02-L-D-RA1-SL 价格&库存
很抱歉,暂时无法提供与“MEC1-160-02-L-D-RA1-SL”相匹配的价格&库存,您可以联系我们找货
    • 1+116.58600
    • 200+45.12240
    • 500+43.53480
    • 1000+42.74640
