QRM8-078-05.0-S-D-A-GP
    SAMTEC(申泰)
    .8MM Q RATE TERMINAL WITH EDGE R
QRM8-078-05.0-S-D-A-GP 数据手册
® (0.80 mm) .0315" PITCH • QRM8/QRF8 SERIES QRM8 QRM8 Board Mates: QRF8 - QRF8 - PINS PER ROW NO. OF PAIRS –018, –036, –054 Cable Mates: EQRD (18 pairs per bank = –D–DP) SPECIFICATIONS = Guide Post –GP Leave blank for Tray Packaging –D-DP –K = Tape & Reel     –TR = (5.00 mm) .197" DIA Polyimide Film Pick & Place Pad LEAD STYLE $   1RRI%DQNV[     % 1RRI%DQNV[       –GP OPTION –FR = Full Reel Tape & Reel (must order maximum quantity per reel; contact Samtec for quantity breaks) A B –02 (4.81) (6.12) .189 .241 –05 (7.81) .307 –07 (9.78) (11.12) .385 .438 (9.12) .359 View complete specifications at: samtec.com?QRM8 QRF8 - PINS PER ROW NO. OF PAIRS –026, –052, –078 (52 total pins per bank = –D) –018, –036, –054 (18 pairs per bank = –D–DP) - LEAD STYLE –05.0 = 5 mm Body Height –07.0 = 7 mm Body Height - PLATING OPTION - –L –S = 30 µ" (0.76 µm) Gold on contact, Matte Tin on tail - - TYPE A –D = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail OTHER OPTIONS = Differential Pair –05 (5.01) .197 (1.04) .041 –07 (7.01) .276 No. of Banks x (24.80) .976 + (5.25) .206 –GP OPTION View complete specifications at: samtec.com?QRF8 –TR = Tape & Reel (Not available with –054 & –078 positions) = (5.00 mm) .197" DIA Polyimide Film Pick & Place Pad –FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) (Not available with –054 & –078 positions) MATED HEIGHT* No. of Banks x (24.80) .976 - (2.00) .078 A Leave blank for Tray Packaging –K –D-DP (4.60) .181 LEAD STYLE ”X”R = Guide Post No. of Banks x (24.80) .976 + (3.57) .140 (1.25) A .049 - –GP = SingleEnded (4.60) .181 HIGH MATING CYCLES F-224 ”X”R   10 YEAR MFG Note: Some lengths, styles and options are non-standard, non-returnable. - = SingleEnded = Differential Pair –S OTHER OPTIONS 1RRI%DQNV[     EXTENDED LIFE PRODUCT (1.20 mm) .047" Nominal Wipe A = 30 µ" (0.76 µm) Gold on contact, Matte Tin on tail –07.0 PROCESSING Lead–Free Solderable: Yes SMT Lead Coplanarity: (0.10 mm) .004" max (018-026) (0.15 mm) .006" max (036-078)* *(.004" stencil solution may be available; contact ipg@samtec.com) Board Stacking: For applications requiring more than two connectors contact ipg@samtec.com –05.0 = 5 mm Body Height - - TYPE –D = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail = 7 mm Body Height Insulator Material: Black LCP QRM8 Terminal Material: Phosphor Bronze QRF8 Contact Material: BeCu Ground Plane Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Current Rating: Contact: 2.2 A per pin (2 pins powered) Ground Plane: 8.5 A per ground plane (1 ground plane powered) Operating Temp Range: -55 °C to +125 °C Voltage Rating: 215 VAC Max Cycles: 100 - –L = 2 mm Body Height Not available with –054 & –078 Positions) (52 total pins per bank = –D) QRM8/QRF8 PLATING OPTION –02.0 –026, –052, –078 Board Mates: QRM8 - LEAD STYLE QRM8 LEAD STYLE QRF8 LEAD STYLE -02.0 -05.0 -07.0 –05 (7.00) .276 (10.00) .394 (12.00) .472 –07 (9.00) .354 (12.00) .472 (14.00) .551 *Processing conditions will affect mated height. See SO Series for board space tolerances. samtec.com/QRate Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
QRM8-078-05.0-S-D-A-GP 价格&库存
很抱歉,暂时无法提供与“QRM8-078-05.0-S-D-A-GP”相匹配的价格&库存,您可以联系我们找货
