SIB-127-02-F-S-LC
SIB-127-02-F-S-LC
    SAMTEC(申泰)
    .100 SINGLE INTERFACE BEAM ASSEM
SIB-127-02-F-S-LC 数据手册
ONE-PIECE INTERFACES (2.54 mm) .100" PITCH • SIB/SIR1 SERIES SPECIFICATIONS Insulator Material: Black Liquid Crystal Polymer Contact Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Current Rating: 2.6 A per pin (1 pin powered) Operating Temp Range: -55 °C to +125 °C SIB -1 NO. OF POSITIONS - 02 02 thru 30 S Insulator Material: Black LCP Contact Material: Phosphor Bronze Weld Tab: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Current Rating: 2.8 A per pin (1 pin powered) –LC 1RRISRVLWLRQV[           —LC SIR1 - - NO. OF POSITIONS –03, –05, –10, –15 (Per Row) - PLATING OPTION –L = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail –S = 30 µ" (0.76 µm) Gold on contact, Matte Tin on tail PROCESSING - OPTION –A = Alignment Pin –K = (4.00 mm) .157" DIA Polyimide Film Pick & Place Pad –TR –FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks)     S = Tape & Reel 1RRISRVLWLRQV[      Lead-Free Solderable: Yes SMT Lead Coplanarity: (0.10 mm) .004" max Note: Some lengths, styles and options are non-standard, non-returnable. OPTION = Locking Clip (Manual placement required) Some lengths, styles and options are non-standard, non-returnable. SPECIFICATIONS - = Gold flash on contact, Matte Tin on tail Lead-Free Solderable: Yes SMT Lead Coplanarity: (0.10 mm) .004" max (02-19) (0.15 mm) .005" max (20-30)* *(.004" stencil solution may be available; contact ipg@samtec.com) Notes: The SIB Series is intended for vertical mating only. - PLATING OPTION –F (Per Row) PROCESSING -     samtec.com?SIB or samtec.com?SIR1 Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-224
SIB-127-02-F-S-LC 价格&库存
很抱歉,暂时无法提供与“SIB-127-02-F-S-LC”相匹配的价格&库存,您可以联系我们找货
