SM07B-LBTAKS-TD-N2T-K-TB(HF)
    JST
    插件
    线对板针座
SM07B-LBTAKS-TD-N2T-K-TB(HF) 数据手册
LBT CONNECTOR A Type Emboss Emboss Tape Tape Disconnectable Crimp style connectors LBT CONNECTOR A Type Specifications • Current rating: Power supply circuit; 7.0 A AC/DC (AWG #20) Signal circuit; 0.5 A AC/DC (AWG #28) • Voltage rating: 50 V AC/DC • Temperature range: -25℃ to +85℃ (including temperature rise in applying electrical current) • Contact resistance: Power supply circuit Initial value/ 15 mΩ max. After environmental tests/ 30 mΩ max. Signal circuit Initial value/ 20 mΩ max. After environmental tests/ 40 mΩ max. • Insulation resistance: 100 MΩ min. • Withstanding voltage: 500 VAC/minute • Applicable wire: Power supply circuit Conductor size/ AWG #24 to #20 Insulation O.D./ 1.11 to 1.44 mm Signal circuit Conductor size/ AWG #28 Insulation O.D./ 0.6 to 0.8 mm * In using the products,refer to "Handling Precaution for Terminal and Connector" described on our website (Technical documents of Product information page). * RoHS2 compliance * Dimensional unit: mm * Contact JST for details. This connector is for connecting the lithium polymer battery or for connecting DC-IN, and has the sequence structure for connection to the power supply circuit in preference to connection to the signal circuit by dividing the signal circuit and power supply circuit clearly. Moreover, this is the low profile connector (space saving) for applying the high current by adopting the heat radiation structure. ● Connector for power supply (7.0 A) ● Low profile (Space saving) ● Hybrid model of Signal circuit + Power supply circuit ● Heat radiation structure ● Sequence structure ● High-strength ● Check of incomplete mating Standards   Recognized E60389 PC board layout and Assembly layout A±0.05 B ±0.05 1.25 ±0.05 1 4.8 ±0.05 +0.1 0 2.75 ±0.05 2.9 ±0.05 2.5 ±0.05 0.5 1.2 +0.1 0 ±0.05 R0.25 +0.1 0 (9.9) 3 0.6 ±0.05 Circuit No.1 1.55 ±0.05 1±0.05 2.05 ±0.05 C±0.05 1.5 1.5±0.05 5.65 ±0.05 ±0.05 Header outline Note: 1. The above figure is the figure viewed from the connector mounting side. 2. Tolerances are non-cumulative: ± 0.05 mm for all centers. The dimensions above should serve as a guideline. Contact JST for details. 1 LBT CONNECTOR A Type Contact Power supply 1.7 5.9 Power supply 2.6 0.6 Applicable wire mm2 AWG # Insulation O.D. (mm) 0.22~0.5 24~20 1.11~1.44 7,000 0.08 28 0.6~0.8 23,000 Model No. 1.2 SLBTAD-01T-M0.5 SSH-003T-P0.2-H Signal 1.45 2.9 Q'ty/ reel LBT CONNECTOR A Type Material and Finish Power supply: Copper alloy, tin-plated (reflow treatment) Signal: Phosphor bronze, tin-plated (reflow treatment) RoHS2 compliance Contact Signal SLBTAD-01T-M0.5 3.9 1.6 2 0.8 0.8 AP-K2N アプリケータ Dies Crimp applicator with dies MKS-L MK/SLBTAD-01-05 APLMK SLBTAD01-05 MKS-L-10-3 MK/SSH/L-003-02 APLMK SSH/L003-02 Note: Contact JST for fully automatic crimping applicator. 1.35 0.5 SSH-003T-P0.2-H Crimping machine Crimp applicator 0.45 Housing No. of circuits Power supply D B 1 Model No. Signal LBTAR-03V-2K-K(HF) LBTAR-05V-2K-K(HF) LBTAR-07V-2K-K(HF) LBTAR-09V-2K-K(HF) 1 C 3 2 3 5 7 Dimensions (mm) C B D Q’ty/ bag 3.45 - 9.1 3,000 5.45 2.0 11.1 3,000 7.45 4.0 13.1 2,000 9.45 6.0 15.1 2,000 7.45 Material and Finish PBT, UL94V-0 RoHS2 compliance Circuit No.1 mark Header No. of circuits D 6.55 0.25 Power supply 1 2 3 5 7 3 K-A JST Signal Model No. SM03B-LBTAKS-TD-N2T-K(HF) SM05B-LBTAKS-TD-N2T-K(HF) SM07B-LBTAKS-TD-N2T-K(HF) SM09B-LBTAKS-TD-N2T-K(HF) Dimensions (mm) A B 8.2 3.45 C D Q'ty/ reel - 9.1 1,500 10.2 5.45 2.0 11.1 1,500 12.2 7.45 4.0 13.1 1,500 14.2 9.45 6.0 15.1 1,500 0.8 Material and Finish 1 0.8 C B A Power supply contact: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Signal contact: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Housing: Heat resisting resin, UL94V-0 Solder tab: Copper alloy, copper-undercoated, tin-plated (reflow treatment) RoHS2 compliance Note: The products listed above are supplied on embossed-tape. 2 LBT CONNECTOR A Type Model number allocation Contact for power supply circuit Contact for signal circuit S LBTA D - 01 T - M 0.5 S SH - 003 T - P 0.2 - H Form: S... Strip form Form: S...Strip form Series name Series name Product shape: D...Contact for power supply circuit Applicable wire: AWG #28 Applicable wire: AWG #24 to #20 Surface finish: T...Tin-plated (reflow treatment) Surface finish: T...Tin-plated (reflow treatment) Material: P...Phosphor bronze Material: Copper alloy Terminal size Terminal size Type: For single socket Housing LBTA R - 09 V - 2 K - K (HF) Series name Part name: Receptacle No. of circuits (Power supply circuit + Signal circuit): 3, 5, 7, 9 Flammability: V...UL94V-0 No. of circuits (Power supply circuit): 2 Color indication: K...Black Product type: K...High-strength product Indication of halogen-free: (HF)...Halogen-free Header SM 09 B - LBTA K S - T D - N 2 T - K - TB (HF) Assembly style: SM...SMT Side entry type No. of circuits (Power supply circuit + Signal circuit): 3, 5, 7, 9 Part name: Header Series name Color indication: K...Black Indication of clinch: S...No clinch Surface finish (Signal circuit): T...Copper-underplated Tin-plated (reflow treatment) Solder tab specification: D...DIP type Sequence (Between power supply circuits): N...None No. of circuits (Power supply circuit): 2 Surface finish (Power supply circuit): T...Copper-underplated Tin-plated (reflow treatment) Product type: K...High-strength product Packaging style: TB...Embossed-taping Indication of halogen-free: (HF)... Halogen-free 3
SM07B-LBTAKS-TD-N2T-K-TB(HF) 价格&库存
很抱歉,暂时无法提供与“SM07B-LBTAKS-TD-N2T-K-TB(HF)”相匹配的价格&库存,您可以联系我们找货
    • 1+7.029661+0.90739
    • 10+4.4559110+0.57517
    • 50+3.8956450+0.50285
    • 100+3.52796100+0.45539
    • 500+3.45793500+0.44635
    • 1000+3.405411000+0.43957
    • 2000+3.379142000+0.43618
    库存:1213
