RSF
5.0mm
CONNECTOR
Connectors for tabs
(.197") pitch
Features ––––––––––––––––––––––––
• Secure locking, easy insertion
The combination of terminal and housing allows easy mating to
a male tab. Unmating is equally easy. Simply hold the housing
and pull. The contact locking spring is depressed by the taper
inside the housing. The locking mechanism prevents accidental
disengagement of the contact from the mating tab.
• Stable contact performance
The contact is designed as a low insertion force with a large
contact area to give stable performance, even when high current
is applied.
• Lanceless contacts help to prevent contact back out
Removal of the locking lance from the contact and putting it in
the housing eliminates a major cause of contact backout due to
damaged locking lances during termination and harness
assembly.
• Housing options:
Selective removal of the built-in keys, allows for an infinite
number of keying possibilities. In addition, contact cavities can
be blocked using the cavity blocking plug or molded into the
housing when volume requirements dictate. The housings can
be molded in various colors.
Specifications –––––––––––––––––––
• Current rating: 20A AC, DC max.(#250 tab + AWG#12)
• Voltage rating: 250V AC, DC max.
• Temperature range: -40˚C to +105˚C
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/ 3m Ω max.
After environmental testing/ 6m Ω max.
• Insulation resistance:
1,000M Ω min.
• Withstanding voltage: 2,000V AC/minute
• Applicable wire: #250...AWG #22 to #12
• Applicable tab: #250 Tab 0.8mm(.031") thick
* Contact JST if Lead-Free product is required.
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
Standards ––––––––––––––––––––––
Recognized E60389
Certified C22.2 #182.3-M1987
1
RSF
CONNECTOR
Contact––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––
#250 Series
SRSF-91T-250A* (Tin Plated)
SRSF-91-250A* (Unplated)
3.2
(.126)
0.9(.035)
2.0(.079)
20.8(.819)
6.4
7.5
(.252) 3.2
(.295)
(.126)
2.8(.110)
2.8(.110)
0.9(.035)
7.5
(.295)
0.9(.035)
2.0(.079)
2.8(.110)
20.8(.819)
6.4
(.252)
7.6 (.299)
7.6 (.299)
SRSF-61T-250A* (Tin Plated)
SRSF-61-250A* (Unplated)
7.6 (.299)
SRSF-21T-250A* (Tin Plated)
SRSF-21-250A* (Unplated)
20.8(.819)
6.4
7.5
(.252) 3.2
(.295)
(.126)
2.0(.079)
#250 Series Nickel Plated Steel
SRSF-61N-250FE*
7.6 (.299)
7.6 (.299)
SRSF-21N-250FE*
0.9(.035)
2.0(.079)
2.8(.110)
2.8(.110)
0.9(.035)
20.8 (.819)
6.4
7.5
(.252) 3.2
(.295)
(.126)
20.95
6.4
(.252) 3.2
(.126)
7.5
(.295)
2.0(.079)
#250 Series Double Wire Crimp
7.6
(.299)
SRSF-82T-250A* (Tin Plated)
SRSF-82-250A* (Unplated)
21.1 (.831)
2.8(.110)
0.9(.035)
6.4
(.252) 3.2
(.126)
7.8
(.307)
1.7(.067)
Note: *Contact JST for availability.
2
Title: Current rating for SRSF connector
SRSF-91( )-250A and SRSF-91( )-250AS
Unit: A
current rating
position
AWG#12
AWG#14
2
3
19
15
4
19
15
5
19
15
6
17
14
7
17
14
8
17
14
9
15
13
10
15
13
11
15
13
12
15
13
SRSF-61( )-250A
SRSF-82( )-250A
SRSF-21( )-250A
Unit: A
position
2
3
4
5
6
7
8
9
10
11
12
AWG#14
15
14
12
12
11
11
11
10
10
10
10
current rating
AWG#16
10
10
10
10
10
10
10
10
10
10
10
AWG#18
7
7
7
7
7
7
7
7
7
7
7
current rating
AWG#20
4
4
4
4
4
4
4
4
4
4
4
Unit: A
position
2
3
4
5
6
7
8
9
10
11
12
AWG#16+16
10
10
10
10
10
10
10
10
10
10
10
current rating
AWG#16+18
10
10
10
10
10
10
10
10
10
10
10
AWG#16+20
10
10
10
10
10
10
10
10
10
10
10
AWG#18
7
7
7
7
7
7
7
7
7
7
7
Unit: A
position
2
3
4
5
6
7
8
9
10
11
12
AWG#22
3
3
3
3
3
3
3
3
3
3
3
RSF
CONNECTOR
Applicable wire
Model No.
Series
SRSF-21-250A*
AWG # UL1015
Insulation O.D.
mm(in.)
Material
0.32 to 0.82
22 to 18
2.5 to 3.0(.098 to .118)
Brass
0.82 to 2.08
18 to 14
3.0 to 3.9(.118 to .154)
2.08 to 3.30
14 to 12
3.9 to 4.4(.154 to .173)
Brass
3.0+3.0 to 3.4+3.4(.118+.118 to .134+.134)
Brass
Finish
Q´ty /
reel
SRSF-21T-250A*
SRSF-61-250A
SRSF-61T-250A
SRSF-91-250A*
mm2
#250
SRSF-91T-250A*
Brass
Tin-plated
5,000
Tin-plated
5,000
Tin-plated
5,000
SRSF-82-250A*
0.82+0.82, 1.31+1.31, 1.31+0.52
18+18, 16+16, 16+14, 16+20
Tin-plated
SRSF-82T-250A*
SRSF-21N-250FE*
0.32 to 0.82
22 to 18
SRSF-61N-250FE*
0.82 to 1.25
18 to 16
3.0 to 3.4(.118 to .134)
Steel
Nickel-plated
5,000
5,000
Note: Contact Extraction Tool Part Number: AEJ-RSF250H
TYP
3.5(.138)
25.5(1.004)
Max
RSF Series Connectors
9.2 Max
(.362)
Y Max
12.6 Max
(.496)
Circuits
1
Q'ty/bag
"Y"Max.mm(in.)
RSFP-LP-1V-250
Model No.
10,000
5.3 (.209)
RSFP-2V
Applicable terminal
3,000
10.0( .394)
SRSF-21T-250A
3
RSFP-3V
2,000
15.0( .591)
SRSF-21-250A
4
RSFP-4V
2,000
20.0( .787)
5
RSFP-5V
1,500
25.0( .984)
6
RSFP-6V
1,000
30.0(1.181)
7
RSFP-7V
1,000
35.0(1.378)
8
RSFP-8V
1,000
40.0(1.575)
9
RSFP-9V
800
45.0(1.772)
SRSF-21N-250FE
10
RSFP-10V
500
50.0(1.969)
SRSF-61N-250FE
11
RSFP-11V
500
55.0(2.165)
12
RSFP-12V
500
60.0(2.362)
2
SRSF-61T-250A
SRSF-61-250A
SRSF-91T-250A
SRSF-91-250A
SRSF-82T-250A
SRSF-82-250A
Material and Finish
Nylon 66, UL94V-0, natural(white) Other colors available upon request.
Notes: Consult JST for keying options and colored housings.
Cavity Blocking Plug Part Number: RSFP-PK.
Mates with NEMA, PC Mounted tabs only.
3
2 Position Housing
Part Numbers
Keying
2 Position Housing
Part Numbers
RSFP-2V-16
RSFP-2V-P
RSFP-2V-17
RSFP-2V-09
RSFP-2V-18
RSFP-2V-A
RSFP-2V-G
RSFP-2V-H
RSFPE-2V-00
(Extended Length
Series - 44.3mm)
RSFP-2V
RSFP-2V-E
RSFP-2V-00 (Natural)
RSFP-2VB-00 (Black)
RSFP-2V-B
RSFP-2V-K
RSFP-2V-I
Keying
3 Position Housing
Part Numbers
RSFP-3V-27
RSFP-3V-36
RSFP-3V-00
RSFP-2(3)V-00
RSFP-3V
RSFP-3VB-00
RSFP-3V-29
RSFP-2(3)V-00
RSFP-3V-B
RSFP-3V-ZB
RSFP-3V-A
Keying
3 Position Housing
Part Numbers
Keying
4 Position Housing
Part Numbers
RSFP-4V-A
RSSP-G4V-00
RSFP-2(4)V-00
RSFP-3(4)V-00
RSFP-4V-00
RSFP-4V
RSFP-2(4)V
RSFP-4V-19
RSFP-2.3(4)V-00
RSFP-4V-C
RSFP-4V-27
Keying
4 Position Housing
Part Numbers
Keying
5 Position
Housing
Part Numbers
Keying
5 Position
Housing
Part Numbers
RSFP-2.3(5)V-00
RSFP-5V-AA
RSFP-5V-AA
RSFP-5V-DA
RSFP-5V-00
RSFP-5V-ES
RSFP-2(5)V-00
RSFP-3(5)V-00
RSFP-4(5)V-00
RSFP-5(5)V-00
RSFP-1.4(5)V-00
RSFP-5V
RSFP-5VB-00
RSFP-3(5)VB-00
Keying
6 Position Housing
Part Numbers
Keying
6 Position Housing
Part Numbers
RSFP-2.4(6)V-00
RSFP-3.4(6)V-00
RSFP-6V-A
RSFP-2(6)V-00
RSFP-2.3.4(6)V-FA
RSFP-6V-00
RSFP-4.5(6)V-00
RSFP-2.4.6(6)V-00
RSFP-6V
RSFP-3(6)V-00
RSFP-4(6)V-00
RSFP-2.3.5(6)V-00
RSFP-3.5(6)V-00
RSFP-2.3(6)V-00
RSFP-2.6(6)V-00
RSFP-6V-FS
Keying
7 Position Housing
Part Numbers
Keying
7 Position Housing
Part Numbers
RSFP-3.5.6(7)V-00
RSFP-4.6(7)VB-00
RSFP-3(7)V-00
RSFP-2.6(7)V-00
RSFP-3.6(7)V-00
RSFP-5(7)V-00
RSFP-7V
RSFP-7V-A
RSFP-3.5(7)V-00
RSFP-7VB-00
RSFP-4.5.6(7)V-00
RSFP-3.4(7)VB-00
RSFP-7V-00
RSFP-2.3.4(7)V-00
RSFP-2.3.6(7)VB-00
RSFP-2.3(7)V-00
RSFP-2(7)V-00
Keying
8 Position
Housing
Part Numbers
Keying
8 Position
Housing
Part Numbers
RSFP-1.6(8)V-00
RSFP-6(8)V-00
RSFP-1.7(8)V-00
RSFP-6.7(8)V-00
RSFP-2.3(8)V-00
RSFP-8V-00
RSFP-2.4(8)V-00
RSFP-8V-D
RSFP-2.4.6.7(8)V-00
RSFP-8V
RSFP-2.6(8)V-00
RSFP-3(8)V-00
RSFP-4(8)V-00
RSFP-4.5.7.8(8)V-00
RSFP-4.5.8(8)V-00
RSFP-5(8)V-00
RSFP-5.6(8)V-00
Keying
9 Position Housing
Part Numbers
RSFP-2(9)V
RSFP-9V-00
RSFP-7(9)V-00
RSFP-1.2.4.5.8(9)V-00
RSFP-4.5.7.8(9)V-00
Keying
10 Position Housing
Part Numbers
Keying
RSFP-2.4.6.7.9(10)V-00
10
RSFP-2.5.6.7.8(10)V-00
10
RSFP-3(10)V-00
10
RSFP-4.5.7(10)V-00
10
RSFP-4.9(10)V-00
RSFP-6(10)V-00
10
RSFP-6(10)VB-00
10
RSFP-6.7(10)V-00
10
RSFP-10V-00
10
RSFP-10VB
10
11 Position Housing
Part Numbers
Keying
RSFP-11V
10 11
RSFP-11V-00
10 11
RSFP-2.8.9(11)V-00
RSFP-3.8(11)V-00
10 11
RSFP-4.9(11)V-00
10 11
RSFP-4.9(11)VB-00
12 Position Housing
Part Numbers
Keying
RSFP-12V
10 11 12
RSFP-1(12)V-00
10 11 12
RSFP-2.3(12)V-00
10 11 12
RSFP-2.4(12)V-00
RSFP-2.12(12)V-00
RSFP-3.4(12)V-00
10 11
10 11 12
Single Position Low Profile RSF Housing
Housing
RSFP-LP-1V-250
Contact
15
RSF CONNECTOR
Cavity Blocking Plug ––––––––––––––––––––––––––––––––––––––––––––––
RSFP-PK
Applicable tab –––––––––––––––––––––––––––––––––––––––––––––––––––
Note: Make sure there are no unneeded ribs or other protuberances on tab surfaces.
16
很抱歉,暂时无法提供与“RSFP-2(5)V-00”相匹配的价格&库存,您可以联系我们找货
