TSM-130-01-L-SH-A-P
TSM-130-01-L-SH-A-P
    SAMTEC(申泰)
    .025 SQ. TERMINAL STRIPS
TSM-130-01-L-SH-A-P 数据手册
SURFACE MOUNT .025" SQ POST HEADER 8 G b p s (2.54 mm) .100" PITCH • TSM SERIES TSM Board Mates: SSW, SSQ, SSM, BSW, ESW, ESQ, BCS, SLW, CES, HLE Cable Mates: IDSS, IDSD - TSM 1 - NO. PINS PER ROW LEAD STYLE 02 thru 36 Specify LEAD STYLE from chart SPECIFICATIONS Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +105 °C with Tin; -55 °C to +125 °C with Gold Voltage Rating: 495 VAC -SV/-DV mated with the BCS 475 VAC -SV/-DV mated with the SSM (2.54) .100 x No. of positions (2.54) .100 Post Height (2.54) .100 MATES TSM/SSW (2.54) .100 x No. of positions (3.05) .120 TSM/HLE 4.1 A TSM/BCS 5.0 A 2 POSITIONS POWERED –01 (5.84) .230 SSW, BCS, SSM, IDSS, IDSD –02 (8.13) .320 SSM -DH –03 (10.67) .420 Bottom Mount & Pass Through –04 (3.05) .120 SLW, CES, HLE Post Height 4.7 A 5.4 A MATES WITH (No. of positions x (2.54) .100) – (5.08) .200 CURRENT RATING (PER PIN) TSM/SSM LEAD POST STYLE HEIGHT —SV Row Option PROCESSING Lead–Free Solderable: Yes -DH/-SH/-SV Lead Coplanarity: (0.15 mm) .006" max (02-36)* -DV Lead Coplanarity: (0.10 mm) .004" max (02-05) (0.13 mm) .005" max (06-10)* (0.15 mm) .006" max (11-36)* *(.004" stencil solution may be available; contact ipg@samtec.com) (3.81) .150 (2.54) .100 –01= (4.57) .180 –02, –03, –04 = (4.82) .190 —SH Row Option (2.54) .100 x No. of positions (5.08) .200 Post Height Notes: Severe Environment Testing qualified; aligns with MIL-DTL-55302. Visit samtec.com/set Some sizes, styles and options are non-standard, non-returnable. F-224 (Rev 26APR24) (2.54) .100 (3.81) .150 (No. of positions -2) x (2.54) .100) —DV Row Option samtec.com?TSM Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. - - PLATING OPTION - - ROW OPTION –F –SV = Gold flash on post, Matte Tin on tail = Single Row Vertical Pin –L –DV = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail = Double Row Vertical Pin –S = Single Row Horizontal Pin –SH = 30 µ" (0.76 µm) Gold on post, Matte Tin on tail –DH = Double Row Horizontal Pin –T –TM = Matte Tin = Triple Row Vertical Mixed Technology (Style –01 only) (02 thru 30 positions only) –MT = Mixed Technology Pin (Style –01, –02 or –03 only) (2.54) .100 x No. of positions –“XXX” = Polarized Position –A = Alignment Pin metal or plastic at Samtec discretion (Not available with –TM or –MT) (02 positions minimum) (Not available with –LC) –LC = Locking Clip (Not available with –TM) (3 positions minimum) (Not available with –A) (Manual placement required) –K = (6.50 mm) .256" DIA Polyimide Film Pick & Place Pad (–SH: 4 positions minimum without –TR; 2 & 3 positions available with –TR) (–DH: 4 positions minimum without –TR) –P = Plastic Pick & Place Pad (–DV: 4 positions minimum without –TR; 2 & 3 positions available with –TR) (–SH: 4 positions minimum without –TR; 2 & 3 positions available with –TR) (–DH: 5 positions minimum without –TR) (–SV: 4 positions minimum without –TR; 2 & 3 positions available with –TR) (6.10) .240 (No. of positions x (2.54) .100) – (5.08) .200 –TR Post Height = Tape & Reel –SV: 02-22 positions, –DV: 02-28 positions, –SH: 02-30 positions, –DH: 02-29 positions (Not available with –MT or –TM) (2.54) .100 (3.68) .145 (7.87) .310 OTHER OPTIONS –FR (1.16) .046 = Full Reel Tape & Reel (must order maximum quantity per reel; contact Samtec for quantity breaks) –SV: 02-22 positions, –DV: 02-28 positions, –SH: 02-30 positions, –DH: 02-29 positions (Not available with –MT or –TM) —DH Row Option  [1RRISRVLWLRQV (2.54) .100 x No. of positions   (6.10) .240 (1.52) .060 (2.54) .100 3RVW +HLJKW Post Height     (7.87) .310 —TM Row Option (1.16) .046 —MT Row Option samtec.com?TSM F-224 (Rev 26APR24) Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
TSM-130-01-L-SH-A-P 价格&库存
很抱歉,暂时无法提供与“TSM-130-01-L-SH-A-P”相匹配的价格&库存,您可以联系我们找货
TSM-130-01-L-SH-A-P
  • 7+44.726817+5.78142
