F-224 SUPPLEMENT
SSA–115–S–T
SSA–108–W–T–RA
SSA–118–W–G
(2.54 mm) .100"
SSA SERIES
COST-EFFECTIVE SOCKET STRIPS
Mates with:
TS, HTS, BBS,
BBL, BHS
SSA
1
NO. OF
POSITIONS
LEAD
STYLE
SPECIFICATIONS
Insulator Material:
Black PET Polyester
Contact Material:
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Operating Temp Range:
-55 °C to +125 °C with Gold
-55 °C to +105 °C with Tin
Heat Deflection Temp:
215 °C @ 264 psi (1.8 MPa)
Dielectric Withstanding
Voltage:
1000 VRMS
Lead Size Range:
(0.38 mm) .015" to
(0.56 mm) .022" DIA
and most IC leads
Insertion Depth:
(1.27 mm) .050" to
(3.30 mm) .130"
RoHS Compliant:
Yes
Lead-Free Solderable:
Wave only
RECOGNITIONS
For complete scope of
recognitions see
www.samtec.com/quality
–T
= Matte Tin
(0.25)
.010
x
(0.56)
.022
(2.54) .100 x No. of Positions
(2.54)
.100
(2.54)
.100
TYP
–RA
= 10 µ"
(0.25 µm) Gold
= P.C.
01 thru 32
RA
OPTION
–G
–S
For complete specifications
see www.samtec.com?SSA
PLATING
OPTION
= Right-angle
(7.37)
.290
(3.84)
.151
(0.64)
.025
SQ
(14.61)
.575
(Requires –W Lead Style)
–W
= Wire Wrap
(5.46)
.215
P.C.
(0.38)
.015
W/W
(0.64)
.025
SQ
(16.66)
.656
FILE NO. E111594
High-reliability
double side-wipe
contacts
Snap-strip
feature
UL Rated 94 V-O
High Temp PET
Polyester Body
Selectively plated
for lower contact
resistance
Note:
Some sizes, styles and
options are non-standard,
non-returnable.
Standoffs allow for
easy board cleaning
WWW.SAMTEC.COM
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
很抱歉,暂时无法提供与“SSA-111-W-T-RA”相匹配的价格&库存,您可以联系我们找货
