F-218 (Rev 10OCT17)
SSW–125–01–G–S
SSQ–116–03–L–T
(2.54 mm) .100"
THROUGH-HOLE .025" SQ POST SOCKET
SPECIFICATIONS
For complete specifications
see www.samtec.com?SSW
or www.samtec.com?SSQ
Insulator Material:
Black Liquid Crystal Polymer
(-S & -D) or
Black High Temperature
Thermoplastic (-T)
Contact Material:
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Current Rating (SSW/TSM):
4.7 A per pin
(2 pins powered)
Current Rating (SSQ/TSW):
6.3 A per pin
(2 pins powered)
Operating Temp Range:
-55 °C to +125 °C with Gold
-55 °C to +105 °C with Tin
Insertion Depth:
(3.68 mm) .145" to
(6.35 mm) .250"
Normal Force:
Standard= 125 grams (4.4 N)
Max Cycles:
100 with 10 µ" (0.25 µm) Au
Voltage Rating:
465 VAC / 655 VDC
RoHS Compliant:
Yes
Mates With:
TSW, MTSW, MTLW,
EW, ZW, TSS, ZSS,
TSM, TSSH, HTSS
1
SSW = Solder Tail
–1 = (2.54 mm) .100" Centers
SSQ = Square Tail
(2.54)
.100
2
49
50
(2.41)
.095
(2.54) .100 x No. of Positions + (0.51) .020
100
98
4
2
(2.54) (4.95)
.100 .195
–D
99
97
150
147
3
(2.54)
.100
6
1
3
(2.54)
.100 (5.08)
.200
–T
RECOGNITIONS
For complete scope
of recognitions see
www.samtec.com/quality
PIN CENTERS
–S
PROCESSING
Lead–Free Solderable:
Yes:
-S and -D row option
Wave only:
-P, -T and -Q row option
TYPE STRIP
148
145
150
147
1
4
6
(7.49)
.295
3
(5.08)
.200
–Q
(7.49)
.295
01
thru
50
FILE NO. E111594
148
145
4
1
(8.51)
.335
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
(2.54) .100 x No. of Spaces
–RA
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
NO. PINS
PER ROW
SSW–125–02–G–D–RA
SSW–130–01–G–S
SSW–113–02–T–T–RA
LEAD
STYLE
SSW–118–22–F–T
ROW
OPTION
PLATING
OPTION
–F
TAIL
OPTION
–LL
= Locking Lead
= Right-angle
(Leave blank
for straight pin
version)
= Single Row
–P
–L
OTHER
OPTION
–RA
–S
= Gold flash on contact,
Matte Tin on tail
SSW, SSQ SERIES
Two leads per strip crimped in opposite
directions on or near centerline.
Available on tails from (2.29 mm) .090"
to (7.87 mm) .310" only. N/A with single
row 1 or 2 positions.
= Single Row
(36 pins max)
= 10 µ" (0.25 µm) Gold on contact,
Matte Tin on tail
–D
–G
–“XXX”
= Double Row
= 20 µ" (0.51 µm) Gold on contact,
Gold flash on tail
= Polarized
(Specify “XXX” as position number)
–T
–T
= Triple Row
= Matte Tin
(-T N/A on LIF contacts)
ALSO AVAILABLE
–Q
(MOQ Required)
• Other platings
• Notch option
Contact Samtec.
= Double Row
.200" (5.08 mm) row space
(Outer rows filled only)
Straight Pin Versions (Specify “LEAD STYLE” from chart)
Standard
Insertion
Force
Low
Insertion
Force*
–01
–02
–03
–04
–21
–22
–23
–24
Not
Available
–06**
–S & –P
SINGLE
DOUBLE
OR
TRIPLE
LEAD STYLE
–T
–D
–Q
A
(2.64) .104
(4.93) .194
(10.00) .394
A
(14.83) .584
(2.54)
.100
(3.15) .124
SSW
(0.41) x (0.79)
.016
.031
* LIF not available with Tin Plating
**Style –06 Not available with SSQ
(5.08)
.200
(2.54)
.100
SSQ
(0.64) SQ
.025
(5.08)
.200
Right-Angle Versions (Specify “LEAD STYLE” from chart)
Standard
Low
Insertion Insertion
Force
Force*
–T
–D
–S & –P
LEAD STYLE
–Q
SINGLE DOUBLE TRIPLE
(–S )
(–D)
A
A
A
(2.54)
.100
(2.54)
.100
(7.62)
.300
Not
Available
–02
–22
(2.54)
.100
–03
–23
(7.62)
.300
–04
–24
(12.45)
.490
(–T & –Q)
Not
Not
Available Available
(1.52)
.060
A
SSW
SSQ
(0.41) x (0.79) (0.64)
.016
.031 .025 SQ
A
A
(2.54)
.100
*LIF not available with Tin Plating
(2.54)
.100
WWW.SAMTEC.COM
A
(5.08)
.200
很抱歉,暂时无法提供与“SSQ-125-02-T-D-025”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+40.595171+5.24458
