F-217
SS–132–G–2
ESD–115–TT–05
(2.54 mm) .100"
SS, SD, ESD, ESS, HSS SERIES
PRECISION MACHINED SOCKET STRIPS
Mates with:
TS, TD, HTS, BBS,
BBD, BBL, BDL, BHS
TYPE
STRIP
NO. PINS
PER ROW
1
PLATING
OPTION
LEAD
STYLE
OTHER
OPTION
OPTION
SPECIFICATIONS
For complete specifications
see www.samtec.com?SS,
www.samtec.com?ESS,
www.samtec.com?SD,
www.samtec.com?ESD or
www.samtec.com?HSS
Insulator Material:
SS, SD, ESS, ESD=
Black G.F. Polyester
HSS=
Black Liquid Crystal Polymer
Contact:
BeCu
Shell:
Brass except Style 5A
Phosphor Bronze
Plating:
Au over 50 µ" (1.27 µm) Ni or
Sn over 50 µ" (1.27 µm) Ni
Operating Temp Range:
-55 °C to +125 °C
Contact Resistance:
10 mW
Lead Size Range:
(0.38 mm to 0.56 mm)
.015" to .022" DIA
and most IC leads
RoHS Compliant:
Yes
Lead-Free Solderable:
Wave only
01 thru 32
01 thru 36
= 30 µ" (0.76 µm) Gold contact,
Tin shell
SS
= Standard
= High Temp
Single Row Socket Single Row Socket
10 µ" (0.25 µm) Gold shell
(2.54) .100 x No. of Positions
–1A, –1B or –1C
(4.90)
.193
(1.32)
.052
DIA
(2.54)
.100
ESD
(2.54)
(2.54)
.100 TYP
= (2.54)
Standard Double
(5.08)
.100
.200
Row Socket
(2.54)
.100
For LIF specify –23
(ESS, ESD)
(0.76)
.030
Y
= Elevated Double
(2.54)
Row Socket .100
LEAD STYLE
Y
–1A or –21A
(9.14)
.360
(12.95)
.510
(6.60)
.260
–1B or –21B
(0.64)
.025 SQ
Style –(2.54)
5A not available.
TYP& –05 socket
Styles.100
–5A
heads not countersunk.
–1C or –21C
(0.76)
.030
B
A
C
(0.64)
.025
SQ
–2, –22*,–5A,
or –38*
*For LIF specify –22 or –38 (SS, HSS, SD)
(2.54)
.100
(5.08)
.200
–03, –04, –05
(1.83)
.072 DIA
(2.54)
.100
SD
(1.83)
.072
DIA
(2.54)
.100 TYP
(0.76)
.030
(2.54)
.100
(1.32)
.052
DIA
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
• Locking lead option on ESS
and ESD series
Contact Samtec.
For LIF specify –21A, –21B or –21C
(SS, HSS, SD)
(2.54)
.100 TYP
N/A Style –5A
(MOQ Required)
Styles – 5A & –05 socket
(2.54)
.100
(0.76)
.030
REF
ALSO AVAILABLE
= Tin contact and shell
(Styles 1, 2, 4, and 05
except LIF N/A)
= Elevated Single Row Socket
= Non
Flush
Requires -T Plating Option
–TT
ESS
–N
Locking
Socket
(7.62)
.300
(3.43)
.135
–G
HSS
Add –L suffix for locking
lead socket in end positions.
Requires Style -2 or -22 and
.035" ± .003 DIA board hole.
–T
= HSS, SD & ESD Series
FILE NO. E111594
–L
= 10 µ" (0.25 µm) Gold contact,
Tin shell
(Styles 2 & 22 only)
= SS, ESS Series
RECOGNITIONS
For complete scope
of recognitions see
www.samtec.com/quality
–S
X
LIF= Low Insertion Force
LEAD
STYLE
–2 or –22
Z
–38
–5A
Y
X
DIA
Y
Z
(0.51) (3.18) (7.62)
.020
.125
.300
(0.51) (4.57) (8.89)
.020
.180
.350
(0.89) (12.95) (17.86)
.035
.510
.703
Locking lead available. See OPTION.
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
LEAD
STYLE
A
B
C
–05
(17.86) (13.46) (4.39)
.703
.530 .173
–03 or
–23
(11.51) (8.38) (3.12)
.453
.330 .123
–04
(14.05) (10.92) (3.12)
.553
.430 .123
很抱歉,暂时无法提供与“SS-102-G-38”相匹配的价格&库存,您可以联系我们找货
