TCSD-25-D-18.00-01-F-N-R
    SAMTEC(申泰)
    Cable Assembly 0.457m 28AWG 1mm 50 to 50 POS IDC Connector to IDC Connector F-F TIGER EYE™ Bulk
TCSD-25-D-18.00-01-F-N-R 数据手册
F-215 ™ TCSD TMM .26" (6,6 mm) TCSD–08–D–02.00–01–N–R UUUUUUUUUUUUUUUUUUU (2,00 mm) .0787" TCSD SERIES ™ TIGER EYE IDC SOCKET CABLE Mates with: TMM, TMMH, STMM, MMT, TW, MTMM, EHT, ETMM (-SR), ZSTMM TYPE STRIP END OPTION NO. PINS PER ROW 01 LENGTH PLATING OPTION OTHER OPTION N SPECIFICATIONS For complete specifications see www.samtec.com?TCSD –04, –05, –06, –07, –08, –10, –12, –13, –15, –17, –20, –22, –25 Insulator Material: Black Glass Filled Polyester Contact: BeCu Plating: Au or Sn over 50µ" (1,27 µm) Ni Wire: 28 AWG 7/36 Stranded, Tinned, Copper with Gray PVC Insulator Current Rating (TCSD/STMM): 2.8 A per pin (1 pin powered per row) Operating Temp Range: -40°C to +105°C Lead Size Accepted: (0,48 mm) .019" to (0,53 mm) .021" Contact Resistance: 15 mΩ Insertion Depth: (2,87 mm) .113" to (3,17 mm) .125" RoHS Compliant: Yes = Notch Polarization = Assembled Length Assembled Length in INCHES (±1/8") 2 inches minimum –F = Gold flash on contact Leave blank for standard plating: 30µ" (0,76 µm) Gold on contact area (Standard sizes) –S –D = Single End = Double End –SR –P “XX” = Position Polarization = Strain Relief No. of positions x (2,00) .0787 + (7,874) .3100 01 02 TCSD RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality –N –“XX.XX” = Socket Strip (1,02) .040 Not available with –O, –M, –R, –DXX or –BXX Specify “XX” as position number. Same position will be polarized on both ends. (3,17) .125 –D “XX” 1 –B “XX” 01 2" min. = Breakout (4,00) .158 = Daisy Chain “XX” Double Row Connectors Specify “XX” as number of conductors to be broken out. No. of positions x (2,00) .0787 + (4,00) .157 (1,00) .039 1/8" 4" minimum Outer Most (End of assembly) 4 ALSO AVAILABLE (MOQ Required) • Other sizes • Other platings Contact Samtec. “XX” (5,08) .200 (2,00) .0787 (2,00) .0787 –R = Reversed 5"max. 2"min. Breakout starts with Number 1 lead indicated by brown wire or red stripe. Shown on top side. 5 2 POLARIZING KEY Specify PK-01-07 for polarizing key (Available in wheels of six each). Also polarizes SMM Series socket strips. EJECTOR HEADERS & LOCKING CLIPS –M –RW = Middle Reverse = Reverse Wiring See TMM Series. Requires –DXX • Ejector headers • Locking clips 5 –O 01 = Outside Reverse • Strain relief option 02 Note: TCSD Series assemblies are nonstandard, non-returnable. See EHT Series. Blue or black wire opposite position #1. 3 WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. Requires –DXX 5
TCSD-25-D-18.00-01-F-N-R 价格&库存
很抱歉,暂时无法提供与“TCSD-25-D-18.00-01-F-N-R”相匹配的价格&库存,您可以联系我们找货
    • 2+165.97319
    • 10+157.05003
    • 25+147.96969
    • 50+138.10343
    • 100+128.50318
    • 250+118.90292
    • 500+97.90085
    • 1000+82.55737
    库存:30
