SS-113-G-1C
SS-113-G-1C
    SAMTEC(申泰)
    SOCKET STRIPS
SS-113-G-1C 数据手册
F-224 WEB SS–132–G–2 ESD–115–TT–05 SS, SD, ESD, ESS, HSS SERIES (2.54 mm) .100" PRECISION MACHINED SOCKET STRIPS Mates with: TS, TD, HTS, BBS, BBD, BBL, BDL, BHS TYPE STRIP NO. PINS PER ROW 1 LEAD STYLE PLATING OPTION OTHER OPTION OPTION SPECIFICATIONS For complete specifications see www.samtec.com?SS, www.samtec.com?ESS, www.samtec.com?SD, www.samtec.com?ESD or www.samtec.com?HSS Insulator Material: SS, SD, ESS, ESD= Black G.F. Polyester HSS= Black Liquid Crystal Polymer Contact: BeCu Shell: Brass except Style 5A Phosphor Bronze Plating: Au over 50 µ" (1.27 µm) Ni or Sn over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +125 °C Lead Size Range: (0.38 mm to 0.56 mm) .015" to .022" DIA and most IC leads RoHS Compliant: Yes Lead-Free Solderable: SS, SD, ESS, ESD: No, Lead Wave only HSS: Yes 01 thru 32 =SS, ESS Series 01 thru 36 =HSS, SD & ESD Series SS HSS –T –TT (4.90) .193 (1.32) .052 DIA (2.54) .100 x No. of Positions (2.54) .100 (2.54) .100 ESD (2.54) .100 x No. of Positions = (5.08) Standard .200 Row Socket –03, –04, –05 For LIF specify –23 (ESS, ESD) (1.83) .072 DIA (2.54) .100 (2.54) Double .100 TYP • Locking lead option on ESS and ESD series For LIF specify –21A, –21B or –21C (SS, HSS, SD) (2.54) .100 TYP SD (MOQ Required) –1A, –1B OR –1C (2.54) .100 x No. of Positions (2.54) .100 ALSO AVAILABLE LIF= Low Insertion Force (2.54) .100 N/A Style –5A Requires -T Plating Option = Tin contact and shell (Styles 1, 2, 4, and 05 except LIF N/A) Styles –5A & –05 socket heads not countersunk. (0.76) .030 REF (7.62) .300 (3.43) .135 = 30 µ" (0.76 µm) Gold contact, 10 µ" (0.25 µm) Gold shell = Elevated Single Row Socket –N = Non Flush Locking = Socket Add –L suffix for locking lead socket in end positions. Requires Style -2 or -22 and .035" ± .003 DIA board hole. = 30 µ" (0.76 µm) Gold contact, Tin shell ESS FILE NO. E111594 –L = 10 µ" (0.25 µm) Gold contact, Tin shell (Styles 2 & 22 only) –G = Standard = High Temp Single Row Socket Single Row Socket RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality –S (0.76) .030 LEAD STYLE –1A or –21A Y = Elevated Double (2.54) Row Socket .100 –1B or –21B (0.64) .025 SQ (2.54) Style .100 –5A not available. TYP Styles –5A & –05 socket heads not countersunk. –1C or –21C Y (9.14) .360 (12.95) .510 (6.60) .260 (0.76) .030 B A C (0.64) .025 SQ –2, –22*,–5A, or –38* *For LIF specify –22 or –38 (SS, HSS, SD) (2.54) .100 x No. of Positions (2.54) .100 TYP (2.54) .100 Note: Some lengths, styles and options are non-standard, non-returnable. (1.83) .072 DIA (2.54) .100 (5.08) .200 (0.76) .030 (1.32) .052 DIA Z Y X LEAD STYLE –2 or –22 –38 –5A X DIA Y Z (0.51) (3.18) (7.62) .020 .125 .300 (0.51) (4.57) (8.89) .020 .180 .350 (0.89) (12.95) (17.86) .035 .510 .703 LEAD STYLE –05 –03 or –23 –04 A B C (17.86) (13.46) (4.39) .703 .530 .173 (11.51) (8.38) (3.12) .453 .330 .123 (14.05) (10.92) (3.12) .553 .430 .123 Locking lead available. See OPTION. WWW.SAMTEC.COM Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
SS-113-G-1C 价格&库存
很抱歉,暂时无法提供与“SS-113-G-1C”相匹配的价格&库存,您可以联系我们找货
SS-113-G-1C
  • 17+53.2081917+6.90372
